1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools
47  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParse.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseAttributes.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseData.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseDepends.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseExtras.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseHierarchy.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseMain.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseMangle.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseMerge.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseMethodType.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParsePreprocess.h"
58  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseProperties.h"
59  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseString.h"
60  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseSystem.h"
61  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkParseType.h"
62  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkWrap.h"
63  "/builds/gitlab-kitware-sciviz-ci/VTK/Wrapping/Tools/vtkWrapText.h"
64  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Wrapping/Tools/vtkWrappingToolsModule.h"
65  )
66 endif()
67
68 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
69  foreach(file
70  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so.5.13"
71  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so.1"
72  )
73  if(EXISTS "${file}" AND
74  NOT IS_SYMLINK "${file}")
75  file(RPATH_CHECK
76  FILE "${file}"
77  RPATH "\$ORIGIN")
78  endif()
79  endforeach()
80  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
81  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkWrappingTools-pv5.13.so.5.13"
82  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkWrappingTools-pv5.13.so.1"
83  )
84  foreach(file
85  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so.5.13"
86  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so.1"
87  )
88  if(EXISTS "${file}" AND
89  NOT IS_SYMLINK "${file}")
90  file(RPATH_CHANGE
91  FILE "${file}"
92  OLD_RPATH ":::::::"
93  NEW_RPATH "\$ORIGIN")
94  if(CMAKE_INSTALL_DO_STRIP)
95  execute_process(COMMAND "/usr/bin/strip" "${file}")
96  endif()
97  endif()
98  endforeach()
99 endif()
100
101 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
102  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so" AND
103  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so")
104  file(RPATH_CHECK
105  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so"
106  RPATH "\$ORIGIN")
107  endif()
108  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkWrappingTools-pv5.13.so")
109  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so" AND
110  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so")
111  file(RPATH_CHANGE
112  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so"
113  OLD_RPATH ":::::::"
114  NEW_RPATH "\$ORIGIN")
115  if(CMAKE_INSTALL_DO_STRIP)
116  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkWrappingTools-pv5.13.so")
117  endif()
118  endif()
119 endif()
120
121 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
122  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13" AND
123  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13")
124  file(RPATH_CHECK
125  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13"
126  RPATH "\$ORIGIN:\$ORIGIN/../lib64")
127  endif()
128  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/vtkWrapHierarchy-pv5.13")
129  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13" AND
130  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13")
131  file(RPATH_CHANGE
132  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13"
133  OLD_RPATH "\$ORIGIN/../lib64::::::::"
134  NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64")
135  if(CMAKE_INSTALL_DO_STRIP)
136  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapHierarchy-pv5.13")
137  endif()
138  endif()
139 endif()
140
141 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
142  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13" AND
143  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13")
144  file(RPATH_CHECK
145  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13"
146  RPATH "\$ORIGIN:\$ORIGIN/../lib64")
147  endif()
148  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/vtkWrapPython-pv5.13")
149  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13" AND
150  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13")
151  file(RPATH_CHANGE
152  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13"
153  OLD_RPATH "\$ORIGIN/../lib64::::::::"
154  NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64")
155  if(CMAKE_INSTALL_DO_STRIP)
156  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPython-pv5.13")
157  endif()
158  endif()
159 endif()
160
161 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
162  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13" AND
163  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13")
164  file(RPATH_CHECK
165  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13"
166  RPATH "\$ORIGIN:\$ORIGIN/../lib64")
167  endif()
168  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/vtkWrapPythonInit-pv5.13")
169  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13" AND
170  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13")
171  file(RPATH_CHANGE
172  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13"
173  OLD_RPATH "\$ORIGIN/../lib64::::::::"
174  NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64")
175  if(CMAKE_INSTALL_DO_STRIP)
176  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapPythonInit-pv5.13")
177  endif()
178  endif()
179 endif()
180
181 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
182  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13" AND
183  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13")
184  file(RPATH_CHECK
185  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13"
186  RPATH "\$ORIGIN:\$ORIGIN/../lib64")
187  endif()
188  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/vtkParseJava-pv5.13")
189  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13" AND
190  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13")
191  file(RPATH_CHANGE
192  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13"
193  OLD_RPATH "\$ORIGIN/../lib64::::::::"
194  NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64")
195  if(CMAKE_INSTALL_DO_STRIP)
196  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkParseJava-pv5.13")
197  endif()
198  endif()
199 endif()
200
201 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
202  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13" AND
203  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13")
204  file(RPATH_CHECK
205  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13"
206  RPATH "\$ORIGIN:\$ORIGIN/../lib64")
207  endif()
208  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/vtkWrapJava-pv5.13")
209  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13" AND
210  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13")
211  file(RPATH_CHANGE
212  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13"
213  OLD_RPATH "\$ORIGIN/../lib64::::::::"
214  NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64")
215  if(CMAKE_INSTALL_DO_STRIP)
216  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapJava-pv5.13")
217  endif()
218  endif()
219 endif()
220
221 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
222  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13" AND
223  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13")
224  file(RPATH_CHECK
225  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13"
226  RPATH "\$ORIGIN:\$ORIGIN/../lib64")
227  endif()
228  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/vtkWrapSerDes-pv5.13")
229  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13" AND
230  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13")
231  file(RPATH_CHANGE
232  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13"
233  OLD_RPATH "\$ORIGIN/../lib64::::::::"
234  NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64")
235  if(CMAKE_INSTALL_DO_STRIP)
236  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/vtkWrapSerDes-pv5.13")
237  endif()
238  endif()
239 endif()
240
