1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Web/Python 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
"xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/web" TYPE FILE FILES
"/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/__init__.py")
49 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xpythonx
" OR NOT CMAKE_INSTALL_COMPONENT) 50 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/web
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/_default_proxies.py
") 53 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 54 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/web
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/camera.py
" OR NOT CMAKE_INSTALL_COMPONENT) 58 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/web
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/data_converter.py
") 61 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 62 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/web
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/data_writer.py
") 65 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 66 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/web
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/dataset_builder.py
") 69 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 70 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/web
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/decorators.py
") 73 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 74 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/web
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/helper.py
") 77 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 78 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/web
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/protocols.py
") 81 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 82 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/web
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/pv_wslink.py
") 85 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 86 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/web
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/test_server.py
") 89 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/web
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/vtkjs_helper.py
") 93 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 94 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/web
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Web/Python/paraview/web/venv.py
