1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Wrapping/Python
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/__init__.py")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/_backwardscompatibilityhelper.py")
51 endif()
52
53 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/algorithms" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/algorithms/__init__.py")
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/algorithms" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/algorithms/openpmd.py")
59 endif()
60
61 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/algorithms" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/algorithms/savgreader.py")
63 endif()
64
65 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/apps" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/apps/__init__.py")
67 endif()
68
69 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/apps" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/apps/__main__.py")
71 endif()
72
73 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/apps" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/apps/_internals.py")
75 endif()
76
77 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/apps" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/apps/glance.py")
79 endif()
80
81 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/apps" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/apps/trame.py")
83 endif()
84
85 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/benchmark" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/benchmark/__init__.py")
87 endif()
88
89 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/benchmark" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/benchmark/basic.py")
91 endif()
92
93 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/benchmark" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/benchmark/logbase.py")
95 endif()
96
97 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
98  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/benchmark" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/benchmark/logparser.py")
99 endif()
100
101 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
102  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/benchmark" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/benchmark/manyspheres.py")
103 endif()
104
105 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
106  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/benchmark" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/benchmark/waveletcontour.py")
107 endif()
108
109 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
110  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/benchmark" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/benchmark/waveletvolume.py")
111 endif()
112
113 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
114  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/catalyst" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/catalyst/__init__.py")
115 endif()
116
117 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
118  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/catalyst" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/catalyst/bridge.py")
119 endif()
120
121 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
122  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/catalyst" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/catalyst/detail.py")
123 endif()
124
125 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
126  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/catalyst" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/catalyst/importers.py")
127 endif()
128
129 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
130  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/catalyst" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/catalyst/v2_internals.py")
131 endif()
132
133 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
134  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/collaboration.py")
135 endif()
136
137 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
138  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/coprocessing.py")
139 endif()
140
141 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
142  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/cpstate.py")
143 endif()
144
145 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
146  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/demos" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/demos/__init__.py")
147 endif()
148
149 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
150  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/demos" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/demos/export_catalyst_state.py")
151 endif()
152
153 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
154  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/demos" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/demos/filedriver_miniapp.py")
155 endif()
156
157 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
158  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/demos" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/demos/show_grid_as_background.py")
159 endif()
160
161 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
162  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/demos" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/demos/wavelet_miniapp.py")
163 endif()
164
165 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
166  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/demos" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/demos/wavelet_miniapp_plugin.py")
167 endif()
168
169 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
170  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/detail" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/detail/__init__.py")
171 endif()
172
173 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
174  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/detail" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/detail/annotation.py")
175 endif()
176
177 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
178  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/detail" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/detail/calculator.py")
179 endif()
180
181 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
182  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/detail" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/detail/catalyst_export.py")
183 endif()
184
185 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
186  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/detail" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/detail/cdbwriter.py")
187 endif()
188
189 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
190  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/detail" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/detail/exportnow.py")
191 endif()
192
193 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
194  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/detail" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/detail/extract_selection.py")
195 endif()
196
197 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
198  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/detail" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/detail/loghandler.py")
199 endif()
200
201 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
202  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/detail" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/detail/pythonalgorithm.py")
203 endif()
204
205 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
206  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/detail" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/detail/python_selector.py")
207 endif()
208
209 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
210  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/detail" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/detail/catalyst_export.py")
211 endif()
212
213 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
214  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/incubator" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/incubator/__init__.py")
215 endif()
216
217 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
218  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/inspect.py")
219 endif()
220
221 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
222  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/live.py")
223 endif()
224
225 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
226  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/modules" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/modules/__init__.py")
227 endif()
228
229 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
230  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/numeric.py")
231 endif()
232
233 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
234  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/numpy_support.py")
235 endif()
236
237 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
238  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/pv-vtk-all.py")
239 endif()
240
241 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
242  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/python_view.py")
243 endif()
244
245 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
246  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/selection.py")
247 endif()
248
249 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
250  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/servermanager.py")
251 endif()
252
253 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
254  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/simple.py")
255 endif()
256
257 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
258  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/smstate.py")
259 endif()
260
261 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
262  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/smtesting.py")
263 endif()
264
265 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
266  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/smtrace.py")
267 endif()
268
269 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
270  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/spatiotemporalparallelism.py")
271 endif()
272
273 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
274  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tests" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/tests/basic_rendering.py")
275 endif()
276
277 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
278  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tests" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/tests/__init__.py")
279 endif()
280
281 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
282  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tests" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/tests/internals.py")
283 endif()
284
285 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
286  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tests" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/tests/__main__.py")
287 endif()
288
289 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
290  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tests" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/tests/proxy_deprecation.py")
291 endif()
292
293 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
294  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tests" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/tests/validate_extracts.py")
295 endif()
296
297 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
298  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tests" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/tests/verify_eyedomelighting.py")
299 endif()
300
301 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
302  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/tpl/__init__.py")
303 endif()
304
305 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
306  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/util/__init__.py")
307 endif()
308
309 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
310  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/util" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/util/vtkAlgorithm.py")
311 endif()
312
313 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
314  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/variant.py")
315 endif()
316
317 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
318  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/vtkConstants.py")
319 endif()
320
321 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
322  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/python3.10/site-packages/paraview/vtk.py")
323 endif()
324
