pqPresetGroupsManager is an object to manage the groups of color map presets displayed in the pqPresetDialog. More...
#include <pqPresetGroupsManager.h>
Inherits QObject.
Public Slots | |
void | saveGroupsToSettings () |
Save groups to settings. More... | |
Signals | |
void | groupsUpdated () |
Fired whenever loadGroups or replaceGroups is called and new group information is available. More... | |
pqPresetGroupsManager (QObject *p) | |
Create a new groups manager. More... | |
~pqPresetGroupsManager () override | |
int | numberOfGroups () |
Returns the number of groups the manager knows of. More... | |
int | numberOfPresetsInGroup (const QString &groupName) |
Returns the number of presets in the given group. More... | |
int | presetRankInGroup (const QString &presetName, const QString &groupName) |
Returns the rank (index) of the given preset in the given group. More... | |
QList< QString > | groupNames () |
Returns a list of the group names the manager knows of. More... | |
QString | groupName (int i) |
Returns the name of the ith group in the manager's list of groups. More... | |
void | loadGroups (const QString &json) |
Load groups from the given JSON string (for the format see the class documentation) and add the groups to the groups in the manager. More... | |
void | replaceGroups (const QString &json) |
Clears all groups in the manager and then loads groups from the given JSON string (see loadGroups). More... | |
bool | loadGroupsFromSettings () |
Load the groups from the settings Return true if loading was successful. More... | |
void | addToGroup (const QString &groupName, const QString &presetName) |
Adds a preset to a group. More... | |
void | removeFromGroup (const QString &groupName, const QString &presetName) |
Removes a preset from a group. More... | |
void | removeFromAllGroups (const QString &presetName) |
Removes a preset from all groups. More... | |
static QString | getPresetGroupsJson () |
A pqPresetGroupsManager is created by the pqPVApplicationCore and registered as a manager. To get it:
The group manager loads the groups of presets from a json file with this format:
Definition at line 63 of file pqPresetGroupsManager.h.
pqPresetGroupsManager::pqPresetGroupsManager | ( | QObject * | p | ) |
Custom applications should use the one created by pqPVApplicationCore (see class description).
int pqPresetGroupsManager::numberOfGroups | ( | ) |
int pqPresetGroupsManager::presetRankInGroup | ( | const QString & | presetName, |
const QString & | groupName | ||
Returns -1 if the preset is not in the group (the preset dialog relies on this).
QList<QString> pqPresetGroupsManager::groupNames | ( | ) |
QString pqPresetGroupsManager::groupName | ( | int | i | ) |
void pqPresetGroupsManager::loadGroups | ( | const QString & | json | ) |
This is an append operation so the groups already in the manager will not be removed. If the json string has a group with the same name as one already in the manager, then the color maps in that group will be appended to the existing group.
void pqPresetGroupsManager::replaceGroups | ( | const QString & | json | ) |
This is an override operation instead of the append provided by loadGroups.
bool pqPresetGroupsManager::loadGroupsFromSettings | ( | ) |
Creates the group if it does not exist
void pqPresetGroupsManager::removeFromGroup | ( | const QString & | groupName, |
const QString & | presetName | ||
void pqPresetGroupsManager::removeFromAllGroups | ( | const QString & | presetName | ) |
slot |
signal |
