ftconfig.h
1 /****************************************************************************
2  *
3  * ftconfig.h.in
4  *
5  * UNIX-specific configuration file (specification only).
6  *
7  * Copyright (C) 1996-2022 by
8  * David Turner, Robert Wilhelm, and Werner Lemberg.
9  *
10  * This file is part of the FreeType project, and may only be used,
11  * modified, and distributed under the terms of the FreeType project
12  * license, LICENSE.TXT. By continuing to use, modify, or distribute
13  * this file you indicate that you have read the license and
14  * understand and accept it fully.
15  *
16  */
17
18
19  /**************************************************************************
20  *
21  * This header file contains a number of macro definitions that are used by
22  * the rest of the engine. Most of the macros here are automatically
23  * determined at compile time, and you should not need to change it to port
24  * FreeType, except to compile the library with a non-ANSI compiler.
25  *
26  * Note however that if some specific modifications are needed, we advise
27  * you to place a modified copy in your build directory.
28  *
29  * The build directory is usually `builds/<system>`, and contains
30  * system-specific files that are always included first when building the
31  * library.
32  *
33  */
35 #ifndef FTCONFIG_H_
36 #define FTCONFIG_H_
37
38 #include <ft2build.h>
39 #include FT_CONFIG_OPTIONS_H
40 #include FT_CONFIG_STANDARD_LIBRARY_H
41
42 #define HAVE_UNISTD_H
43 #define HAVE_FCNTL_H
45 #include <freetype/config/integer-types.h>
46 #include <freetype/config/public-macros.h>
47 #include <freetype/config/mac-support.h>
48
49 #endif /* FTCONFIG_H_ */
50
51
52 /* END */
