3 if(
4 message(FATAL_ERROR
"CMake >= 2.6.0 required")
15 # Protect against multiple inclusion, which would fail when already imported targets are added once more.
17 set(_targetsNotDefined)
19 foreach(_expectedTarget DigitalSignalProcessing::DSPDataModel DigitalSignalProcessing::DSPFiltersPlugin)
20 list(APPEND _expectedTargets ${_expectedTarget})
21 if(NOT TARGET ${_expectedTarget})
22 list(APPEND _targetsNotDefined ${_expectedTarget})
24 if(TARGET ${_expectedTarget})
25 list(APPEND _targetsDefined ${_expectedTarget})
28 if("${_targetsDefined}
") 29 unset(_targetsDefined) 30 unset(_targetsNotDefined) 31 unset(_expectedTargets) 32 set(CMAKE_IMPORT_FILE_VERSION) 36 if(NOT "${_targetsDefined}
" STREQUAL "") 37 message(FATAL_ERROR "Some (but not all) targets in
this export
") 39 unset(_targetsDefined) 40 unset(_targetsNotDefined) 41 unset(_expectedTargets) 44 # Create imported target DigitalSignalProcessing::DSPDataModel 45 add_library(DigitalSignalProcessing::DSPDataModel STATIC IMPORTED) 47 set_target_properties(DigitalSignalProcessing::DSPDataModel PROPERTIES 48 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel;/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/DataModel
" 49 INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::CommonExecutionModel;\$<LINK_ONLY:VTK::CommonDataModel>
" 52 # Create imported target DigitalSignalProcessing::DSPFiltersPlugin 53 add_library(DigitalSignalProcessing::DSPFiltersPlugin STATIC IMPORTED) 55 set_target_properties(DigitalSignalProcessing::DSPFiltersPlugin PROPERTIES 56 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/DSP/Filters
" 57 INTERFACE_LINK_LIBRARIES "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonExecutionModel;VTK::FiltersGeneral;\$<LINK_ONLY:DigitalSignalProcessing::DSPDataModel>;\$<LINK_ONLY:VTK::FiltersCore>;\$<LINK_ONLY:VTK::FiltersExtraction>;\$<LINK_ONLY:VTK::ParallelCore>
" 60 # Import target "DigitalSignalProcessing::DSPDataModel
" for configuration "Debug
" 61 set_property(TARGET DigitalSignalProcessing::DSPDataModel APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG) 62 set_target_properties(DigitalSignalProcessing::DSPDataModel PROPERTIES 63 IMPORTED_LINK_INTERFACE_LANGUAGES_DEBUG "CXX
" 64 IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/DigitalSignalProcessing/libvtkDSPDataModel.a
" 67 # Import target "DigitalSignalProcessing::DSPFiltersPlugin
" 68 set_property(TARGET DigitalSignalProcessing::DSPFiltersPlugin APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG) 69 set_target_properties(DigitalSignalProcessing::DSPFiltersPlugin PROPERTIES 70 IMPORTED_LINK_INTERFACE_LANGUAGES_DEBUG "CXX
" 71 IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/DigitalSignalProcessing/libvtkDSPFiltersPlugin.a
" 74 # Make sure the targets which have been exported in some other 76 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 77 foreach(_target "VTK::CommonCore
" "VTK::CommonExecutionModel
" "VTK::CommonDataModel
" "VTK::FiltersGeneral
" "VTK::FiltersCore
" "VTK::FiltersExtraction
" "VTK::ParallelCore
" ) 78 if(NOT TARGET "${_target}
" ) 79 set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}
") 83 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 84 if(CMAKE_FIND_PACKAGE_NAME) 85 set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE) 86 set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 88 message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}
") 91 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets) 93 # Commands beyond this point should not need to know the version. 94 set(CMAKE_IMPORT_FILE_VERSION)
