GeodesicMeasurement-targets.cmake
1 # Generated by CMake
5 endif()
6 cmake_policy(PUSH)
11
14
16 set(_targetsDefined)
17 set(_targetsNotDefined)
18 set(_expectedTargets)
19 foreach(_expectedTarget GeodesicMeasurement::GeodesicMeasurementFilters GeodesicMeasurement::FmmMesh)
23  endif()
26  endif()
27 endforeach()
29  unset(_targetsDefined)
30  unset(_targetsNotDefined)
31  unset(_expectedTargets)
33  cmake_policy(POP)
34  return()
35 endif()
39 unset(_targetsDefined)
40 unset(_targetsNotDefined)
41 unset(_expectedTargets)
42
43
44 # Create imported target GeodesicMeasurement::GeodesicMeasurementFilters
45 add_library(GeodesicMeasurement::GeodesicMeasurementFilters SHARED IMPORTED)
46
47 set_target_properties(GeodesicMeasurement::GeodesicMeasurementFilters PROPERTIES
48  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/GeodesicMeasurement/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters"
49  INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel"
50 )
51
52 # Create imported target GeodesicMeasurement::FmmMesh
53 add_library(GeodesicMeasurement::FmmMesh STATIC IMPORTED)
54
55 set_target_properties(GeodesicMeasurement::FmmMesh PROPERTIES
56  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/GeodesicMeasurement/Filters/FmmMesh;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/FmmMesh;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/FmmMesh/gw_core;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/FmmMesh/gw_geodesic;/builds/gitlab-kitware-sciviz-ci/Plugins/GeodesicMeasurement/Filters/FmmMesh/gw_maths"
57 )
58
59 # Import target "GeodesicMeasurement::GeodesicMeasurementFilters" for configuration "Debug"
60 set_property(TARGET GeodesicMeasurement::GeodesicMeasurementFilters APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG)
61 set_target_properties(GeodesicMeasurement::GeodesicMeasurementFilters PROPERTIES
62  IMPORTED_LINK_DEPENDENT_LIBRARIES_DEBUG "VTK::CommonCore;VTK::CommonDataModel;VTK::FiltersCore;VTK::FiltersModeling"
63  IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/GeodesicMeasurement/libvtkGeodesicMeasurementFilters.so"
64  IMPORTED_SONAME_DEBUG "libvtkGeodesicMeasurementFilters.so"
65  )
66
67 # Import target "GeodesicMeasurement::FmmMesh" for configuration "Debug"
68 set_property(TARGET GeodesicMeasurement::FmmMesh APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG)
69 set_target_properties(GeodesicMeasurement::FmmMesh PROPERTIES
70  IMPORTED_LINK_INTERFACE_LANGUAGES_DEBUG "CXX"
71  IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/GeodesicMeasurement/libFmmMesh.a"
72  )
73
74 # Make sure the targets which have been exported in some other
75 # export set exist.
76 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
77 foreach(_target "VTK::CommonExecutionModel" )
78  if(NOT TARGET "${_target}" )
79  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
80  endif()
81 endforeach()
82
83 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
84  if(CMAKE_FIND_PACKAGE_NAME)
85  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
86  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
87  else()
88  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
89  endif()
90 endif()
91 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
92
93 # Commands beyond this point should not need to know the version.
94 set(CMAKE_IMPORT_FILE_VERSION)
95 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
