LegacyGhostCellsGenerator-targets.cmake
1 # Generated by CMake
5 endif()
6 cmake_policy(PUSH)
11
14
16 set(_targetsDefined)
17 set(_targetsNotDefined)
18 set(_expectedTargets)
19 foreach(_expectedTarget LegacyGhostCellsGeneratorFilters LegacyGhostCellsGeneratorParallel)
23  endif()
26  endif()
27 endforeach()
29  unset(_targetsDefined)
30  unset(_targetsNotDefined)
31  unset(_expectedTargets)
33  cmake_policy(POP)
34  return()
35 endif()
39 unset(_targetsDefined)
40 unset(_targetsNotDefined)
41 unset(_expectedTargets)
42
43
44 # Create imported target LegacyGhostCellsGeneratorFilters
45 add_library(LegacyGhostCellsGeneratorFilters SHARED IMPORTED)
46
47 set_target_properties(LegacyGhostCellsGeneratorFilters PROPERTIES
48  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Filters;/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Filters"
49  INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel"
50 )
51
52 # Create imported target LegacyGhostCellsGeneratorParallel
53 add_library(LegacyGhostCellsGeneratorParallel SHARED IMPORTED)
54
55 set_target_properties(LegacyGhostCellsGeneratorParallel PROPERTIES
56  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Parallel;/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel"
57  INTERFACE_LINK_LIBRARIES "LegacyGhostCellsGeneratorFilters;VTK::CommonExecutionModel;VTK::CommonSystem;VTK::FiltersCore;VTK::FiltersGeneral;VTK::FiltersGeometry;VTK::ParallelMPI"
58 )
59
60 # Import target "LegacyGhostCellsGeneratorFilters" for configuration "Debug"
61 set_property(TARGET LegacyGhostCellsGeneratorFilters APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG)
62 set_target_properties(LegacyGhostCellsGeneratorFilters PROPERTIES
63  IMPORTED_LINK_DEPENDENT_LIBRARIES_DEBUG "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonMisc;VTK::ParallelCore"
64  IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorFilters.so"
65  IMPORTED_SONAME_DEBUG "libLegacyGhostCellsGeneratorFilters.so"
66  )
67
68 # Import target "LegacyGhostCellsGeneratorParallel" for configuration "Debug"
69 set_property(TARGET LegacyGhostCellsGeneratorParallel APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG)
70 set_target_properties(LegacyGhostCellsGeneratorParallel PROPERTIES
71  IMPORTED_LINK_DEPENDENT_LIBRARIES_DEBUG "VTK::CommonCore;VTK::CommonDataModel;VTK::CommonMisc;VTK::ParallelCore"
72  IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorParallel.so"
73  IMPORTED_SONAME_DEBUG "libLegacyGhostCellsGeneratorParallel.so"
74  )
75
76 # Make sure the targets which have been exported in some other
77 # export set exist.
78 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
79 foreach(_target "VTK::CommonExecutionModel" "VTK::CommonSystem" "VTK::FiltersCore" "VTK::FiltersGeneral" "VTK::FiltersGeometry" "VTK::ParallelMPI" )
80  if(NOT TARGET "${_target}" )
81  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
82  endif()
83 endforeach()
84
85 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
86  if(CMAKE_FIND_PACKAGE_NAME)
87  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
88  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
89  else()
90  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
91  endif()
92 endif()
93 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
94
95 # Commands beyond this point should not need to know the version.
96 set(CMAKE_IMPORT_FILE_VERSION)
97 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
