NonOrthogonalSource-targets.cmake
1 # Generated by CMake
5 endif()
6 cmake_policy(PUSH)
11
14
16 set(_targetsDefined)
17 set(_targetsNotDefined)
18 set(_expectedTargets)
19 foreach(_expectedTarget NonOrthogonalSource::vtkNonOrthogonalSources)
23  endif()
26  endif()
27 endforeach()
29  unset(_targetsDefined)
30  unset(_targetsNotDefined)
31  unset(_expectedTargets)
33  cmake_policy(POP)
34  return()
35 endif()
39 unset(_targetsDefined)
40 unset(_targetsNotDefined)
41 unset(_expectedTargets)
42
43
44 # Create imported target NonOrthogonalSource::vtkNonOrthogonalSources
45 add_library(NonOrthogonalSource::vtkNonOrthogonalSources SHARED IMPORTED)
46
47 set_target_properties(NonOrthogonalSource::vtkNonOrthogonalSources PROPERTIES
48  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/NonOrthogonalSource/Sources;/builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources"
49  INTERFACE_LINK_LIBRARIES "VTK::CommonExecutionModel;VTK::PythonUsed"
50 )
51
52 # Import target "NonOrthogonalSource::vtkNonOrthogonalSources" for configuration "Debug"
53 set_property(TARGET NonOrthogonalSource::vtkNonOrthogonalSources APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG)
54 set_target_properties(NonOrthogonalSource::vtkNonOrthogonalSources PROPERTIES
55  IMPORTED_LINK_DEPENDENT_LIBRARIES_DEBUG "ParaView::VTKExtensionsMisc;VTK::CommonCore;VTK::CommonDataModel;VTK::CommonMath;VTK::CommonTransforms;VTK::FiltersGeneral;VTK::ImagingCore"
56  IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/NonOrthogonalSource/libvtkNonOrthogonalSources.so"
57  IMPORTED_SONAME_DEBUG "libvtkNonOrthogonalSources.so"
58  )
59
60 # Make sure the targets which have been exported in some other
61 # export set exist.
62 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
63 foreach(_target "VTK::CommonExecutionModel" "VTK::PythonUsed" )
64  if(NOT TARGET "${_target}" )
65  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
66  endif()
67 endforeach()
68
69 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
70  if(CMAKE_FIND_PACKAGE_NAME)
71  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
72  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
73  else()
74  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
75  endif()
76 endif()
77 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
78
79 # Commands beyond this point should not need to know the version.
80 set(CMAKE_IMPORT_FILE_VERSION)
81 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
