3 if(
4 message(FATAL_ERROR
"CMake >= 2.6.0 required")
15 # Protect against multiple inclusion, which would fail when already imported targets are added once more.
17 set(_targetsNotDefined)
19 foreach(_expectedTarget ParaView::paraview)
20 list(APPEND _expectedTargets ${_expectedTarget})
21 if(NOT TARGET ${_expectedTarget})
22 list(APPEND _targetsNotDefined ${_expectedTarget})
24 if(TARGET ${_expectedTarget})
25 list(APPEND _targetsDefined ${_expectedTarget})
28 if("${_targetsDefined}
") 29 unset(_targetsDefined) 30 unset(_targetsNotDefined) 31 unset(_expectedTargets) 32 set(CMAKE_IMPORT_FILE_VERSION) 36 if(NOT "${_targetsDefined}
" STREQUAL "") 37 message(FATAL_ERROR "Some (but not all) targets in
this export
") 39 unset(_targetsDefined) 40 unset(_targetsNotDefined) 41 unset(_expectedTargets) 44 # Create imported target ParaView::paraview 45 add_executable(ParaView::paraview IMPORTED) 47 # Import target "ParaView::paraview
" for configuration "Debug
" 48 set_property(TARGET ParaView::paraview APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG) 49 set_target_properties(ParaView::paraview PROPERTIES 50 IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/bin/paraview
" 53 # This file does not depend on other imported targets which have 54 # been exported from the same project but in a separate export set. 56 # Commands beyond this point should not need to know the version. 57 set(CMAKE_IMPORT_FILE_VERSION)
