ParaViewIncubator-targets.cmake
1 # Generated by CMake
5 endif()
6 cmake_policy(PUSH)
11
14
16 set(_targetsDefined)
17 set(_targetsNotDefined)
18 set(_expectedTargets)
19 foreach(_expectedTarget ParaViewIncubator::Core)
23  endif()
26  endif()
27 endforeach()
29  unset(_targetsDefined)
30  unset(_targetsNotDefined)
31  unset(_expectedTargets)
33  cmake_policy(POP)
34  return()
35 endif()
39 unset(_targetsDefined)
40 unset(_targetsNotDefined)
41 unset(_expectedTargets)
42
43
44 # Create imported target ParaViewIncubator::Core
45 add_library(ParaViewIncubator::Core SHARED IMPORTED)
46
47 set_target_properties(ParaViewIncubator::Core PROPERTIES
48  INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/Incubator/Core;/builds/gitlab-kitware-sciviz-ci/Incubator/Core"
49  INTERFACE_LINK_LIBRARIES "VTK::CommonCore"
50 )
51
52 # Import target "ParaViewIncubator::Core" for configuration "Debug"
53 set_property(TARGET ParaViewIncubator::Core APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG)
54 set_target_properties(ParaViewIncubator::Core PROPERTIES
55  IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVIncubatorCore-pv5.13.so.5.13"
56  IMPORTED_SONAME_DEBUG "libvtkPVIncubatorCore-pv5.13.so.1"
57  )
58
59 # Make sure the targets which have been exported in some other
60 # export set exist.
61 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
62 foreach(_target "VTK::CommonCore" )
63  if(NOT TARGET "${_target}" )
64  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
65  endif()
66 endforeach()
67
68 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
69  if(CMAKE_FIND_PACKAGE_NAME)
70  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
71  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
72  else()
73  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
74  endif()
75 endif()
76 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
77
78 # Commands beyond this point should not need to know the version.
79 set(CMAKE_IMPORT_FILE_VERSION)
80 cmake_policy(POP)
#define VERSION
Definition: jconfigint.h:17
