3 if(
4 message(FATAL_ERROR
"CMake >= 2.6.0 required")
15 # Protect against multiple inclusion, which would fail when already imported targets are added once more.
17 set(_targetsNotDefined)
19 foreach(_expectedTarget ParaView::pvserver ParaView::pvdataserver ParaView::pvrenderserver ParaView::pvbatch ParaView::pvpython)
20 list(APPEND _expectedTargets ${_expectedTarget})
21 if(NOT TARGET ${_expectedTarget})
22 list(APPEND _targetsNotDefined ${_expectedTarget})
24 if(TARGET ${_expectedTarget})
25 list(APPEND _targetsDefined ${_expectedTarget})
28 if("${_targetsDefined}
") 29 unset(_targetsDefined) 30 unset(_targetsNotDefined) 31 unset(_expectedTargets) 32 set(CMAKE_IMPORT_FILE_VERSION) 36 if(NOT "${_targetsDefined}
" STREQUAL "") 37 message(FATAL_ERROR "Some (but not all) targets in
this export
") 39 unset(_targetsDefined) 40 unset(_targetsNotDefined) 41 unset(_expectedTargets) 44 # Create imported target ParaView::pvserver 45 add_executable(ParaView::pvserver IMPORTED) 47 # Create imported target ParaView::pvdataserver 48 add_executable(ParaView::pvdataserver IMPORTED) 50 # Create imported target ParaView::pvrenderserver 51 add_executable(ParaView::pvrenderserver IMPORTED) 53 # Create imported target ParaView::pvbatch 54 add_executable(ParaView::pvbatch IMPORTED) 56 # Create imported target ParaView::pvpython 57 add_executable(ParaView::pvpython IMPORTED) 59 # Import target "ParaView::pvserver
" for configuration "Debug
" 60 set_property(TARGET ParaView::pvserver APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG) 61 set_target_properties(ParaView::pvserver PROPERTIES 62 IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/bin/pvserver
" 65 # Import target "ParaView::pvdataserver
" 66 set_property(TARGET ParaView::pvdataserver APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG) 67 set_target_properties(ParaView::pvdataserver PROPERTIES 68 IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/bin/pvdataserver
" 71 # Import target "ParaView::pvrenderserver
" 72 set_property(TARGET ParaView::pvrenderserver APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG) 73 set_target_properties(ParaView::pvrenderserver PROPERTIES 74 IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/bin/pvrenderserver
" 77 # Import target "ParaView::pvbatch
" 78 set_property(TARGET ParaView::pvbatch APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG) 79 set_target_properties(ParaView::pvbatch PROPERTIES 80 IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch
" 83 # Import target "ParaView::pvpython
" 84 set_property(TARGET ParaView::pvpython APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG) 85 set_target_properties(ParaView::pvpython PROPERTIES 86 IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/bin/pvpython
" 89 # This file does not depend on other imported targets which have 90 # been exported from the same project but in a separate export set. 92 # Commands beyond this point should not need to know the version. 93 set(CMAKE_IMPORT_FILE_VERSION)
