This page documents at a very high level how to contribute to ParaView. Please check our developer instructions for a more detailed guide to developing and contributing to the project, and our ParaView Git README for additional information.
The ParaView development cycle is built upon the following components:
If you have a bug report or a feature request for ParaView, you can use the issues tracker to report a new issue.
To report an issue.
triage:needinfo label and add a comment for the reporter soliciting more information. Once the reporter has provided the necessary information, he/she should remove the triage:needinfo label from the issue to notify the development team.When a developer starts working on an issue, the developer will add the workflow:active-development label. Once the development is complete and the issue resolved, the issue will be closed, and the workflow:active-development label will be replaced by workflow:customer-review. At that point, the reporter can checkout the latest master and confirm that the issue has been addressed. If so, the reporter can remove the workflow:customer-review label. If the issue was not addressed then the reporter should reopen the issue or solicit more information from the developer by adding the triage:needinfo label.
To keep the number of open issues manageable, we will periodically expire old issues with no activity. Such issues will be closed and tagged with the label triage:expired. Such issues can be reopened if needed.
For every issue, project managers can assign:
project:... label to indicate which project this issue is necessary for. An issue may have multiple projects associated with it.priority:... label to indicate how critical is this issue for the specific milestone, ranging from priority:required, priority:important, priority:nice-to-have, and priority:low. Only one priority label makes sense at a time.For every issue, developers can assign:
area:... labels to indicate which area this issue relates to e.g. area:web, area:catalyst, etc.triage:... labels to indicate issue triage status. triage:confirmed is added when the issue has been confirmed. triage:easy is added for issues that are easy to fix. triage:feature is added to issues that are new feature requests. triage:needinfo is added to solicit more information from the reporter.triage:needinfo label on closed issues means the reporter or reviewer is requesting more information from the developer before the fix can be reviewed. Please provide such information and then remove the label.workflow:active-development label should be added to issues under development.Typically, one addresses issues by writing code. To start contributing to ParaView:
Create a local clone of the main ParaView repository. Optionally configure Git to use SSH instead of HTTPS. Then clone:
$ git clone --recursive https://gitlab.kitware.com/paraview/paraview.git ParaView $ cd ParaView
The main repository will be configured as your origin remote.
For more information see: Setup and download instructions
Run the developer setup script to prepare your ParaView work tree and create Git command aliases used below:
$ ./Utilities/SetupForDevelopment.sh
This will prompt for your GitLab user name and configure a remote called gitlab to refer to it. Choose the defaults for ParaView Data questions.
Edit files and create commits (repeat as needed):
$ edit file1 file2 file3 $ git add file1 file2 file3 $ git commit
Commit messages must be thorough and informative so that reviewers will have a good understanding of why the change is needed before looking at the code. Appropriately refer to the issue number, if applicable.
For more information see: Create a Topic
Push commits in your topic branch to your fork in GitLab:
$ git gitlab-push
For more information see: Share a Topic
Visit your fork in GitLab, browse to the "**Merge Requests**" link on the left, and use the "**New Merge Request**" button in the upper right to create a Merge Request.
For more information see: Create a Merge Request
Follow the review process to get your merge request reviewed and tested. On success, the merge-request can be merged and closed.
For more information see: Review a Merge Request
workflow:customer-review label to request a review from the reporter.triage:needinfo label additions to provide the customer with any details necessary to test the fix.We have a ParaView Discourse forum to coordinate development and to provide support.
1.8.13 on Fri Aug 1 2025
