This page documents how to develop ParaView using GitLab and Git. See the README for more information.
Git is an extremely powerful version control tool that supports many different "workflows" for individual development and collaboration. Here we document procedures used by the ParaView development community. In the interest of simplicity and brevity we do not provide an explanation of why we use this approach.
Before you begin, perform initial setup:
Follow the download instructions to create a local clone of the main ParaView repository.
$ git clone --recursive https://gitlab.kitware.com/paraview/paraview.git ParaView
The main repository will be configured as your origin
remote.
Run the developer setup script to prepare your ParaView work tree and create Git command aliases used below:
$ ./Utilities/SetupForDevelopment.sh
This will prompt for your GitLab username and configure a remote called gitlab
to refer to your fork. It will also setup a data directory for you. No need to do anything else.
This is a quick start guide so that you can start contributing to ParaView easily. To understand the process more deeply, you can jump to the workflow section.
Create a local branch for your changes:
Make the needed changes in ParaView and use git locally to create logically separated commits. There is no strict requirements regarding git commit messages syntax but a good rule of thumb to follow is: General domain: reason for change
, General domain being a class, a module , a specific system like build or CI.
Build ParaView following the guide and fix any build warnings or issues that arise and seems related to your changes.
If you are working on a change that is across both VTK and ParaView, you can work directly on the VTK that is inside your repository of ParaView. Just follow the steps in the VTK develop guide starting at the usage of SetupForDevelopment.sh
script.
You can then develop in the VTK directory as if it was any VTK repository, where you can make changes, commit and push to your VTK fork.
If you want to test the integration of your VTK changes in ParaView [continuous integration](continuous-integration), commit and push your changes to your VTK fork, then commit the VTK submodule update with your changes in a separate commit in your ParaView branch. Your VTK commit will be found without issue.
Once your VTK changes are merged into VTK master, you can cleanup your history and commit the submodule update cleanly like this (this will remove local non commited changes and also rebase your branch on the last master):
Every change and new features needs to be tested. In ParaView, there are mainly two types of tests. Python tests and XML tests. While both types of tests are as valid to add, XML tests should be preferred for standard feature tests when possible as they exercise the ParaView user interface as well as core features.
First, as XML tests are impacted by ParaView's user settings, it is recommanded to always run paraview
in dry run (option --dr
To add a XML test, use the Tools -> Record Test
menu in ParaView. After specifying name for the XML test, a new window named Recording User Input
will pop up. This one will record every action you will perfom in ParaView to test his feature.
It is also recommanded to lock the view size when we want to create a baseline, choose Tools -> Lock View Size Custom...
and set it to a 400x400 window as it works well.
On top of recording actions, the most important feature in this window is the check mark button which allows you to:
TESTS_WITH_INLINE_COMPARES
)Advanced features are:
Continuous Flush
: writes events to file as soon as they are recorded. Especially useful when user environment isn't stable.Record Interaction Timings
: record each pause between interactions as a pause event.It is also possible to stop the test recording by using the pause button and add comments in the XML test.
Finally, you can save the XML test by using the Stop recording
button.
You may need to edit this file slightly to make it work as expected, do not hesitate to look at other files.
Add the file to Client/ParaView/Testing/XML
folder and list it in one of the test.XXX.cmake
file. Those files are conditionally used, typically depending on a build option. Look at Client/ParaView/Testing/XML/CMakeLists.txt
to find the appropriate one. By default, tests should be added in test.common.cmake
There are different categories of tests depending on what you want to test :
DATA_WITH_BASELINES
: for general use case, in most of the case the safest bet is this category.TESTS_WITH_INLINE_COMPARES
: for when you need to do multiple image comparison.TESTS_WITHOUT_BASELINES
: in some context, a valid XML test can be made without baseline.You can then configure ParaView and run your test from the build directory and check that they pass:
To add a Python test, write a pvpython script testing the feature, add it in Client/ParaView/Testing/Python
folder and list it in Client/ParaView/Testing/Python/CMakeLists.txt
. There are different categories of tests, but the safest bet is probably the paraview_add_test_python
category.
Push your changes to the gitlab fork that you created in the initial setup stage:
If your test uses new data or baselines, you will need to add it to your fork. For data, add the file names to the list in the corresponding Clients/ParaView/Testing/Python/CMakeLists.txt
or Clients/ParaView/Testing/XML/test.common.cmake
and drop the files in Testing/Data/
. For baselines, just drop the file in Clients/ParaView/Testing/Data/Baseline/
and run the following commands from your build directory:
This will transform your files into .sha512 files. Check your test is passing by running from your build directory:
If it passes, add these .sha512 files and commit them, then push with:
Once you are happy with the state of your development on your fork, the next step is to create a merge request back into the main ParaView repository.
Open [](https://gitlab.kitware.com/username/paraview/-/merge_requests/new) in a browser, select your branch in the list and create a Merge Request against master.
In the description, write an informative explanation of your added features or bugfix. If there is an associated issue, link it with the #number
in the description.
Tag some ParaView maintainers in the description to ensure someone will see it, eg: .quammen, .boeckel or .
Once the MR is created, our gitlab robot will check multiple things and make automated suggestions. Please read them and try to follow the instructions. The two standard suggestions are related to formatting errors and adding markdown changelog.
To fix the formatting, just add a comment containing:
Then, once the robot has fixed the formatting, fetch the changes locally (this will remove any local changes to your branch)
To fix the changelog warning, create, add, commit and push a markdown (.md) file in Documentation/release/dev
folder. In this file, write a small markdown paragraph describing the development. See other .md files in this folder for examples. It may look like this:
Suggestions and best practices on writing the changelog can be found in the Documentation/release/dev/0-sample-topic.md
file. This is an optional step but recommended to do for any new feature and user facing issues.
ParaView maintainers and developers will review your MR by leaving comments on it. Try to follow their instructions and be patient. It can take a while to get a MR into mergeable form. This is a mandatory step, and it is absolutely normal to get change requests.
Review comments can be resolved, please resolve a comment once you've taken it into account and pushed related changes or once you've reached an agreement with the commenter that nothing should be changed.
Once a reviewer is happy with your changes, they will add a +X
comment. You need at least one +2
or higher to consider merging the MR. Two +1
s do not equal a +2
. If a reviewer leave a -1
comment, please discuss with them to understand what is the issue and how it could be fixed.
Once you have pushed new changes, please tag reviewers again so that they can take a look. If you do not tag reviewers, they may not know to revisit your changes. Do not hesitate to tag them and ask for help.
Before merging a MR, the ParaView continuous integration (CI) needs to run and be green. For CI to be functional, please read and follow this guide. It was written for VTK but is as valid for ParaView.
To run the CI:
Play all manual
arrows on top of the Build and Test stagesDo not hesitate to tag a ParaView developer for help if needed.
You then need to wait for CI to run, it can take a while, up to a full day.
A successful CI should be fully green. If that is so, then your MR is ready !
If not, you need to analyze the issues and fix them. Recover the failure information this way:
Click on the pipelines tab, then on the last status badge, then on the cdash-commit
job. It will take you to the related CDash report where you will find all information.
Everything in the CDash report should be green except the NotRun
and Time
column. Take a look into each issue and fix them locally. If there are issues in the pipeline but nothing is visible in the CDash, please ask a maintainer for help to figure out if anything should be done. You can always try to rerun the failed job by clicking on the arrow of the job in the pipeline.
Once you have fixed some issues locally, commit and push them to gitlab, run the CI again and tag reviewers again for follow-up reviews.
Once the MR has green CI and you have at least one +2
, you can ask for a merge. Before that please make sure that:
If that is not the case, please rebase on master using the following commands:
The interactive rebase will let you squash commits, reorganize commits and edit commit messages.
After the force push, make sure to run CI again.
Once all is done, tag a ParaView developer so that they can perform the merge command.
Congratulations ! You just contributed to ParaView !
ParaView development uses a branchy workflow based on topic branches. Our collaboration workflow consists of three main steps:
master
branch: $ git checkout master $ git pullall
master
to your fork in GitLab: $ git push gitlab masterto keep it in sync. The
git gitlab-push
script used to Share a Topic below will also do this.All new work must be committed on topic branches. Name topics like you might name functions: concise but precise. A reader should have a general idea of the feature or fix to be developed given just the branch name. Additionally, it is preferred to have an issue associated with every topic. The issue can document the bug or feature to be developed. In such cases, being your topic name with the issue number.
To start a new topic branch:
$ git fetch origin
If there is an issue associated with the topic, assign the issue to yourself using the "**Assignee**" field, and add the workflow:active-development
label to it.
For new development, start the topic from origin/master
$ git checkout -b my-topic origin/master
For release branch fixes, start the topic from origin/release
, and by convention use a topic name starting in release-
$ git checkout -b release-my-topic origin/release
If subdmodules may have changed, the run:
$ git submodule update
Edit files and create commits (repeat as needed):
$ edit file1 file2 file3 $ git add file1 file2 file3 $ git commit
Caveats:
Commit messages must contain a brief description as the first line and a more detailed description of what the commit contains. If the commit contains a new feature, the detailed message must describe the new feature and why it is needed. If the commit contains a bug fix, the detailed message must describe the bug behavior, its underlying cause, and the approach to fix it. If the bug is described in the bug tracker, the commit message must contain a reference to the bug number.
Update a submodule if needed
If you need to update a submodule (eg: VTK) in order to access a specific bugfix or features, first make sure that the needed developments have been merged into the main branch of the submodule. You can then use the command:
$ git bump my-submodule my-hash-or-branch
my-submodule
being the submodule folder (eg: VTK), my-hash-or-branch
being either a hash or a branch provided by any of your remote or your local repository, typically, origin/master
This will add a new commit which update the submodule and prefill the commit message with information about the different commits in the submodule. Make sure to still add some information about the reason for the bump.
Please note you can run CI on a submodule commit in another remote, see [continuous integration] for more info.
Add some tests
Every changes and new features need to be tested in ParaView. Depending on what you implement, you can perform an image comparison with a baseline of expected result or checking a property at anytime.
They are mainly 2 types of test in ParaView, python and XML testing. Generally we use a XML test, for more details regarding this topic, it's highly recommanded to check this section.
Add release notes
Notable changes should create a new file in Documentation/release/dev/
named my-topic.md
(replace my-topic
with the name of your topic). This is not necessary for branches which are "trivial" such as fixing typos, updating test baselines, or are developer-oriented.
When a topic is ready for review and possible inclusion, share it by pushing to a fork of your repository in GitLab. Be sure you have registered and signed in for GitLab Access and created your fork by visiting the main ParaView GitLab repository page and using the "Fork" button in the upper right.
$ git checkout my-topic
$ git prepush
Push commits in your topic branch to your fork in GitLab:
$ git gitlab-push
Notes:
-f
or --force
to overwrite the destination.gitlab-push
script also pushes the master
branch to your fork in GitLab to keep it in sync with the upstream master
.The output will include a link to the topic branch in your fork in GitLab and a link to a page for creating a Merge Request.
(If you already created a merge request for a given topic and have reached this step after revising it, skip to the next step.)
Visit your fork in GitLab, browse to the "**Merge Requests**" link on the left, and use the "**New Merge Request**" button in the upper right to reach the URL printed at the end of the previous step. It should be of the form:
https://gitlab.kitware.com/<username>/paraview/-/merge_requests/new
Follow these steps:
<username>/paraview
repository and the my-topic
branch.In the "**Target branch**" box select the paraview/paraview
repository and the master
branch. It should be the default.
If your change is a fix for the release
branch, you should still select the master
branch as the target because the change needs to end up there too.
In the "**Title**" field provide a one-line summary of the entire topic. This will become the title of the Merge Request.
Example Merge Request Title:
Wrapping: Add Java 1.x support
In the "**Description**" field provide a high-level description of the change the topic makes and any relevant information about how to try it.
@username
syntax to draw attention of specific developers. This syntax may be used anywhere outside literal text and code blocks. Or, wait until the next step and add comments to draw attention of developers.release
branch, indicate this so that a maintainer knows it should be merged to release
.message
to specify text to be included in the generated merge commit message when the topic is merged.Example Merge Request Description:
This branch requires Java 1.x which is not generally available yet. Get Java 1.x from ... in order to try these changes. ```message Add support for Java 1.x to the wrapping infrastructure. ``` Cc: @user1 @user2
For guidelines with respect to licensing, naming conventions, code formatting, documentation and further, please check guidelines
Add comments mentioning specific developers using @username
syntax to draw their attention and have the topic reviewed. After typing @
and some text, GitLab will offer completions for developers whose real names or user names match.
Comments use GitLab Flavored Markdown for formatting. See GitLab documentation on Special GitLab References to add links to things like merge requests and commits in other repositories.
When a merge request is ready for review, developers can use the triage:ready-for-review
to indicate the same to the reviewers. If reviewers deems that it needs more work, they can add the triage:needswork
label. This can be repeated as many times as needed adding/removing labels as appropriate.
If a merge request is waiting on dashboards, use the triage:pending-dashboards
label.
Reviewers may add comments providing feedback or to acknowledge their approval.
If a reviewer raises an issue via a thread, the contributor may resolve the thread if the solution is indisputable. In case of cited lines within the issue, the corresponding changes of the commit prior to a comment are shown. So it is better to first push the change and then comment/resolve. When code is cited, the last line is usually the line of interest, the above lines just provide the context. Providing a comment just saying 'done' is unnecessary as GitLab will indicate that the relevant code has changed.
It shall be a common goal for reviewers and contributors to limit the amount of generated emails. Therefore reviewers are encouraged to comment systematic issues (e.g. missing this->
) only once but to indicate the general application. Contributors do not need to comment on trivial fixes (e.g. typos in comments) but may simply solved the threads after fixing.
To raise the attention of individuals, e.g. a reviewer for another round of review, this person can be pinged by addressing via @
in a comment.
Lines of specific forms will be extracted during merging and included as trailing lines of the generated merge commit message:
The leading line of a comment may optionally be exactly one of the following votes followed by nothing but whitespace before the end of the line:
-1
or :-1:
indicates "the change is not ready for integration".+1
or :+1:
indicates "I like the change". This adds an Acked-by:
trailer to the merge commit message.+2
indicates "the change is ready for integration". This adds a Reviewed-by:
trailer to the merge commit message.+3
indicates "I have tested the change and verified it works". This adds a Tested-by:
trailer to the merge commit message.The middle lines of a comment may be free-form GitLab Flavored Markdown.
Zero or more trailing lines of a comment may each contain exactly one of the following votes followed by nothing but whitespace before the end of the line:
Rejected-by: me
means "The change is not ready for integration."Acked-by: me
means "I like the change but defer to others."Reviewed-by: me
means "The change is ready for integration."Tested-by: me
means "I have tested the change and verified it works."Each me
reference may instead be an @username
reference or a full Real Name <user@domain>
reference to credit someone else for performing the review. References to me
and @username
will automatically be transformed into a real name and email address according to your GitLab account profile.
One may fetch the changes associated with a merge request by using the git fetch
command line shown at the top of the Merge Request page. It is of the form:
$ git fetch https://gitlab.kitware.com/$username/paraview.git $branch
This updates the local FETCH_HEAD
to refer to the branch.
There are a few options for checking out the changes in a work tree:
$ git checkout FETCH_HEAD -b $branchor checkout the commit without creating a local branch:
$ git cherry-pick ..FETCH_HEAD
The "Kitware Robot" automatically performs basic checks including clang-format on the commits and adds a comment acknowledging or rejecting the topic. This will be repeated automatically whenever the topic is pushed to your fork again.
Automatic formatting can be triggered by adding a comment with a single line.
Do: reformat
A re-check may be explicitly requested by
Do: check
A topic cannot be merged until the automatic review succeeds. It is necessary to correct the specific commit via rebase.
ParaView uses https://gitlab.kitware.com/help/ci/README.md "GitLab CI" to test merge requests, configured by the top-level .gitlab-ci.yml
file. Results may be seen both on the merge request's pipeline page and on the ParaView CDash Page. Filtered CDash results showing just the pipeline's jobs can be reached by selecting the cdash-commit
job in the External
stage of the pipeline. Note that due to GitLab changes, the External
stage may be in a separate pipeline for the same commit.
Lint build jobs run automatically after every push. Actual CI jobs require a manual trigger to run:
git bump
when performing the actual submodule update.ParaView GitLab Project Developers may trigger CI on a merge request by adding a comment with a command among the comment trailing lines:
Do: test
@kwrobot
will add an award emoji to the comment to indicate that it was processed and also trigger all manual jobs in the merge request's pipeline.
The Do: test
command accepts the following arguments:
--named <regex>
, -n <regex>
: Trigger jobs matching <regex>
anywhere in their name. Job names may be seen on the merge request's Pipelines tab.--stage <stage>
, -s <stage>
: Only affect jobs in a given stage. Stage names may be seen on the merge request's Pipelines tab. Note that the names are determined by what is in the .gitlab-ci.yml
file and may be capitalized in the web page, so lowercasing the webpage's display name for stages may be required.--action <action>
, -a <action>
: The action to perform on the jobs. Possible actions:manual
(the default): Start jobs awaiting manual interaction.unsuccessful
: Start or restart jobs which have not completed successfully.failed
: Restart jobs which have completed, but without success.completed
: Restart all completed jobs.If the merge request topic branch is updated by a push, a new manual trigger using one of the above methods is needed to start CI again. Currently running jobs will generally be canceled automatically.
Before the merge, all the jobs must be run and reviewed, see below.
If you have any question about the CI process, do not hesitate to ask a CI maintainer:
Reading CI results is a very important part of the merge request process and is the responsibility of the author of the merge request, although reviewers can usually help. There are two locations to read the results, GitLab CI and CDash. Both should be checked and considered clean before merging.
To read GitLab CI result, click on the Pipelines tab then on the last pipeline. It is expected to be fully green. If there is a yellow warning job, please consult CDash. If there is a red failed job, click on it to see the reason for the failure. It should clearly appears on the bottom of the log. Possible failures are:
To read the CDash results, on the job page, click on the "cdash-commit" external job which will open the commit-specific CDash page. Once it is open, make sure to show "All Build" at the bottom left of the page. CDash results display error, warnings, and test failures for all the jobs. It is expected to be green except for the "NoRun" and "Test Timings" categories, which can be ignored.
To check the history of a failing test, on the test page, click on the "Summary" link to see a summary of the test for the day, then click on the date controls on the top of the page to go back in time. If the test fails on other MRs or on master, this is probably a flaky test, currently in the process of being fixed or excluded. A flaky test can be ignored.
As a reminder, here is our current policy regarding CI results. All the jobs must be run before merging. Configure warnings and errors are not acceptable to merge and must be fixed. Build warning and errors are not acceptable to merge and must be fixed. Testing failure should be fixed before merging but can be accepted if a flaky test has been clearly identified.
If a topic is approved during GitLab review, skip to the next step. Otherwise, revise the topic and push it back to GitLab for another review as follows:
To revise the 3
rd commit back on the topic:
$ git rebase -i HEAD~3
(Substitute the correct number of commits back, as low as 1
.) Follow Git's interactive instructions.
Once review has concluded that the MR topic is ready for integration (at least one +2
), authorized developers may add a comment with a single trailing line:
Do: merge
to ask that the change be merged into the upstream repository. By convention, do not request a merge if any -1
or Rejected-by:
review comments have not been resolved and superseded by at least +1
or Acked-by:
review comments from the same user.
Developers are encouraged to merge their own merge requests on review. However, please do not merge unless you are available to address any dashboard issues that may arise. Developers who repeatedly ignore dashboard issues following their merges may loose developer privileges to the repository temporarily (or permanently)!
If the merge succeeds the topic will appear in the upstream repository master
branch and the Merge Request will be closed automatically. Any issues associated with the Merge Request will generally get closed automatically. If not, the developer merging the changes should close such issues and add a workflow:customer-review
tag to the issue(s) addressed by the change. Reporters and testers can then review the fix. Try to add enough information to the Issue or the Merge Request to indicate how to test the functionality if not obvious from the original Issue.
If the merge fails (likely due to a conflict), a comment will be added describing the failure. In the case of a conflict, fetch the latest upstream history and rebase on it:
$ git fetch origin $ git rebase origin/master
(If you are fixing a bug in the latest release then substitute origin/release
for origin/master
Return to the above step to share the revised topic.
After a topic has been merged upstream the Merge Request will be closed. Now you may delete your copies of the branch.
my-topic
branch from your fork in GitLab.master
Delete the local topic branch:
$ git branch -d my-topic
The branch -d
command works only when the topic branch has been correctly merged. Use -D
instead of -d
to force the deletion of an unmerged topic branch (warning - you could lose commits).
If you have any VTK changes, then you are required to get your changes incorporated into VTK using VTK's development workflow. Once your VTK topic has been approved and merged into VTK, then:
$ cd VTK $ git checkout master $ cd .. $ git add VTK $ git commit
