3 "With PARAVIEW_SSH_SERVERS_TESTING, to have the SSH Server tests pass, make sure that this machine has its own ssh public key as an authorized_keys and that 127.0.0.1 is in the known_hosts file, /usr/bin/xterm is available. In case of failing tests, pvserver logs are available in ${CMAKE_CURRENT_BINARY_DIR}/sshServer.log")
6 "${CMAKE_CURRENT_SOURCE_DIR}/server.sh.in" 7 "${CMAKE_CURRENT_BINARY_DIR}/tmp/server.sh" @ONLY)
9 "${CMAKE_CURRENT_SOURCE_DIR}/server_rc.sh.in" 10 "${CMAKE_CURRENT_BINARY_DIR}/tmp/server_rc.sh" @ONLY)
13 COPY ${CMAKE_CURRENT_BINARY_DIR}/tmp/server.sh
14 DESTINATION ${CMAKE_CURRENT_BINARY_DIR}
15 FILE_PERMISSIONS OWNER_READ OWNER_WRITE OWNER_EXECUTE GROUP_READ GROUP_EXECUTE WORLD_READ WORLD_EXECUTE
19 COPY ${CMAKE_CURRENT_BINARY_DIR}/tmp/server_rc.sh
20 DESTINATION ${CMAKE_CURRENT_BINARY_DIR}
21 FILE_PERMISSIONS OWNER_READ OWNER_WRITE OWNER_EXECUTE GROUP_READ GROUP_EXECUTE WORLD_READ WORLD_EXECUTE
25 "${CMAKE_CURRENT_SOURCE_DIR}/sshServers.pvsc.in" 26 "${CMAKE_CURRENT_BINARY_DIR}/sshServers.pvsc" @ONLY)
30 SimpleSSHServerAskPass
31 SimpleSSHServerTermExec
33 SSHServerPortForwarding
34 RCSSHServerPortForwarding
37 foreach(tname IN LISTS ssh_server_tests)
40 "${CMAKE_CURRENT_BINARY_DIR}/${tname}.xml" @ONLY)
42 list(APPEND TESTS_WITHOUT_BASELINES
43 ${CMAKE_CURRENT_BINARY_DIR}/${tname}.xml)
44 set(${tname}_DISABLE_CS TRUE)
45 set(${tname}_DISABLE_CRS TRUE)
46 # The SSH tests should not be run in parallel to avoid port collision
47 set(${tname}_FORCE_SERIAL TRUE)
