1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/Python
45 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/Python/fv_coprocess.py")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "python" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.13/site-packages" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/Python/se_coprocess.py")
51 endif()
52
