4 This file is used by CMake when finding VTK. It provides the [VTK module
5 API][] as well as some VTK-specific APIs.
7 The following variables are provided by
this module:
13 * `VTK_AVAILABLE_COMPONENTS`: Components available with VTK.
14 * `VTK_PREFIX_PATH`: Install prefix
for VTK.
17 * `VTK_HAS_VTKm: [Deprecated, use VTK_HAS_VISKORES] If VTK provides VTK-m. 18 * `VTK_HAS_VISKORES`: If VTK provides Viskores. 19 * `VTK_OPENGL_HAS_EGL`: If VTK can use EGL for OpenGL context. 20 * `VTK_USE_X`: If VTK uses X windows. 21 * `VTK_USE_COCOA`: If VTK uses Cocoa (only present on APPLE systems). 22 * `VTK_PYTHON_VERSION`: The major version of Python used by VTK. Empty if 23 Python support is not available. 24 * `VTK_WRAP_PYTHON`: If VTK itself provides Python wrapping. If so, the 25 Python parts of the module API are available. 26 * `VTK_WRAP_JAVA`: If VTK itself provides Java wrapping. If so, the 27 Java parts of the module API are available. 28 * `VTK_WRAP_SERIALIZATION`: If VTK itself provides serialization wrappings 29 for marshallable classes in modules with `INCLUDE_MARSHAL`. 30 * `VTK_PYTHONPATH`: Where VTK's Python modules live inside the install
31 prefix. Unset
if Python is not available.
32 * `VTK_LIBRARIES`: The list of modules specified by `COMPONENTS` and
33 `OPTIONAL_COMPONENTS`. However,
if no components are specified, all
34 available components are added to
this variable. This may be used in
35 `MODULES` arguments in the API (e.g., `vtk_module_autoinit`). All modules
36 are also targets and may be linked to
using `target_link_libraries`.
37 * `VTK_AUTOINIT_INCLUDE`: The header to include
for access to VTK
's autoinit 39 * `VTK_QT_VERSION`: The major version of Qt used by VTK if Qt support enabled. 40 * `VTK_QML_DIR`: Where VTK's QML plugins live
if QML support is
enabled.
41 * `VTK_ENABLE_VR_COLLABORATION`: Is VR collaboration
enabled when VR is
enabled.
42 * `VTK_SMP_BACKENDS`: The list of available SMP backends.
44 For more information about the Python in use by VTK, (note that the `Python`
45 component must be found to guarantee that
this happens), see the
46 [FindPython3][] documentation
for what is available. Of particular use are
49 - the `Python3_VERSION` variable; and
50 - the `Python3::Python`
target.
56 if (CMAKE_VERSION VERSION_LESS
"3.12")
57 set(
"${CMAKE_FIND_PACKAGE_NAME}_FOUND" 0)
58 set(
"${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE" 59 "VTK requires CMake 3.12 in order to reliably be used.")
66 set("${CMAKE_FIND_PACKAGE_NAME}_AVAILABLE_COMPONENTS
" "WrappingTools;WebPython;WebCore;WebGLExporter;PythonInterpreter;ViewsContext2D;ViewsCore;RenderingUI;loguru;cli11;TestingRendering;ImagingColor;TestingDataModel;TestingCore;SerializationManager;RenderingVolumeAMR;RenderingVolumeOpenGL2;RenderingParallelLIC;RenderingParallel;RenderingVRModels;RenderingMatplotlib;RenderingLabel;octree;RenderingLICOpenGL2;RenderingGridAxes;RenderingContextOpenGL2;RenderingCellGrid;ImagingMath;ParallelMPI4Py;mpi4py;ImagingFourier;IOXdmf2;IOXMLParser;libxml2;
xdmf2;IOVeraOut;IOVPIC;vpic;IOTecplotTable;utf8;IOTRUCHAS;IOSegY;IOParallelXML;IOParallelNetCDF;IOParallelLSDyna;IOLSDyna;IOParallelExodus;IOExodus;exodusII;IOPLY;IOPIO;IOOggTheora;theora;ogg;IOOMF;IONetCDF;IOParallel;IOMPIImage;IOLANLX3D;IOImport;IOIOSS;ioss;IOHDF;IOHDFTools;IOH5part;h5part;IOH5Rage;IOFLUENTCFF;IOMovie;IOFDS;IOInfovis;InfovisCore;IOExportGL2PS;RenderingGL2PSOpenGL2;gl2ps;png;netcdf;IOEnSight;IOERF;IOCityGML;IOChemistry;IOCatalystConduit;catalyst;IOCONVERGECFD;IOCGNSReader;cgns;IOAvmesh;IOAsynchronous;IOExport;RenderingVtkJS;IOGeometry;RenderingSceneGraph;jsoncpp;IOAMR;hdf5;GeovisCore;libproj;sqlite;InteractionWidgets;RenderingVolume;RenderingAnnotation;InteractionStyle;ImagingHybrid;FiltersTensor;FiltersPython;FiltersProgrammable;FiltersPoints;FiltersParallelVerdict;FiltersParallelStatistics;FiltersParallelGeometry;FiltersParallelFlowPaths;FiltersParallelDIY2;ParallelDIY;FiltersTemporal;FiltersImaging;ImagingGeneral;FiltersGeometryPreview;FiltersGeneric;FiltersFlowPaths;eigen;FiltersAMR;FiltersParallelMPI;FiltersParallel;FiltersTexture;FiltersModeling;ParallelMPI;mpi;DomainsChemistryOpenGL2;RenderingOpenGL2;RenderingHyperTreeGrid;x11;glad;FiltersHybrid;DomainsChemistry;WrappingPythonCore;Python;ChartsCore;FiltersExtraction;diy2;IOXML;expat;ParallelCore;IOLegacy;IOCellGrid;FiltersCellGrid;token;FiltersStatistics;FiltersHyperTree;ImagingSources;IOImage;DICOMParser;jpeg;metaio;tiff;IOCore;lzma;fast_float;lz4;RenderingContext2D;RenderingFreeType;freetype;kwiml;zlib;RenderingCore;FiltersSources;CommonColor;AcceleratorsVTKmFilters;AcceleratorsVTKmCore;AcceleratorsVTKmDataModel;ImagingCore;FiltersGeneral;FiltersVerdict;verdict;FiltersGeometry;CommonComputationalGeometry;FiltersCore;FiltersReduction;CommonExecutionModel;vtkviskores;CommonDataModel;pegtl;pugixml;CommonSystem;CommonMisc;exprtk;CommonTransforms;CommonMath;kissfft;CommonCore;scn;
vtksys;nlohmannjson;fmt;WrapHierarchy;WrapPython;WrapPythonInit;ParseJava;WrapJava
") 68 set(_vtk_temp_variables) 69 set(_vtk_real_components) 70 foreach (_vtk_component IN LISTS "${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS
") 71 # Handle component requests that are not VTK. 72 if (NOT _vtk_component IN_LIST "${CMAKE_FIND_PACKAGE_NAME}_AVAILABLE_COMPONENTS
") 73 set("${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
" 0) 74 list(APPEND "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_NOT_FOUND_MESSAGE
" 75 "The ${_vtk_component}
component is not recognized.
") 77 if (_vtk_component MATCHES "^
vtk" AND 78 NOT _vtk_component STREQUAL "vtksys" AND 79 NOT _vtk_component STREQUAL "vtkjava
") 80 string(SUBSTRING "${_vtk_component}
" 3 -1 _vtk_actual_component) 81 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_FIND_VERSION) 82 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_FIND_QUIETLY) 85 "'${_vtk_actual_component}'") 87 elseif (${CMAKE_FIND_PACKAGE_NAME}_FIND_VERSION VERSION_LESS "8.90
") 88 # Ignore for compatibility. 92 "'${_vtk_actual_component}'. By requesting at least
version 8.90, the
" 95 list(APPEND _vtk_real_components 96 "${_vtk_actual_component}
") 97 list(APPEND _vtk_temp_variables 98 "${CMAKE_FIND_PACKAGE_NAME}_FIND_REQUIRED_${_vtk_actual_component}
") 99 set("${CMAKE_FIND_PACKAGE_NAME}_FIND_REQUIRED_${_vtk_actual_component}
" 100 "${${CMAKE_FIND_PACKAGE_NAME}_FIND_REQUIRED_${_vtk_component}}
") 101 unset(_vtk_actual_component) 103 list(APPEND _vtk_real_components 107 unset(_vtk_component) 108 set("${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS
" 109 ${_vtk_real_components}) 110 unset(_vtk_real_components) 112 set("${CMAKE_FIND_PACKAGE_NAME}_CMAKE_MODULE_PATH_save
" "${CMAKE_MODULE_PATH}
") 113 list(INSERT CMAKE_MODULE_PATH 0 114 "${CMAKE_CURRENT_LIST_DIR}
") 116 set("${CMAKE_FIND_PACKAGE_NAME}_CMAKE_PREFIX_PATH_save
" "${CMAKE_PREFIX_PATH}
") 117 include("${CMAKE_CURRENT_LIST_DIR}/
vtk-prefix.cmake
") 118 set("${CMAKE_FIND_PACKAGE_NAME}_PREFIX_PATH
" 119 "${_vtk_module_import_prefix}
") 120 unset(_vtk_module_import_prefix) 121 list(INSERT CMAKE_PREFIX_PATH 0 122 "${${CMAKE_FIND_PACKAGE_NAME}_PREFIX_PATH}
") 124 set("${CMAKE_FIND_PACKAGE_NAME}_VERSION
" "9.5.20251209
") 125 set("${CMAKE_FIND_PACKAGE_NAME}_MAJOR_VERSION
" "9
") 126 set("${CMAKE_FIND_PACKAGE_NAME}_MINOR_VERSION
" "5
") 127 set("${CMAKE_FIND_PACKAGE_NAME}_BUILD_VERSION
" "20251209
") 128 set("${CMAKE_FIND_PACKAGE_NAME}_LEGACY_REMOVE
" "ON
") 129 set("${CMAKE_FIND_PACKAGE_NAME}_AUTOINIT_INCLUDE
"vtkAutoInit.h\"")
130 set(
"${CMAKE_FIND_PACKAGE_NAME}_SMP_BACKENDS" "STDThread;Sequential")
132 unset("${CMAKE_FIND_PACKAGE_NAME}_FOUND
") 133 set("${CMAKE_FIND_PACKAGE_NAME}_HAS_VISKORES
" "ON
") 134 set("${CMAKE_FIND_PACKAGE_NAME}_HAS_VTKm
" "ON
") 135 if (${CMAKE_FIND_PACKAGE_NAME}_HAS_VISKORES) 136 if (NOT "OFF
") # VTK_MODULE_USE_EXTERNAL_VTK_vtkviskores 137 find_package(Viskores 138 PATHS "${CMAKE_CURRENT_LIST_DIR}/
viskores" 140 if (NOT Viskores_FOUND) 141 set("${CMAKE_FIND_PACKAGE_NAME}_FOUND
" 0) 142 set("${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE
" "VTK
internal enabled Viskores cannot be founded
") 147 include("${CMAKE_CURRENT_LIST_DIR}/vtkCMakeBackports.cmake
") 148 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}-targets.cmake
") 149 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}-
vtk-module-properties.cmake
") 151 include("${CMAKE_CURRENT_LIST_DIR}/
vtk-find-package-helpers.cmake
" OPTIONAL) 153 # Ensure that the right OpenGL preference is in place when finding the OpenGL 155 if (0) # vtk_opengl_preference_set 156 if (DEFINED OpenGL_GL_PREFERENCE) 157 set("${CMAKE_FIND_PACKAGE_NAME}_OpenGL_GL_PREFERENCE_save
" "${OpenGL_GL_PREFERENCE}
") 159 set(OpenGL_GL_PREFERENCE "") 162 # Ensure that python is found based on location, not on version 163 # See https://cmake.org/cmake/help/latest/module/FindPython.html 164 if (DEFINED Python3_FIND_STRATEGY) 165 set("${CMAKE_FIND_PACKAGE_NAME}_Python3_FIND_STRATEGY_save
" "${Python3_FIND_STRATEGY}
") 167 set(Python3_FIND_STRATEGY LOCATION) 169 # Ensures that the OpenGL::GLES3 is found. 170 include("${CMAKE_CURRENT_LIST_DIR}/vtkMobileDevices.cmake
") 171 include("${CMAKE_CURRENT_LIST_DIR}/${CMAKE_FIND_PACKAGE_NAME}-
vtk-module-find-packages.cmake
") 173 if (0) # vtk_opengl_preference_set 174 if (DEFINED "${CMAKE_FIND_PACKAGE_NAME}_OpenGL_GL_PREFERENCE_save
") 175 set(OpenGL_GL_PREFERENCE "${${CMAKE_FIND_PACKAGE_NAME}_OpenGL_GL_PREFERENCE_save}
") 176 unset("${CMAKE_FIND_PACKAGE_NAME}_OpenGL_GL_PREFERENCE_save
") 178 unset(OpenGL_GL_PREFERENCE) 182 if (DEFINED "${CMAKE_FIND_PACKAGE_NAME}_Python3_FIND_STRATEGY_save
") 183 set(Python3_FIND_STRATEGY "${${CMAKE_FIND_PACKAGE_NAME}_Python3_FIND_STRATEGY_save}
") 184 unset("${CMAKE_FIND_PACKAGE_NAME}_Python3_FIND_STRATEGY_save
") 186 unset(Python3_FIND_STRATEGY) 189 set(VTK_OPENGL_HAS_EGL "ON
") 191 if (APPLE AND NOT APPLE_IOS) 192 set(VTK_USE_COCOA "OFF
") 195 if (TARGET VTK::RenderingVR) 196 set("${CMAKE_FIND_PACKAGE_NAME}_ENABLE_VR_COLLABORATION
" "") 199 if () # VTK_QT_VERSION 200 set("${CMAKE_FIND_PACKAGE_NAME}_QT_VERSION
" "") 204 set("${CMAKE_FIND_PACKAGE_NAME}_QML_DIR
" "${${CMAKE_FIND_PACKAGE_NAME}_PREFIX_PATH}/
") 207 include("${CMAKE_CURRENT_LIST_DIR}/vtkModule.cmake
") 208 include("${CMAKE_CURRENT_LIST_DIR}/vtkEncodeString.cmake
") 209 include("${CMAKE_CURRENT_LIST_DIR}/vtkHashSource.cmake
") 212 include("${CMAKE_CURRENT_LIST_DIR}/vtkModuleJson.cmake
") 214 set("${CMAKE_FIND_PACKAGE_NAME}_PYTHON_VERSION
" "3
") 215 set("${CMAKE_FIND_PACKAGE_NAME}_WRAP_PYTHON
" "ON
") 216 if (${CMAKE_FIND_PACKAGE_NAME}_WRAP_PYTHON) 217 include("${CMAKE_CURRENT_LIST_DIR}/VTKPython-targets.cmake
") 218 include("${CMAKE_CURRENT_LIST_DIR}/vtkmodules-
vtk-python-module-properties.cmake
") 219 include("${CMAKE_CURRENT_LIST_DIR}/vtkModuleWrapPython.cmake
") 220 set("${CMAKE_FIND_PACKAGE_NAME}_PYTHONPATH
" "lib64/python3.13/site-packages
") 223 set("${CMAKE_FIND_PACKAGE_NAME}_WRAP_JAVA
" "") 224 if (${CMAKE_FIND_PACKAGE_NAME}_WRAP_JAVA) 225 include("${CMAKE_CURRENT_LIST_DIR}/vtkModuleWrapJava.cmake
") 227 if () # VTK_JAVA_JOGL_COMPONENT 228 set(_vtk_find_jogl_args) 229 if (${CMAKE_FIND_PACKAGE_NAME}_FIND_QUIETLY) 230 list(APPEND _vtk_find_jogl_args QUIET) 232 find_package(JOGL ${_vtk_find_jogl_args}) 233 unset(_vtk_find_jogl_args) 236 include("${CMAKE_CURRENT_LIST_DIR}/VTKJava-targets.cmake
") 237 set("${CMAKE_FIND_PACKAGE_NAME}_vtkjava_FOUND
" 1) 239 set("${CMAKE_FIND_PACKAGE_NAME}_vtkjava_FOUND
" 0) 240 set("${CMAKE_FIND_PACKAGE_NAME}_vtkjava_NOT_FOUND_MESSAGE
" 241 "JOGL was not found
") 246 set("${CMAKE_FIND_PACKAGE_NAME}_WRAP_JAVASCRIPT
" "") 247 if (${CMAKE_FIND_PACKAGE_NAME}_WRAP_JAVASCRIPT) 248 include("${CMAKE_CURRENT_LIST_DIR}/VTKJavaScript-targets.cmake
") 249 include("${CMAKE_CURRENT_LIST_DIR}/vtkModuleWrapJavaScript.cmake
") 252 set("${CMAKE_FIND_PACKAGE_NAME}_WRAP_SERIALIZATION
" "ON
") 253 include("${CMAKE_CURRENT_LIST_DIR}/vtkModuleSerialization.cmake
") 255 set(_vtk_search_components 256 ${${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS}) 257 if (NOT _vtk_search_components) 258 set(_vtk_search_components 259 ${${CMAKE_FIND_PACKAGE_NAME}_AVAILABLE_COMPONENTS}) 261 list(REMOVE_ITEM _vtk_search_components 262 # These components need to always be requested explicitly since they are 264 WrapHierarchy;vtkbuild;vtkplatform;vtkpython;pvtkpython;WrapPython;WrapPythonInit;vtkjava;ParseJava;WrapJava;vtkWebAssemblyTestLinkOptions) 265 set(_vtk_components_to_check) 266 foreach (_vtk_component IN LISTS _vtk_search_components) 267 if (DEFINED "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
") 268 # It was already not-found (likely due to `find-package` failures). 269 elseif (TARGET "${CMAKE_FIND_PACKAGE_NAME}::${_vtk_component}
") 270 list(APPEND _vtk_components_to_check 273 set("${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
" 0) 274 list(APPEND "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_NOT_FOUND_MESSAGE
" 275 "The ${_vtk_component}
component is not available.
") 278 unset(_vtk_component) 279 unset(_vtk_search_components) 281 while (_vtk_components_to_check) 282 list(GET _vtk_components_to_check 0 _vtk_component) 283 list(REMOVE_AT _vtk_components_to_check 0) 284 if (DEFINED "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
") 285 # We've already made a determiniation. 289 get_property(_vtk_public_dependencies 290 TARGET "${CMAKE_FIND_PACKAGE_NAME}::${_vtk_component}
" 291 PROPERTY "INTERFACE_vtk_module_depends
") 292 get_property(_vtk_private_dependencies 293 TARGET "${CMAKE_FIND_PACKAGE_NAME}::${_vtk_component}
" 294 PROPERTY "INTERFACE_vtk_module_private_depends
") 295 get_property(_vtk_optional_dependencies 296 TARGET "${CMAKE_FIND_PACKAGE_NAME}::${_vtk_component}
" 297 PROPERTY "INTERFACE_vtk_module_optional_depends
") 298 set(_vtk_dependencies 299 ${_vtk_public_dependencies} 300 ${_vtk_private_dependencies}) 301 foreach (_vtk_optional_dependency IN LISTS _vtk_optional_dependencies) 302 if (TARGET "${_vtk_optional_dependency}
") 303 list(APPEND _vtk_dependencies 304 "${_vtk_optional_dependency}
") 307 unset(_vtk_public_dependencies) 308 unset(_vtk_private_dependencies) 309 unset(_vtk_optional_dependency) 310 unset(_vtk_optional_dependencies) 312 string(REPLACE "${CMAKE_FIND_PACKAGE_NAME}::
" "" _vtk_dependencies "${_vtk_dependencies}
") 313 set(_vtk_all_dependencies_checked TRUE) 314 foreach (_vtk_dependency IN LISTS _vtk_dependencies) 315 if (DEFINED "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_dependency}_FOUND
") 316 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_${_vtk_dependency}_FOUND) 317 set("${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
" 0) 318 list(APPEND "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_NOT_FOUND_MESSAGE
" 319 "Failed to find the ${_vtk_dependency}
component.
") 322 # Check its dependencies. 323 list(APPEND _vtk_components_to_check 324 "${_vtk_dependency}
") 325 set(_vtk_all_found FALSE) 328 if (NOT DEFINED "${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
") 329 if (_vtk_all_dependencies_checked) 330 set("${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND
" 1) 332 list(APPEND _vtk_components_to_check 336 unset(_vtk_all_dependencies_checked) 337 unset(_vtk_dependency) 338 unset(_vtk_dependencies) 340 unset(_vtk_component) 341 unset(_vtk_components_to_check) 343 set(_vtk_missing_components) 344 foreach (_vtk_component IN LISTS "${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS
") 345 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_${_vtk_component}_FOUND AND ${CMAKE_FIND_PACKAGE_NAME}_FIND_REQUIRED_${_vtk_component}) 346 list(APPEND _vtk_missing_components 351 if (_vtk_missing_components) 352 list(REMOVE_DUPLICATES _vtk_missing_components) 353 list(SORT _vtk_missing_components) 354 string(REPLACE ";
" _vtk_missing_components "${_vtk_missing_components}
") 355 set("${CMAKE_FIND_PACKAGE_NAME}_FOUND
" 0) 356 set("${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE
" 357 "Could not find the ${CMAKE_FIND_PACKAGE_NAME}
package with the following required components: ${_vtk_missing_components}.")
359 unset(_vtk_missing_components)
361 set("${CMAKE_FIND_PACKAGE_NAME}_LIBRARIES")
362 if (NOT DEFINED "${CMAKE_FIND_PACKAGE_NAME}_FOUND")
363 # If nothing went wrong, we've successfully found the package.
364 set("${CMAKE_FIND_PACKAGE_NAME}_FOUND" 1)
365 set(_vtk_found_components
366 ${${CMAKE_FIND_PACKAGE_NAME}_FIND_COMPONENTS})
367 if (NOT _vtk_found_components)
368 set(_vtk_found_components
369 ${${CMAKE_FIND_PACKAGE_NAME}_AVAILABLE_COMPONENTS})
371 list(REMOVE_ITEM _vtk_found_components
372 # These components need to always be requested explicitly since they are
374 WrapHierarchy;vtkbuild;vtkplatform;vtkpython;pvtkpython;WrapPython;WrapPythonInit;vtkjava;ParseJava;WrapJava;vtkWebAssemblyTestLinkOptions)
375 # Build the `_LIBRARIES` variable.
376 foreach (_vtk_component IN LISTS _vtk_found_components)
377 if (TARGET
"${CMAKE_FIND_PACKAGE_NAME}::${_vtk_component}")
378 list(APPEND
"${CMAKE_FIND_PACKAGE_NAME}_LIBRARIES" 379 "${CMAKE_FIND_PACKAGE_NAME}::${_vtk_component}")
382 unset(_vtk_component)
383 unset(_vtk_found_components)
386 set(CMAKE_PREFIX_PATH "${${CMAKE_FIND_PACKAGE_NAME}_CMAKE_PREFIX_PATH_save}
") 387 unset("${CMAKE_FIND_PACKAGE_NAME}_CMAKE_PREFIX_PATH_save
") 389 set(CMAKE_MODULE_PATH "${${CMAKE_FIND_PACKAGE_NAME}_CMAKE_MODULE_PATH_save}
") 390 unset("${CMAKE_FIND_PACKAGE_NAME}_CMAKE_MODULE_PATH_save
") 392 foreach (_vtk_temp_variable IN LISTS _vtk_temp_variables) 393 unset("${_vtk_temp_variable}
") 395 unset(_vtk_temp_variable) 396 unset(_vtk_temp_variables) 398 # Compatibility with old code. 399 if (NOT ${CMAKE_FIND_PACKAGE_NAME}_FIND_VERSION) 400 set(VTK_USE_FILE "${CMAKE_CURRENT_LIST_DIR}/
vtk-use-file-deprecated.cmake
") 401 elseif (${CMAKE_FIND_PACKAGE_NAME}_FIND_VERSION VERSION_LESS "8.90
") 402 set(VTK_USE_FILE "${CMAKE_CURRENT_LIST_DIR}/
vtk-use-file-compat.cmake
") 404 set(VTK_USE_FILE "${CMAKE_CURRENT_LIST_DIR}/
vtk-use-file-error.cmake
#define VTK_BUILD_VERSION
#define VTK_LEGACY_REMOVE
#define VTK_MINOR_VERSION
#define VTK_MAJOR_VERSION
