1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Clients/CommandLineExecutables 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/bin" TYPE FILE RENAME
"paraview.conf" FILES
"/builds/gitlab-kitware-sciviz-ci/build/Clients/CommandLineExecutables/CMakeFiles/paraview.conf.install")
50 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver
" AND 51 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver
") 53 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver
" 54 RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib
") 56 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/pvserver
") 57 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver
" AND 58 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver
") 60 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver
" 61 OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:
" 62 NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib
") 63 if(CMAKE_INSTALL_DO_STRIP) 64 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver
") 69 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime
" OR NOT CMAKE_INSTALL_COMPONENT) 70 include("/builds/gitlab-kitware-sciviz-ci/build/Clients/CommandLineExecutables/CMakeFiles/pvserver.dir/install-cxx-module-bmi-Release.cmake
" OPTIONAL) 73 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime
" OR NOT CMAKE_INSTALL_COMPONENT) 74 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver
" AND 75 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver
") 77 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver
" 78 RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib
") 80 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/pvdataserver
") 81 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver
" AND 82 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver
") 84 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver
" 85 OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:
" 86 NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib
") 87 if(CMAKE_INSTALL_DO_STRIP) 88 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver
") 93 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime
" OR NOT CMAKE_INSTALL_COMPONENT) 94 include("/builds/gitlab-kitware-sciviz-ci/build/Clients/CommandLineExecutables/CMakeFiles/pvdataserver.dir/install-cxx-module-bmi-Release.cmake
" OPTIONAL) 97 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime
" OR NOT CMAKE_INSTALL_COMPONENT) 98 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver
" AND 99 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver
") 101 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver
" 102 RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib
") 104 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/pvrenderserver
") 105 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver
" AND 106 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver
") 108 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver
" 109 OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:
" 110 NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib
") 111 if(CMAKE_INSTALL_DO_STRIP) 112 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver
") 117 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime
" OR NOT CMAKE_INSTALL_COMPONENT) 118 include("/builds/gitlab-kitware-sciviz-ci/build/Clients/CommandLineExecutables/CMakeFiles/pvrenderserver.dir/install-cxx-module-bmi-Release.cmake
" OPTIONAL) 121 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime
" OR NOT CMAKE_INSTALL_COMPONENT) 122 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch
" AND 123 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch
") 125 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch
" 126 RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib
") 128 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch
") 129 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch
" AND 130 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch
") 132 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch
" 133 OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:
" 134 NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib
") 135 if(CMAKE_INSTALL_DO_STRIP) 136 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch
") 141 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime
" OR NOT CMAKE_INSTALL_COMPONENT) 142 include("/builds/gitlab-kitware-sciviz-ci/build/Clients/CommandLineExecutables/CMakeFiles/pvbatch.dir/install-cxx-module-bmi-Release.cmake
" OPTIONAL) 145 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime
" OR NOT CMAKE_INSTALL_COMPONENT) 146 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython
" AND 147 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython
") 149 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython
" 150 RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib
") 152 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/pvpython
") 153 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython
" AND 154 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython
") 156 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython
" 157 OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:
" 158 NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib
") 159 if(CMAKE_INSTALL_DO_STRIP) 160 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython
") 165 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime
" OR NOT CMAKE_INSTALL_COMPONENT) 166 include("/builds/gitlab-kitware-sciviz-ci/build/Clients/CommandLineExecutables/CMakeFiles/pvpython.dir/install-cxx-module-bmi-Release.cmake
" OPTIONAL) 169 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 170 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE PROGRAM FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/paraview-config
") 173 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 174 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/ParaViewTools-targets.cmake
") 175 file(DIFFERENT _cmake_export_file_changed FILES 176 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/ParaViewTools-targets.cmake
" 177 "/builds/gitlab-kitware-sciviz-ci/build/Clients/CommandLineExecutables/CMakeFiles/Export/073b2a9b196d662e262a87a68654bd3c/ParaViewTools-targets.cmake
") 178 if(_cmake_export_file_changed) 179 file(GLOB _cmake_old_config_files "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/ParaViewTools-targets-*.cmake
") 180 if(_cmake_old_config_files) 181 string(REPLACE ";
" _cmake_old_config_files_text "${_cmake_old_config_files}
") 182 message(STATUS "Old export file \
"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/ParaViewTools-targets.cmake\" will be replaced. Removing files [${_cmake_old_config_files_text}].")
183 unset(_cmake_old_config_files_text)
184 file(REMOVE ${_cmake_old_config_files})
186 unset(_cmake_old_config_files)
188 unset(_cmake_export_file_changed)
190 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/CommandLineExecutables/CMakeFiles/Export/073b2a9b196d662e262a87a68654bd3c/ParaViewTools-targets.cmake
") 191 if(CMAKE_INSTALL_CONFIG_NAME MATCHES "^([Rr][Ee][Ll][Ee][Aa][Ss][Ee])$
") 192 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/CommandLineExecutables/CMakeFiles/Export/073b2a9b196d662e262a87a68654bd3c/ParaViewTools-targets-release.cmake
