1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Clients/ParaView 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
"/builds/gitlab-kitware-sciviz-ci/build/Clients/ParaView/Documentation/cmake_install.cmake")
50 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 51 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/paraview
" AND 52 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/paraview
") 54 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/paraview
" 55 RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib
") 57 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/paraview
") 58 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/paraview
" AND 59 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/paraview
") 61 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/paraview
" 62 OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:
" 63 NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib
") 64 if(CMAKE_INSTALL_DO_STRIP) 65 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/paraview
") 70 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 71 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin
" TYPE FILE RENAME "paraview.conf
" FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/ParaView/CMakeFiles/paraview.conf.install
") 74 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 75 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/ParaViewClient-targets.cmake
") 76 file(DIFFERENT EXPORT_FILE_CHANGED FILES 77 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/ParaViewClient-targets.cmake
" 78 "/builds/gitlab-kitware-sciviz-ci/build/Clients/ParaView/CMakeFiles/Export/lib64/cmake/paraview-5.13/ParaViewClient-targets.cmake
") 79 if(EXPORT_FILE_CHANGED) 80 file(GLOB OLD_CONFIG_FILES "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/ParaViewClient-targets-*.cmake
") 82 message(STATUS "Old export file \
"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/ParaViewClient-targets.cmake\" will be replaced. Removing files [${OLD_CONFIG_FILES}].")
83 file(REMOVE ${OLD_CONFIG_FILES})
87 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/ParaView/CMakeFiles/Export/lib64/cmake/paraview-5.13/ParaViewClient-targets.cmake
") 88 if("${CMAKE_INSTALL_CONFIG_NAME}
" MATCHES "^([Dd][Ee][Bb][Uu][Gg])$
") 89 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/ParaView/CMakeFiles/Export/lib64/cmake/paraview-5.13/ParaViewClient-targets-debug.cmake
") 93 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 94 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/applications
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/ParaView/org.paraview.ParaView.desktop
") 97 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 98 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/icons/hicolor/22x22/apps
" FILES "/builds/gitlab-kitware-sciviz-ci/Clients/ParaView/pvIcon-22x22.png
") 101 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 102 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/icons/hicolor/32x32/apps
" FILES "/builds/gitlab-kitware-sciviz-ci/Clients/ParaView/pvIcon-32x32.png
") 105 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 106 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/icons/hicolor/96x96/apps
" FILES "/builds/gitlab-kitware-sciviz-ci/Clients/ParaView/pvIcon-96x96.png
") 109 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 110 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/metainfo
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Clients/ParaView/org.paraview.ParaView.appdata.xml
") 113 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 114 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/paraview-5.13/xmls
" TYPE FILE FILES 115 "/builds/gitlab-kitware-sciviz-ci/Clients/ParaView/ParaViewFilters.xml
" 116 "/builds/gitlab-kitware-sciviz-ci/Clients/ParaView/ParaViewSources.xml
