1 # CMake generated Testfile for 2 # Source directory: /builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing 3 # Build directory: /builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst/Testing 5 # This file includes the relevant testing commands required for 6 # testing this directory and lists subdirectories to be tested as well. 7 add_test(Catalyst::WaveletMiniApp.ValidateChangingInput
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "20" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/ValidateChangingInput.py")
8 set_tests_properties(Catalyst::WaveletMiniApp.ValidateChangingInput PROPERTIES ENVIRONMENT
";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" TIMEOUT_AFTER_MATCH
"5;Couldn't find object" _BACKTRACE_TRIPLES
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;236;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;522;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;89;paraview_add_test;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;0;")
9 add_test(Catalyst::WaveletMiniApp.CatalystScriptCustomCallbackVerifier
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "20" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CatalystScriptCustomCallbackVerifier.py")
10 set_tests_properties(Catalyst::WaveletMiniApp.CatalystScriptCustomCallbackVerifier PROPERTIES ENVIRONMENT
11 add_test(Catalyst::WaveletMiniApp.package_test
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "20" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/package_test")
12 set_tests_properties(Catalyst::WaveletMiniApp.package_test PROPERTIES ENVIRONMENT
13 add_test(Catalyst::WaveletMiniApp.package_test_zip
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "20" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/package_test_zip.zip")
14 set_tests_properties(Catalyst::WaveletMiniApp.package_test_zip PROPERTIES ENVIRONMENT
15 add_test(Catalyst::WaveletMiniApp.LiveOnly
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "20" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/LiveOnly.py")
16 set_tests_properties(Catalyst::WaveletMiniApp.LiveOnly PROPERTIES ENVIRONMENT
17 add_test(Catalyst::WaveletMiniApp.repeated_pipeline
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "2" "--size" "21" "--script-version" "2" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/repeated_pipeline.py" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/repeated_pipeline.py")
18 set_tests_properties(Catalyst::WaveletMiniApp.repeated_pipeline PROPERTIES ENVIRONMENT
";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" PASS_REGULAR_EXPRESSION
"Importing 'repeated_pipeline' for 2-th time!" TIMEOUT_AFTER_MATCH
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;236;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;522;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;95;paraview_add_test;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;0;")
19 add_test(Catalyst::MPI::WaveletMiniApp.ValidateChangingInput
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "20" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/ValidateChangingInput.py")
20 set_tests_properties(Catalyst::MPI::WaveletMiniApp.ValidateChangingInput PROPERTIES ENVIRONMENT
";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" PROCESSORS
"2" TIMEOUT_AFTER_MATCH
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;236;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;537;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;106;paraview_add_test_mpi;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;0;")
21 add_test(Catalyst::MPI::WaveletMiniApp.CatalystScriptCustomCallbackVerifier
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "20" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CatalystScriptCustomCallbackVerifier.py")
22 set_tests_properties(Catalyst::MPI::WaveletMiniApp.CatalystScriptCustomCallbackVerifier PROPERTIES ENVIRONMENT
23 add_test(Catalyst::MPI::WaveletMiniApp.package_test
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "20" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/package_test")
24 set_tests_properties(Catalyst::MPI::WaveletMiniApp.package_test PROPERTIES ENVIRONMENT
25 add_test(Catalyst::MPI::WaveletMiniApp.package_test_zip
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "20" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/package_test_zip.zip")
26 set_tests_properties(Catalyst::MPI::WaveletMiniApp.package_test_zip PROPERTIES ENVIRONMENT
27 add_test(Catalyst::MPI::WaveletMiniApp.LiveOnly
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "20" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/LiveOnly.py")
28 set_tests_properties(Catalyst::MPI::WaveletMiniApp.LiveOnly PROPERTIES ENVIRONMENT
29 add_test(Catalyst::MPI::WaveletMiniApp.repeated_pipeline
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "2" "--size" "21" "--script-version" "2" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/repeated_pipeline.py" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/repeated_pipeline.py")
30 set_tests_properties(Catalyst::MPI::WaveletMiniApp.repeated_pipeline PROPERTIES ENVIRONMENT
"Importing 'repeated_pipeline' for 2-th time!" PROCESSORS
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;236;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;537;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;112;paraview_add_test_mpi;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;0;")
31 add_test(Catalyst::WaveletMiniApp::MultiplePipelines::Prepare
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-E" "remove_directory" "/builds/gitlab-kitware-sciviz-ci/build/Testing/Temporary/MultiplePipelines")
32 set_tests_properties(Catalyst::WaveletMiniApp::MultiplePipelines::Prepare PROPERTIES FIXTURES_SETUP
"Catalyst::WaveletMiniApp::MultiplePipelines::Prepare" _BACKTRACE_TRIPLES
"/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;139;add_test;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;0;")
33 add_test(Catalyst::WaveletMiniApp::MultiplePipelines::pipeline1.pipeline2
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--dr" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "10" "--size" "21" "--channel" "Wavelet1" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/pipeline1.py" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/pipeline2.py")
34 set_tests_properties(Catalyst::WaveletMiniApp::MultiplePipelines::pipeline1.pipeline2 PROPERTIES ENVIRONMENT
"PARAVIEW_OVERRIDE_EXTRACTS_OUTPUT_DIRECTORY=/builds/gitlab-kitware-sciviz-ci/build/Testing/Temporary/MultiplePipelines/;VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" FIXTURES_REQUIRED
"Catalyst::WaveletMiniApp::MultiplePipelines::Prepare" LABELS "ParaView" TIMEOUT_AFTER_MATCH
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;236;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;522;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;145;paraview_add_test;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;0;")
35 add_test(Catalyst::WaveletMiniApp::MultiplePipelines::Validate::pipeline1.pipeline2
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvpython" "--dr" "--" "-m" "paraview.tests.validate_extracts" "--name" "MultiplePipelines" "--root" "/builds/gitlab-kitware-sciviz-ci/build/Testing/Temporary/MultiplePipelines" "--baseline-dir" "/builds/gitlab-kitware-sciviz-ci/build/ExternalData/Clients/PythonCatalyst/Testing/Data/Baseline" "--temp-dir" "/builds/gitlab-kitware-sciviz-ci/build/Testing/Temporary" "--json" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/pipeline2.json")
36 set_tests_properties(Catalyst::WaveletMiniApp::MultiplePipelines::Validate::pipeline1.pipeline2 PROPERTIES DEPENDS
"Catalyst::WaveletMiniApp::MultiplePipelines::pipeline1.pipeline2" ENVIRONMENT
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;236;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;522;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;163;paraview_add_test;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;0;")
37 add_test(Catalyst::FileDriverMiniApp::Wavelet.ValidateChangingTime
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.filedriver_miniapp" "-g" "/builds/gitlab-kitware-sciviz-ci/build/ExternalData/Testing/Data/Wavelet/*.pvti" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/ValidateChangingTime.py")
38 set_tests_properties(Catalyst::FileDriverMiniApp::Wavelet.ValidateChangingTime PROPERTIES ENVIRONMENT
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;236;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;522;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;189;paraview_add_test;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;0;")
39 add_test(Catalyst::FileDriverMiniApp::Can.ValidateChangingTime
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.filedriver_miniapp" "-g" "/builds/gitlab-kitware-sciviz-ci/build/ExternalData/Testing/Data/can_vtm/*.vtm" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/ValidateChangingTime.py")
40 set_tests_properties(Catalyst::FileDriverMiniApp::Can.ValidateChangingTime PROPERTIES ENVIRONMENT
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;236;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;522;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;197;paraview_add_test;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;0;")
41 add_test(Catalyst::MPI::FileDriverMiniApp::Wavelet.ValidateChangingTime
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.filedriver_miniapp" "-g" "/builds/gitlab-kitware-sciviz-ci/build/ExternalData/Testing/Data/Wavelet/*.pvti" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/ValidateChangingTime.py")
42 set_tests_properties(Catalyst::MPI::FileDriverMiniApp::Wavelet.ValidateChangingTime PROPERTIES ENVIRONMENT
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;236;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;537;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;206;paraview_add_test_mpi;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;0;")
43 add_test(Catalyst::MPI::FileDriverMiniApp::Can.ValidateChangingTime
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--dr" "--sym" "--" "-m" "paraview.demos.filedriver_miniapp" "-g" "/builds/gitlab-kitware-sciviz-ci/build/ExternalData/Testing/Data/can_vtm/*.vtm" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/ValidateChangingTime.py")
44 set_tests_properties(Catalyst::MPI::FileDriverMiniApp::Can.ValidateChangingTime PROPERTIES ENVIRONMENT
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;236;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;537;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;214;paraview_add_test_mpi;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/CMakeLists.txt;0;")
