1 # CMake generated Testfile for 2 # Source directory: /builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy 3 # Build directory: /builds/gitlab-kitware-sciviz-ci/build/Clients/PythonCatalyst/Testing/Legacy 5 # This file includes the relevant testing commands required for 6 # testing this directory and lists subdirectories to be tested as well. 7 add_test(Catalyst::Legacy::WaveletMiniApp.cpimport
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/cpimport.py")
8 set_tests_properties(Catalyst::Legacy::WaveletMiniApp.cpimport PROPERTIES ENVIRONMENT
";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" TIMEOUT_AFTER_MATCH
"5;Couldn't find object" _BACKTRACE_TRIPLES
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;236;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;522;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;28;paraview_add_test;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;0;")
9 add_test(Catalyst::Legacy::WaveletMiniApp.cpprogrammablefilter
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/cpprogrammablefilter.py")
10 set_tests_properties(Catalyst::Legacy::WaveletMiniApp.cpprogrammablefilter PROPERTIES ENVIRONMENT
11 add_test(Catalyst::Legacy::WaveletMiniApp.TestInput
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/TestInput.py")
12 set_tests_properties(Catalyst::Legacy::WaveletMiniApp.TestInput PROPERTIES ENVIRONMENT
13 add_test(Catalyst::Legacy::WaveletMiniApp.PythonScriptTest
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/PythonScriptTest.py")
14 set_tests_properties(Catalyst::Legacy::WaveletMiniApp.PythonScriptTest PROPERTIES ENVIRONMENT
15 add_test(Catalyst::Legacy::WaveletMiniApp.CatalystLoadVTKmFilterPlugin
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CatalystLoadVTKmFilterPlugin.py")
16 set_tests_properties(Catalyst::Legacy::WaveletMiniApp.CatalystLoadVTKmFilterPlugin PROPERTIES ENVIRONMENT
17 add_test(Catalyst::Legacy::MPI::WaveletMiniApp.cpimport
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/cpimport.py")
18 set_tests_properties(Catalyst::Legacy::MPI::WaveletMiniApp.cpimport PROPERTIES ENVIRONMENT
";VTK_TESTING_IMAGE_COMPARE_METHOD=TIGHT_VALID" LABELS "ParaView" PROCESSORS
"2" TIMEOUT_AFTER_MATCH
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/share/cmake-3.29/Modules/ExternalData.cmake;356;add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;236;ExternalData_add_test;/builds/gitlab-kitware-sciviz-ci/CMake/ParaViewTesting.cmake;537;_paraview_add_tests;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;34;paraview_add_test_mpi;/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CMakeLists.txt;0;")
19 add_test(Catalyst::Legacy::MPI::WaveletMiniApp.cpprogrammablefilter
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/cpprogrammablefilter.py")
20 set_tests_properties(Catalyst::Legacy::MPI::WaveletMiniApp.cpprogrammablefilter PROPERTIES ENVIRONMENT
21 add_test(Catalyst::Legacy::MPI::WaveletMiniApp.TestInput
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/TestInput.py")
22 set_tests_properties(Catalyst::Legacy::MPI::WaveletMiniApp.TestInput PROPERTIES ENVIRONMENT
23 add_test(Catalyst::Legacy::MPI::WaveletMiniApp.PythonScriptTest
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/PythonScriptTest.py")
24 set_tests_properties(Catalyst::Legacy::MPI::WaveletMiniApp.PythonScriptTest PROPERTIES ENVIRONMENT
25 add_test(Catalyst::Legacy::MPI::WaveletMiniApp.CatalystLoadVTKmFilterPlugin
"/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv6.0" "--enable-bt" "--client-mpi" "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch" "--sym" "--" "-m" "paraview.demos.wavelet_miniapp" "-t" "4" "--size" "21" "-s" "/builds/gitlab-kitware-sciviz-ci/Clients/PythonCatalyst/Testing/Legacy/CatalystLoadVTKmFilterPlugin.py")
26 set_tests_properties(Catalyst::Legacy::MPI::WaveletMiniApp.CatalystLoadVTKmFilterPlugin PROPERTIES ENVIRONMENT
