1 # CMake generated Testfile for 2 # Source directory: /builds/gitlab-kitware-sciviz-ci/Examples 3 # Build directory: /builds/gitlab-kitware-sciviz-ci/build/Examples 5 # This file includes the relevant testing commands required for 6 # testing this directory and lists subdirectories to be tested as well. 7 add_test(ParaViewExample-Plugins/AddPQProxy
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/AddPQProxy" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
8 set_tests_properties(ParaViewExample-Plugins/AddPQProxy PROPERTIES SKIP_REGULAR_EXPRESSION
"Skipping example" _BACKTRACE_TRIPLES
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;80;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
9 add_test(ParaViewExample-Plugins/Autostart
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/Autostart" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
10 set_tests_properties(ParaViewExample-Plugins/Autostart PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;81;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
11 add_test(ParaViewExample-Plugins/ComplexPluginArchitecture
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/ComplexPluginArchitecture" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
12 set_tests_properties(ParaViewExample-Plugins/ComplexPluginArchitecture PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;82;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
13 add_test(ParaViewExample-Plugins/ContextMenu
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/ContextMenu" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
14 set_tests_properties(ParaViewExample-Plugins/ContextMenu PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;83;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
15 add_test(ParaViewExample-Plugins/DynamicInitializer
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/DynamicInitializer" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
16 set_tests_properties(ParaViewExample-Plugins/DynamicInitializer PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;84;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
17 add_test(ParaViewExample-Plugins/DockWidget
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/DockWidget" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
18 set_tests_properties(ParaViewExample-Plugins/DockWidget PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;85;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
19 add_test(ParaViewExample-Plugins/DockWidgetCustomProxy
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/DockWidgetCustomProxy" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
20 set_tests_properties(ParaViewExample-Plugins/DockWidgetCustomProxy PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;86;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
21 add_test(ParaViewExample-Plugins/ElevationFilter
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/ElevationFilter" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
22 set_tests_properties(ParaViewExample-Plugins/ElevationFilter PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;88;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
23 add_test(ParaViewExample-Plugins/GUIMyToolBar
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/GUIMyToolBar" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
24 set_tests_properties(ParaViewExample-Plugins/GUIMyToolBar PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;90;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
25 add_test(ParaViewExample-Plugins/LagrangianIntegrationModel
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/LagrangianIntegrationModel" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
26 set_tests_properties(ParaViewExample-Plugins/LagrangianIntegrationModel PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;91;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
27 add_test(ParaViewExample-Plugins/LiveSource
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/LiveSource" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
28 set_tests_properties(ParaViewExample-Plugins/LiveSource PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;92;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
29 add_test(ParaViewExample-Plugins/MyPNGReader
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/MyPNGReader" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
30 set_tests_properties(ParaViewExample-Plugins/MyPNGReader PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;93;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
31 add_test(ParaViewExample-Plugins/MyTiffWriter
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/MyTiffWriter" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
32 set_tests_properties(ParaViewExample-Plugins/MyTiffWriter PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;94;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
33 add_test(ParaViewExample-Plugins/OnLoadCheckCallback
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/OnLoadCheckCallback" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
34 set_tests_properties(ParaViewExample-Plugins/OnLoadCheckCallback PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;95;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
35 add_test(ParaViewExample-Plugins/OverrideXMLOnly
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/OverrideXMLOnly" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
36 set_tests_properties(ParaViewExample-Plugins/OverrideXMLOnly PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;96;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
37 add_test(ParaViewExample-Plugins/PropertyWidgets
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/PropertyWidgets" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
38 set_tests_properties(ParaViewExample-Plugins/PropertyWidgets PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;97;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
39 add_test(ParaViewExample-Plugins/PythonAlgorithm
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/PythonAlgorithm" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
40 set_tests_properties(ParaViewExample-Plugins/PythonAlgorithm PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;98;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
41 add_test(ParaViewExample-Plugins/RegistrationName
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/RegistrationName" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
42 set_tests_properties(ParaViewExample-Plugins/RegistrationName PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;99;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
43 add_test(ParaViewExample-Plugins/ReaderXMLOnly
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/ReaderXMLOnly" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
44 set_tests_properties(ParaViewExample-Plugins/ReaderXMLOnly PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;100;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
45 add_test(ParaViewExample-Plugins/Representation
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/Representation" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
46 set_tests_properties(ParaViewExample-Plugins/Representation PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;101;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
47 add_test(ParaViewExample-Plugins/SMParametricSource
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/SMParametricSource" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
48 set_tests_properties(ParaViewExample-Plugins/SMParametricSource PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;104;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
49 add_test(ParaViewExample-Plugins/SMMyProxy
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/SMMyProxy" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
50 set_tests_properties(ParaViewExample-Plugins/SMMyProxy PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;105;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
51 add_test(ParaViewExample-Plugins/ServerSideQt
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/ServerSideQt" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
52 set_tests_properties(ParaViewExample-Plugins/ServerSideQt PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;106;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
53 add_test(ParaViewExample-Plugins/SourceToolbar
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Plugins/SourceToolbar" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
54 set_tests_properties(ParaViewExample-Plugins/SourceToolbar PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;107;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
55 add_test(ParaViewExample-CustomApplications/Clone1
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=CustomApplications/Clone1" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
56 set_tests_properties(ParaViewExample-CustomApplications/Clone1 PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;110;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
57 add_test(ParaViewExample-CustomApplications/Clone2
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=CustomApplications/Clone2" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
58 set_tests_properties(ParaViewExample-CustomApplications/Clone2 PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;111;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
59 add_test(ParaViewExample-CustomApplications/Demo0
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=CustomApplications/Demo0" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
60 set_tests_properties(ParaViewExample-CustomApplications/Demo0 PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;112;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
61 add_test(ParaViewExample-CustomApplications/Demo1
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=CustomApplications/Demo1" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
62 set_tests_properties(ParaViewExample-CustomApplications/Demo1 PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;113;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
63 add_test(ParaViewExample-CustomApplications/MultiServerClient
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=CustomApplications/MultiServerClient" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
64 set_tests_properties(ParaViewExample-CustomApplications/MultiServerClient PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;114;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
65 add_test(ParaViewExample-CustomApplications/SimpleParaView
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=CustomApplications/SimpleParaView" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
66 set_tests_properties(ParaViewExample-CustomApplications/SimpleParaView PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;115;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
67 add_test(ParaViewExample-CustomApplications/Spreadsheet
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=CustomApplications/Spreadsheet" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
68 set_tests_properties(ParaViewExample-CustomApplications/Spreadsheet PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;116;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
69 add_test(ParaViewExample-Catalyst
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Catalyst" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
70 set_tests_properties(ParaViewExample-Catalyst PROPERTIES SKIP_REGULAR_EXPRESSION
"Skipping example" TIMEOUT
"600" _BACKTRACE_TRIPLES
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;120;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
71 add_test(ParaViewExample-Catalyst2/CFullExample
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Catalyst2/CFullExample" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
72 set_tests_properties(ParaViewExample-Catalyst2/CFullExample PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;124;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
73 add_test(ParaViewExample-Catalyst2/CxxFullExample
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Catalyst2/CxxFullExample" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
74 set_tests_properties(ParaViewExample-Catalyst2/CxxFullExample PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;125;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
75 add_test(ParaViewExample-Catalyst2/CxxImageDataExample
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Catalyst2/CxxImageDataExample" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
76 set_tests_properties(ParaViewExample-Catalyst2/CxxImageDataExample PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;126;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
77 add_test(ParaViewExample-Catalyst2/CxxMultiChannelInputExample
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Catalyst2/CxxMultiChannelInputExample" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
78 set_tests_properties(ParaViewExample-Catalyst2/CxxMultiChannelInputExample PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;127;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
79 add_test(ParaViewExample-Catalyst2/CxxOverlappingAMRExample
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Catalyst2/CxxOverlappingAMRExample" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
80 set_tests_properties(ParaViewExample-Catalyst2/CxxOverlappingAMRExample PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;128;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
81 add_test(ParaViewExample-Catalyst2/CxxPolyhedra
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Catalyst2/CxxPolyhedra" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
82 set_tests_properties(ParaViewExample-Catalyst2/CxxPolyhedra PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;129;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
83 add_test(ParaViewExample-Catalyst2/CxxMultimesh
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Catalyst2/CxxMultimesh" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
84 set_tests_properties(ParaViewExample-Catalyst2/CxxMultimesh PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;130;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
85 add_test(ParaViewExample-Catalyst2/CxxSteeringExample
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Catalyst2/CxxSteeringExample" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
86 set_tests_properties(ParaViewExample-Catalyst2/CxxSteeringExample PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;131;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
87 add_test(ParaViewExample-Catalyst2/PythonFullExample
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Catalyst2/PythonFullExample" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
88 set_tests_properties(ParaViewExample-Catalyst2/PythonFullExample PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;136;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
89 add_test(ParaViewExample-Catalyst2/PythonSteeringExample
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=Catalyst2/PythonSteeringExample" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
90 set_tests_properties(ParaViewExample-Catalyst2/PythonSteeringExample PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;137;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
91 add_test(ParaViewExample-UseParaView/Incubator
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=UseParaView/Incubator" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
92 set_tests_properties(ParaViewExample-UseParaView/Incubator PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;141;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
93 add_test(ParaViewExample-UseParaView/NoIncubator
"/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/cmake" "-Dconfig=Release" "-Dgenerator=Ninja" "-Dsource=/builds/gitlab-kitware-sciviz-ci/Examples" "-Dbinary=/builds/gitlab-kitware-sciviz-ci/build/Examples" "-Dexample_dir=UseParaView/NoIncubator" "-Dbuild_type=Release" "-Dshared=ON" "-Dparaview_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/cmake/paraview-6.0" "-Dctest=/builds/gitlab-kitware-sciviz-ci/.gitlab/cmake/bin/ctest" "-Dplatform=" "-Dtoolset=" "-Dparaview_binary_dir=/builds/gitlab-kitware-sciviz-ci/build/bin" "-Dcatalyst_DIR=/usr/lib64/openmpi/lib/cmake/catalyst-2.0" "-Dparaview_catalyst_dir=/builds/gitlab-kitware-sciviz-ci/build/lib64/catalyst" "-P" "/builds/gitlab-kitware-sciviz-ci/Examples/RunExample.cmake")
94 set_tests_properties(ParaViewExample-UseParaView/NoIncubator PROPERTIES SKIP_REGULAR_EXPRESSION
"/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;17;add_test;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;142;add_example;/builds/gitlab-kitware-sciviz-ci/Examples/CMakeLists.txt;0;")
95 subdirs(
"Plugins/ComplexPythonArchitecture/Testing")
