3 if(NOT PARAVIEW_DATA_STORE)
4 # Select a default from the following. 5 set(PARAVIEW_DATA_STORE_DEFAULT
6 if(EXISTS
"${ParaView_SOURCE_DIR}/.ExternalData/config/store")
7 # Configuration left by developer setup script. 8 file(STRINGS
"${ParaView_SOURCE_DIR}/.ExternalData/config/store" 9 PARAVIEW_DATA_STORE_DEFAULT LIMIT_COUNT 1 LIMIT_INPUT 1024)
10 elseif(IS_DIRECTORY
"${CMAKE_SOURCE_DIR}/../ParaViewExternalData")
11 # Adjacent directory created by user. 12 get_filename_component(PARAVIEW_DATA_STORE_DEFAULT
13 "${CMAKE_SOURCE_DIR}/../ParaViewExternalData" ABSOLUTE)
14 elseif(IS_DIRECTORY
"${CMAKE_SOURCE_DIR}/../ExternalData")
15 # Generic adjacent directory created by user. 16 get_filename_component(PARAVIEW_DATA_STORE_DEFAULT
17 "${CMAKE_SOURCE_DIR}/../ExternalData" ABSOLUTE)
18 elseif(DEFINED
"ENV{ParaViewExternalData_OBJECT_STORES}")
19 # The ParaViewExternalData environment variable. 20 file(TO_CMAKE_PATH
"$ENV{ParaViewExternalData_OBJECT_STORES}" PARAVIEW_DATA_STORE_DEFAULT)
21 elseif(DEFINED
"ENV{ExternalData_OBJECT_STORES}")
22 # Generic ExternalData environment variable. 23 file(TO_CMAKE_PATH
"$ENV{ExternalData_OBJECT_STORES}" PARAVIEW_DATA_STORE_DEFAULT)
27 # Provide users with an option to select a local object store, 28 # starting with the above-selected default. 29 set(PARAVIEW_DATA_STORE
"${PARAVIEW_DATA_STORE_DEFAULT}" CACHE PATH
30 "Local directory holding ExternalData objects in the layout %(algo)/%(hash).")
31 mark_as_advanced(PARAVIEW_DATA_STORE)
33 # Use a store in the build tree if none is otherwise configured. 34 if(NOT PARAVIEW_DATA_STORE)
35 if(ExternalData_OBJECT_STORES)
36 set(PARAVIEW_DATA_STORE
38 set(PARAVIEW_DATA_STORE
"${CMAKE_BINARY_DIR}/ExternalData/Objects")
39 file(MAKE_DIRECTORY
"${PARAVIEW_DATA_STORE}")
43 # Tell ExternalData module about selected object stores. 44 list(APPEND ExternalData_OBJECT_STORES
45 # Store selected by ParaView-specific configuration above.
46 ${PARAVIEW_DATA_STORE}
48 # Local data store populated by the ParaView pre-commit hook
49 "${CMAKE_SOURCE_DIR}/.ExternalData" 52 set(ExternalData_BINARY_ROOT ${CMAKE_BINARY_DIR}/ExternalData)
54 set(ExternalData_URL_TEMPLATES
"" CACHE STRING
55 "Additional URL templates for the ExternalData CMake script to look for testing data. E.g. 56 file:///var/bigharddrive/%(algo)/%(hash)")
57 mark_as_advanced(ExternalData_URL_TEMPLATES)
58 list(APPEND ExternalData_URL_TEMPLATES
59 # Data published by Girder
60 "https://data.kitware.com/api/v1/file/hashsum/%(algo)/%(hash)/download" 62 # Data published by developers
using git-gitlab-push
63 "https://www.paraview.org/files/ExternalData/%(algo)/%(hash)" 65 # Data published by VTK developers
using git-gitlab-push.
66 # ParaView sometimes uses VTK
data. If PARAVIEW_USE_EXTERNAL_VTK the following
67 # location is not added
68 "https://www.vtk.org/files/ExternalData/%(algo)/%(hash)" 71 # Tell ExternalData commands to transform raw files to content links. 72 # TODO: Condition this feature on presence of our pre-commit hook. 73 set(ExternalData_LINK_CONTENT SHA512)
75 # Match series of the form <base>.<ext>, <base>_<n>.<ext> such that <base> may
76 # end in a (test) number that is not part of any series numbering.
77 set(ExternalData_SERIES_PARSE
78 set(ExternalData_SERIES_MATCH
"(_[0-9]+)?")
80 if(DEFINED ENV{DASHBOARD_TEST_FROM_CTEST})
81 # Dashboard builds always need
data.
82 set(PARAVIEW_DATA_EXCLUDE_FROM_ALL OFF)
85 if(NOT DEFINED PARAVIEW_DATA_EXCLUDE_FROM_ALL)
86 if(EXISTS "${ParaView_SOURCE_DIR}/.ExternalData/config/exclude-from-all
") 87 # Configuration left by developer setup script. 88 file(STRINGS "${ParaView_SOURCE_DIR}/.ExternalData/config/exclude-from-all
" 89 PARAVIEW_DATA_EXCLUDE_FROM_ALL_DEFAULT LIMIT_COUNT 1 LIMIT_INPUT 1024) 90 elseif(DEFINED "ENV{PARAVIEW_DATA_EXCLUDE_FROM_ALL}
") 91 set(PARAVIEW_DATA_EXCLUDE_FROM_ALL_DEFAULT 92 "$ENV{PARAVIEW_DATA_EXCLUDE_FROM_ALL}
") 94 set(PARAVIEW_DATA_EXCLUDE_FROM_ALL_DEFAULT OFF) 96 set(PARAVIEW_DATA_EXCLUDE_FROM_ALL "${PARAVIEW_DATA_EXCLUDE_FROM_ALL_DEFAULT}
" 97 CACHE BOOL "Exclude test
data download from
default 'all' target.
" 99 mark_as_advanced(PARAVIEW_DATA_EXCLUDE_FROM_ALL) 102 # Tell VTK to act as we do but not to warn when we warn. 103 set(VTK_DATA_EXCLUDE_FROM_ALL ${PARAVIEW_DATA_EXCLUDE_FROM_ALL}) 104 set(VTK_DATA_EXCLUDE_FROM_ALL_NO_WARNING 1)
