1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/AcceleratedAlgorithms
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpluginsx" OR NOT CMAKE_INSTALL_COMPONENT)
46  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/AcceleratedAlgorithms/AcceleratedAlgorithms.so" AND
47  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/AcceleratedAlgorithms/AcceleratedAlgorithms.so")
48  file(RPATH_CHECK
49  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/AcceleratedAlgorithms/AcceleratedAlgorithms.so"
50  RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
51  endif()
52  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/AcceleratedAlgorithms" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/AcceleratedAlgorithms/AcceleratedAlgorithms.so")
53  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/AcceleratedAlgorithms/AcceleratedAlgorithms.so" AND
54  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/AcceleratedAlgorithms/AcceleratedAlgorithms.so")
55  file(RPATH_CHANGE
56  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/AcceleratedAlgorithms/AcceleratedAlgorithms.so"
57  OLD_RPATH "/builds/gitlab-kitware-sciviz-ci/build/lib64:/usr/lib64/openmpi/lib:"
58  NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
59  if(CMAKE_INSTALL_DO_STRIP)
60  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/AcceleratedAlgorithms/AcceleratedAlgorithms.so")
61  endif()
62  endif()
63 endif()
64
