1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/ParaView_paraview_plugins" TYPE FILE FILES
47  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkBivariateNoiseMapper.h"
48  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkBivariateNoiseRepresentation.h"
49  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkBivariateTextureRepresentation.h"
50  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkContext2DTexturedScalarBarActor.h"
51  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkContext2DTexturedScalarBarRepresentation.h"
52  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkSMBivariateTextureRepresentationProxy.h"
53  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkOpenGLBivariateNoiseMapperDelegator.h"
54  "/builds/gitlab-kitware-sciviz-ci/build/Plugins/BivariateRepresentations/Representations/vtkBivariateRepresentationsModule.h"
55  )
56 endif()
57
58 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
59  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/BivariateRepresentations/vtk/hierarchy/BivariateRepresentations" TYPE FILE RENAME "vtkBivariateRepresentations-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/BivariateRepresentations/vtk/hierarchy/BivariateRepresentations/vtkBivariateRepresentations-hierarchy.txt")
60 endif()
61
62 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpluginsx" OR NOT CMAKE_INSTALL_COMPONENT)
63  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/BivariateRepresentations" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/BivariateRepresentations/libvtkBivariateRepresentations.a")
64 endif()
65
