1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/ContourLabelPlugin/Representations
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/ParaView_paraview_plugins" TYPE FILE FILES
47  "/builds/gitlab-kitware-sciviz-ci/Plugins/ContourLabelPlugin/Representations/vtkContourLabelRepresentation.h"
48  "/builds/gitlab-kitware-sciviz-ci/build/Plugins/ContourLabelPlugin/Representations/vtkContourLabelPluginModule.h"
49  )
50 endif()
51
52 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
53  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/ContourLabelPlugin/vtk/hierarchy/ContourLabelPlugin" TYPE FILE RENAME "vtkContourLabelPlugin-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/ContourLabelPlugin/vtk/hierarchy/ContourLabelPlugin/vtkContourLabelPlugin-hierarchy.txt")
54 endif()
55
56 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpluginsx" OR NOT CMAKE_INSTALL_COMPONENT)
57  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/ContourLabelPlugin/libvtkContourLabelPlugin.so" AND
58  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/ContourLabelPlugin/libvtkContourLabelPlugin.so")
59  file(RPATH_CHECK
60  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/ContourLabelPlugin/libvtkContourLabelPlugin.so"
61  RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
62  endif()
63  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/ContourLabelPlugin" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/ContourLabelPlugin/libvtkContourLabelPlugin.so")
64  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/ContourLabelPlugin/libvtkContourLabelPlugin.so" AND
65  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/ContourLabelPlugin/libvtkContourLabelPlugin.so")
66  file(RPATH_CHANGE
67  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/ContourLabelPlugin/libvtkContourLabelPlugin.so"
68  OLD_RPATH "\$ORIGIN/../../../:/usr/lib64/openmpi/lib::::::::"
69  NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
70  if(CMAKE_INSTALL_DO_STRIP)
71  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/ContourLabelPlugin/libvtkContourLabelPlugin.so")
72  endif()
73  endif()
74 endif()
75
76 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
77 endif()
78
