1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/DSP
47  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel/cmake_install.cmake")
48 endif()
49
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51  # Include the install script for the subdirectory.
52  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/Filters/cmake_install.cmake")
53 endif()
54
55 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
56  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/DigitalSignalProcessing-targets.cmake")
57  file(DIFFERENT _cmake_export_file_changed FILES
58  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/DigitalSignalProcessing-targets.cmake"
59  "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/CMakeFiles/Export/073b2a9b196d662e262a87a68654bd3c/DigitalSignalProcessing-targets.cmake")
60  if(_cmake_export_file_changed)
61  file(GLOB _cmake_old_config_files "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/DigitalSignalProcessing-targets-*.cmake")
62  if(_cmake_old_config_files)
63  string(REPLACE ";" ", " _cmake_old_config_files_text "${_cmake_old_config_files}")
64  message(STATUS "Old export file \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/DigitalSignalProcessing-targets.cmake\" will be replaced. Removing files [${_cmake_old_config_files_text}].")
65  unset(_cmake_old_config_files_text)
66  file(REMOVE ${_cmake_old_config_files})
67  endif()
68  unset(_cmake_old_config_files)
69  endif()
70  unset(_cmake_export_file_changed)
71  endif()
72  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/CMakeFiles/Export/073b2a9b196d662e262a87a68654bd3c/DigitalSignalProcessing-targets.cmake")
73  if(CMAKE_INSTALL_CONFIG_NAME MATCHES "^([Rr][Ee][Ll][Ee][Aa][Ss][Ee])$")
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/CMakeFiles/Export/073b2a9b196d662e262a87a68654bd3c/DigitalSignalProcessing-targets-release.cmake")
75  endif()
76 endif()
77
78 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
79  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0" TYPE FILE RENAME "DigitalSignalProcessing-vtk-module-properties.cmake" FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/CMakeFiles/DigitalSignalProcessing-vtk-module-properties.cmake.install")
80 endif()
81
82 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
83  # Include the install script for the subdirectory.
84  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel/Testing/cmake_install.cmake")
85 endif()
86
87 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
88  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkDSPFiltersPluginCS.a")
89 endif()
90
91 if(CMAKE_INSTALL_COMPONENT STREQUAL "plugins" OR NOT CMAKE_INSTALL_COMPONENT)
92  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so" AND
93  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so")
94  file(RPATH_CHECK
95  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so"
96  RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
97  endif()
98  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalSignalProcessing" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so")
99  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so" AND
100  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so")
101  file(RPATH_CHANGE
102  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so"
103  OLD_RPATH "/builds/gitlab-kitware-sciviz-ci/build/lib64:/usr/lib64/openmpi/lib:"
104  NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
105  if(CMAKE_INSTALL_DO_STRIP)
106  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so")
107  endif()
108  endif()
109 endif()
110
111 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
112  # Include the install script for the subdirectory.
113  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/Testing/cmake_install.cmake")
114 endif()
115
