1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/Datamine/Readers 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/ParaView_paraview_plugins" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/Plugins/Datamine/Readers/vtkDataMineBlockReader.h" 48 "/builds/gitlab-kitware-sciviz-ci/Plugins/Datamine/Readers/vtkDataMineDrillHoleReader.h" 49 "/builds/gitlab-kitware-sciviz-ci/Plugins/Datamine/Readers/vtkDataMineDummyReader.h" 50 "/builds/gitlab-kitware-sciviz-ci/Plugins/Datamine/Readers/vtkDataMinePerimeterReader.h" 51 "/builds/gitlab-kitware-sciviz-ci/Plugins/Datamine/Readers/vtkDataMinePointReader.h" 52 "/builds/gitlab-kitware-sciviz-ci/Plugins/Datamine/Readers/vtkDataMineReader.h" 53 "/builds/gitlab-kitware-sciviz-ci/Plugins/Datamine/Readers/vtkDataMineWireFrameReader.h" 54 "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Datamine/Readers/vtkDatamineReadersModule.h" 58 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 59 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Datamine/
vtk/hierarchy/Datamine
" TYPE FILE RENAME "vtkDatamineReaders-hierarchy.txt
" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/Datamine/
vtk/hierarchy/Datamine/vtkDatamineReaders-hierarchy.txt
") 62 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xpluginsx
" OR NOT CMAKE_INSTALL_COMPONENT) 63 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Datamine/libvtkDatamineReaders.so
" AND 64 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Datamine/libvtkDatamineReaders.so
") 66 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Datamine/libvtkDatamineReaders.so
" 67 RPATH "\$ORIGIN:\$ORIGIN/../../../
") 69 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Datamine
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/Datamine/libvtkDatamineReaders.so
") 70 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Datamine/libvtkDatamineReaders.so
" AND 71 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Datamine/libvtkDatamineReaders.so
") 73 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Datamine/libvtkDatamineReaders.so
" 74 OLD_RPATH "\$ORIGIN/../../../::::::::
" 75 NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../
") 76 if(CMAKE_INSTALL_DO_STRIP) 77 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Datamine/libvtkDatamineReaders.so
") 82 if("x${CMAKE_INSTALL_COMPONENT}x
