1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/DigitalRockPhysics 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
"/builds/gitlab-kitware-sciviz-ci/build/Plugins/DigitalRockPhysics/Filters/cmake_install.cmake")
50 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
51 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/DigitalRockPhysics-targets.cmake
") 52 file(DIFFERENT _cmake_export_file_changed FILES 53 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/DigitalRockPhysics-targets.cmake
" 54 "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DigitalRockPhysics/CMakeFiles/Export/073b2a9b196d662e262a87a68654bd3c/DigitalRockPhysics-targets.cmake
") 55 if(_cmake_export_file_changed) 56 file(GLOB _cmake_old_config_files "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/DigitalRockPhysics-targets-*.cmake
") 57 if(_cmake_old_config_files) 58 string(REPLACE ";
" _cmake_old_config_files_text "${_cmake_old_config_files}
") 59 message(STATUS "Old export file \
"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/DigitalRockPhysics-targets.cmake\" will be replaced. Removing files [${_cmake_old_config_files_text}].")
60 unset(_cmake_old_config_files_text)
61 file(REMOVE ${_cmake_old_config_files})
63 unset(_cmake_old_config_files)
65 unset(_cmake_export_file_changed)
67 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DigitalRockPhysics/CMakeFiles/Export/073b2a9b196d662e262a87a68654bd3c/DigitalRockPhysics-targets.cmake
") 68 if(CMAKE_INSTALL_CONFIG_NAME MATCHES "^([Rr][Ee][Ll][Ee][Aa][Ss][Ee])$
") 69 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DigitalRockPhysics/CMakeFiles/Export/073b2a9b196d662e262a87a68654bd3c/DigitalRockPhysics-targets-release.cmake
") 73 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 74 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0
" TYPE FILE RENAME "DigitalRockPhysics-
vtk-module-properties.cmake
" FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DigitalRockPhysics/CMakeFiles/DigitalRockPhysics-
vtk-module-properties.cmake.install
") 77 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 78 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkDigitalRocksFiltersCS.a
") 81 if(CMAKE_INSTALL_COMPONENT STREQUAL "plugins
" OR NOT CMAKE_INSTALL_COMPONENT) 82 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalRockPhysics/DigitalRockPhysics.so
" AND 83 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalRockPhysics/DigitalRockPhysics.so
") 85 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalRockPhysics/DigitalRockPhysics.so
" 86 RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 88 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalRockPhysics
" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/DigitalRockPhysics/DigitalRockPhysics.so
") 89 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalRockPhysics/DigitalRockPhysics.so
" AND 90 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalRockPhysics/DigitalRockPhysics.so
") 92 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalRockPhysics/DigitalRockPhysics.so
" 93 OLD_RPATH "/builds/gitlab-kitware-sciviz-ci/build/lib64:/usr/lib64/openmpi/lib:/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/DigitalRockPhysics:
" 94 NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 95 if(CMAKE_INSTALL_DO_STRIP) 96 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/DigitalRockPhysics/DigitalRockPhysics.so
") 101 if(NOT CMAKE_INSTALL_LOCAL_ONLY) 102 # Include the install script for the subdirectory. 103 include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/DigitalRockPhysics/Testing/cmake_install.cmake
