1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/GenericIOReader/Readers 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/GenericIOReader/vtk/hierarchy/GenericIOReader" TYPE FILE RENAME
"vtkGenericIOReader-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/GenericIOReader/vtk/hierarchy/GenericIOReader/vtkGenericIOReader-hierarchy.txt")
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "plugins" OR NOT CMAKE_INSTALL_COMPONENT)
50 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/GenericIOReader/libvtkGenericIOReader.so
" AND 51 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/GenericIOReader/libvtkGenericIOReader.so
") 53 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/GenericIOReader/libvtkGenericIOReader.so
" 54 RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 56 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/GenericIOReader
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/GenericIOReader/libvtkGenericIOReader.so
") 57 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/GenericIOReader/libvtkGenericIOReader.so
" AND 58 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/GenericIOReader/libvtkGenericIOReader.so
") 60 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/GenericIOReader/libvtkGenericIOReader.so
" 61 OLD_RPATH "\$ORIGIN/../../../:/usr/lib64/openmpi/lib::::::::
" 62 NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 63 if(CMAKE_INSTALL_DO_STRIP) 64 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/GenericIOReader/libvtkGenericIOReader.so
") 69 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 72 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 75 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 76 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/GenericIOReader/Readers/vtkGenIOReader.h
") 79 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 80 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/GenericIOReader/Readers/vtkGenericIOReaderModule.h
") 83 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses
" OR NOT CMAKE_INSTALL_COMPONENT) 84 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkGenericIOReader
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/GenericIOReader/Readers/LICENSE
") 87 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 88 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/GenericIOReader/Readers/vtkGenericIOReader.spdx
") 91 if(NOT CMAKE_INSTALL_LOCAL_ONLY) 92 # Include the install script for the subdirectory. 93 include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/GenericIOReader/Readers/LANL/cmake_install.cmake
