1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
"/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Filters/cmake_install.cmake")
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51 # Include the install script for the subdirectory. 52 include(
"/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Parallel/cmake_install.cmake")
55 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 56 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/LegacyGhostCellsGenerator-targets.cmake
") 57 file(DIFFERENT EXPORT_FILE_CHANGED FILES 58 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/LegacyGhostCellsGenerator-targets.cmake
" 59 "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/CMakeFiles/Export/lib64/cmake/paraview-5.13/LegacyGhostCellsGenerator-targets.cmake
") 60 if(EXPORT_FILE_CHANGED) 61 file(GLOB OLD_CONFIG_FILES "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/LegacyGhostCellsGenerator-targets-*.cmake
") 63 message(STATUS "Old export file \
"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/LegacyGhostCellsGenerator-targets.cmake\" will be replaced. Removing files [${OLD_CONFIG_FILES}].")
64 file(REMOVE ${OLD_CONFIG_FILES})
68 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/CMakeFiles/Export/lib64/cmake/paraview-5.13/LegacyGhostCellsGenerator-targets.cmake
") 69 if("${CMAKE_INSTALL_CONFIG_NAME}
" MATCHES "^([Rr][Ee][Ll][Ee][Aa][Ss][Ee])$
") 70 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/CMakeFiles/Export/lib64/cmake/paraview-5.13/LegacyGhostCellsGenerator-targets-release.cmake
") 74 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 75 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13
" TYPE FILE RENAME "LegacyGhostCellsGenerator-
vtk-module-properties.cmake
" FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/CMakeFiles/LegacyGhostCellsGenerator-
vtk-module-properties.cmake.install
") 78 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 79 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libLegacyGhostCellsGeneratorFiltersCS.a
") 82 if("x${CMAKE_INSTALL_COMPONENT}x
" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libLegacyGhostCellsGeneratorParallelCS.a
") 86 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xpluginsx
" OR NOT CMAKE_INSTALL_COMPONENT) 87 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so
" AND 88 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so
") 90 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so
" 91 RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 93 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/LegacyGhostCellsGenerator
" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so
") 94 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so
" AND 95 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so
") 97 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so
" 98 OLD_RPATH "/builds/gitlab-kitware-sciviz-ci/build/lib64:/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/LegacyGhostCellsGenerator:/usr/lib64/openmpi/lib:
" 99 NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 100 if(CMAKE_INSTALL_DO_STRIP) 101 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/LegacyGhostCellsGenerator/LegacyGhostCellsGenerator.so
") 106 if(NOT CMAKE_INSTALL_LOCAL_ONLY) 107 # Include the install script for the subdirectory. 108 include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Testing/cmake_install.cmake
