1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/MooseXfemClip
47  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/MooseXfemClip/Filters/cmake_install.cmake")
48 endif()
49
51  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/MooseXfemClip-targets.cmake")
53  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/MooseXfemClip-targets.cmake"
54  "/builds/gitlab-kitware-sciviz-ci/build/Plugins/MooseXfemClip/CMakeFiles/Export/073b2a9b196d662e262a87a68654bd3c/MooseXfemClip-targets.cmake")
56  file(GLOB _cmake_old_config_files "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/MooseXfemClip-targets-*.cmake")
59  message(STATUS "Old export file \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0/MooseXfemClip-targets.cmake\" will be replaced. Removing files [${_cmake_old_config_files_text}].")
62  endif()
64  endif()
66  endif()
67  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/MooseXfemClip/CMakeFiles/Export/073b2a9b196d662e262a87a68654bd3c/MooseXfemClip-targets.cmake")
69  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/MooseXfemClip/CMakeFiles/Export/073b2a9b196d662e262a87a68654bd3c/MooseXfemClip-targets-release.cmake")
70  endif()
71 endif()
72
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-6.0" TYPE FILE RENAME "MooseXfemClip-vtk-module-properties.cmake" FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/MooseXfemClip/CMakeFiles/MooseXfemClip-vtk-module-properties.cmake.install")
75 endif()
76
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkMooseXfemClipCS.a")
79 endif()
80
82  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/MooseXfemClip/MooseXfemClip.so" AND
83  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/MooseXfemClip/MooseXfemClip.so")
84  file(RPATH_CHECK
85  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/MooseXfemClip/MooseXfemClip.so"
87  endif()
88  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/MooseXfemClip" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/MooseXfemClip/MooseXfemClip.so")
89  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/MooseXfemClip/MooseXfemClip.so" AND
90  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/MooseXfemClip/MooseXfemClip.so")
91  file(RPATH_CHANGE
92  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/MooseXfemClip/MooseXfemClip.so"
93  OLD_RPATH "/builds/gitlab-kitware-sciviz-ci/build/lib64:/usr/lib64/openmpi/lib:/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/MooseXfemClip:"
96  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/MooseXfemClip/MooseXfemClip.so")
97  endif()
98  endif()
99 endif()
100
101 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
102  # Include the install script for the subdirectory.
103  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/MooseXfemClip/Testing/cmake_install.cmake")
104 endif()
105
