1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/Prism 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
"/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Filters/cmake_install.cmake")
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51 # Include the install script for the subdirectory. 52 include(
"/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Views/cmake_install.cmake")
55 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
56 # Include the install script for the subdirectory. 57 include(
"/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/ServerManager/cmake_install.cmake")
60 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
61 # Include the install script for the subdirectory. 62 include(
"/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/Readers/cmake_install.cmake")
65 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 66 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/Prism-targets.cmake
") 67 file(DIFFERENT EXPORT_FILE_CHANGED FILES 68 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/Prism-targets.cmake
" 69 "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/CMakeFiles/Export/lib64/cmake/paraview-5.13/Prism-targets.cmake
") 70 if(EXPORT_FILE_CHANGED) 71 file(GLOB OLD_CONFIG_FILES "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/Prism-targets-*.cmake
") 73 message(STATUS "Old export file \
"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/Prism-targets.cmake\" will be replaced. Removing files [${OLD_CONFIG_FILES}].")
74 file(REMOVE ${OLD_CONFIG_FILES})
78 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/CMakeFiles/Export/lib64/cmake/paraview-5.13/Prism-targets.cmake
") 79 if("${CMAKE_INSTALL_CONFIG_NAME}
" MATCHES "^([Dd][Ee][Bb][Uu][Gg])$
") 80 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/CMakeFiles/Export/lib64/cmake/paraview-5.13/Prism-targets-debug.cmake
") 84 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 85 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13
" TYPE FILE RENAME "Prism-
vtk-module-properties.cmake
" FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/Prism/CMakeFiles/Prism-
vtk-module-properties.cmake.install
") 88 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 89 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPrismFiltersCS.a
") 92 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 93 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPrismReadersCS.a
") 96 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 97 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPrismServerManagerCS.a
") 100 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 101 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPrismViewsCS.a
") 104 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xpluginsx
" OR NOT CMAKE_INSTALL_COMPONENT) 105 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Prism/Prism.so
" AND 106 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Prism/Prism.so
") 108 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Prism/Prism.so
" 109 RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 111 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Prism
" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/Prism/Prism.so
") 112 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Prism/Prism.so
" AND 113 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Prism/Prism.so
") 115 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Prism/Prism.so
" 116 OLD_RPATH "/builds/gitlab-kitware-sciviz-ci/build/lib64:/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/Prism:/usr/lib64/openmpi/lib:
" 117 NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 118 if(CMAKE_INSTALL_DO_STRIP) 119 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/Prism/Prism.so
