1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/StereoCursorView
47  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/StereoCursorView/StereoCursorViews/cmake_install.cmake")
48 endif()
49
50 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
51  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/StereoCursorView-targets.cmake")
52  file(DIFFERENT EXPORT_FILE_CHANGED FILES
53  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/StereoCursorView-targets.cmake"
54  "/builds/gitlab-kitware-sciviz-ci/build/Plugins/StereoCursorView/CMakeFiles/Export/lib64/cmake/paraview-5.13/StereoCursorView-targets.cmake")
55  if(EXPORT_FILE_CHANGED)
56  file(GLOB OLD_CONFIG_FILES "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/StereoCursorView-targets-*.cmake")
57  if(OLD_CONFIG_FILES)
58  message(STATUS "Old export file \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/StereoCursorView-targets.cmake\" will be replaced. Removing files [${OLD_CONFIG_FILES}].")
59  file(REMOVE ${OLD_CONFIG_FILES})
60  endif()
61  endif()
62  endif()
63  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/StereoCursorView/CMakeFiles/Export/lib64/cmake/paraview-5.13/StereoCursorView-targets.cmake")
64  if("${CMAKE_INSTALL_CONFIG_NAME}" MATCHES "^([Dd][Ee][Bb][Uu][Gg])$")
65  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/StereoCursorView/CMakeFiles/Export/lib64/cmake/paraview-5.13/StereoCursorView-targets-debug.cmake")
66  endif()
67 endif()
68
69 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13" TYPE FILE RENAME "StereoCursorView-vtk-module-properties.cmake" FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/StereoCursorView/CMakeFiles/StereoCursorView-vtk-module-properties.cmake.install")
71 endif()
72
73 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libStereoCursorViewsCS.a")
75 endif()
76
77 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpluginsx" OR NOT CMAKE_INSTALL_COMPONENT)
78  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StereoCursorView/StereoCursorView.so" AND
79  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StereoCursorView/StereoCursorView.so")
80  file(RPATH_CHECK
81  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StereoCursorView/StereoCursorView.so"
82  RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
83  endif()
84  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StereoCursorView" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/StereoCursorView/StereoCursorView.so")
85  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StereoCursorView/StereoCursorView.so" AND
86  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StereoCursorView/StereoCursorView.so")
87  file(RPATH_CHANGE
88  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StereoCursorView/StereoCursorView.so"
89  OLD_RPATH "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/StereoCursorView:/builds/gitlab-kitware-sciviz-ci/build/lib64:/usr/lib64/openmpi/lib:"
90  NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
91  if(CMAKE_INSTALL_DO_STRIP)
92  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StereoCursorView/StereoCursorView.so")
93  endif()
94  endif()
95 endif()
96
