1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/StreamLinesRepresentation/Representations 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/ParaView_paraview_plugins" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/Plugins/StreamLinesRepresentation/Representations/vtkStreamLinesMapper.h" 48 "/builds/gitlab-kitware-sciviz-ci/Plugins/StreamLinesRepresentation/Representations/vtkStreamLinesRepresentation.h" 49 "/builds/gitlab-kitware-sciviz-ci/build/Plugins/StreamLinesRepresentation/Representations/vtkStreamLinesModule.h" 53 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 54 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StreamLinesRepresentation/
vtk/hierarchy/StreamLinesRepresentation
" TYPE FILE RENAME "vtkStreamLines-hierarchy.txt
" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/StreamLinesRepresentation/
vtk/hierarchy/StreamLinesRepresentation/vtkStreamLines-hierarchy.txt
" STREQUAL "xpluginsx
" OR NOT CMAKE_INSTALL_COMPONENT) 58 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StreamLinesRepresentation/libvtkStreamLines.so
" AND 59 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StreamLinesRepresentation/libvtkStreamLines.so
") 61 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StreamLinesRepresentation/libvtkStreamLines.so
" 62 RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 64 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StreamLinesRepresentation
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/StreamLinesRepresentation/libvtkStreamLines.so
") 65 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StreamLinesRepresentation/libvtkStreamLines.so
" AND 66 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StreamLinesRepresentation/libvtkStreamLines.so
") 68 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StreamLinesRepresentation/libvtkStreamLines.so
" 69 OLD_RPATH "\$ORIGIN/../../../:/usr/lib64/openmpi/lib::::::::
" 70 NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 71 if(CMAKE_INSTALL_DO_STRIP) 72 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/StreamLinesRepresentation/libvtkStreamLines.so
") 77 if("x${CMAKE_INSTALL_COMPONENT}x
