1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Qt/Components
47  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPluginTreeWidget.h"
48  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqAboutDialog.h"
49  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqAbstractItemSelectionModel.h"
50  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqActionGroupInterface.h"
51  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqActiveObjects.h"
52  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqAnimatablePropertiesComboBox.h"
53  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqAnimatableProxyComboBox.h"
54  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqAnimationManager.h"
55  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqAnimationProgressDialog.h"
56  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqAnimationTimeWidget.h"
57  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqAnimationTrackEditor.h"
58  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqArrayListDomain.h"
59  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqArrayListWidget.h"
60  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqArraySelectionWidget.h"
61  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqArraySelectorPropertyWidget.h"
62  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqArrayStatusPropertyWidget.h"
63  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqBlockProxyWidget.h"
64  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqCalculatorWidget.h"
65  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqCameraDialog.h"
66  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqCameraKeyFrameWidget.h"
67  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqChangeInputDialog.h"
68  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqCollaborationPanel.h"
69  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqColorChooserButtonWithPalettes.h"
70  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqColorOverlay.h"
71  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqComboBoxDomain.h"
72  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqCommandPropertyWidget.h"
73  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqComparativeCueWidget.h"
74  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqComparativeVisPanel.h"
75  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqComponentsInit.h"
76  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqComponentsTestUtility.h"
77  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqCompositePropertyWidgetDecorator.h"
78  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqContextMenuInterface.h"
79  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqCustomFilterDefinitionModel.h"
80  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqCustomFilterDefinitionWizard.h"
81  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqCustomFilterManager.h"
82  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqCustomFilterManagerModel.h"
83  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqCustomViewpointButtonDialog.h"
84  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqDataAssemblyTreeModel.h"
85  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqDataInformationModel.h"
86  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqDataInformationWidget.h"
87  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqDialog.h"
88  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqDisplayColorWidget.h"
89  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqDisplayColor2Widget.h"
90  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqDisplayOpacityWidget.h"
91  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqDisplayPanel.h"
92  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqDisplayPanelInterface.h"
93  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqDisplayPanelPropertyWidget.h"
94  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqDisplayRepresentationWidget.h"
95  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqDockWindowInterface.h"
96  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqDoubleVectorPropertyWidget.h"
97  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqExpressionChooserButton.h"
98  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqExpressionsDialog.h"
99  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqExpressionsManager.h"
100  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqExpressionsTableModel.h"
101  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqExpressionsWidget.h"
102  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqFavoritesDialog.h"
103  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqFavoritesTreeWidget.h"
104  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqFileChooserWidget.h"
105  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqFindDataCurrentSelectionFrame.h"
106  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqFindDataSelectionDisplayFrame.h"
107  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSpreadSheetColumnsVisibility.h"
108  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqHighlightItemDelegate.h"
109  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqIconBrowser.h"
110  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqImageTip.h"
111  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqIndexSelectionWidget.h"
112  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqInputSelectorWidget.h"
113  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqIntMaskPropertyWidget.h"
114  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqIntRangeWidget.h"
115  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqIntVectorPropertyWidget.h"
116  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqItemViewSearchWidget.h"
117  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqItemViewSearchWidgetEventPlayer.h"
118  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqKeyFrameEditor.h"
119  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqKeyFrameTimeValidator.h"
120  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqKeyFrameTypeWidget.h"
121  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqLabel.h"
122  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqLightsEditor.h"
123  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqLightsInspector.h"
124  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqLinksEditor.h"
125  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqLinksManager.h"
126  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqLiveInsituManager.h"
127  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqLiveInsituVisualizationManager.h"
128  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqLiveSourceItem.h"
129  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqLiveSourceManager.h"
130  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqLockViewSizeCustomDialog.h"
131  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqLogViewerDialog.h"
132  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqMemoryInspectorPanel.h"
133  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqMultiBlockInspectorWidget.h"
134  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqMultiBlockPropertiesEditorWidget.h"
135  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqMultiBlockPropertiesStateWidget.h"
136  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqMultiViewWidget.h"
137  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqOneLinerTextEdit.h"
138  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqOrbitCreatorDialog.h"
139  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqOutputPortComboBox.h"
140  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPipelineAnnotationFilterModel.h"
141  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPipelineBrowserWidget.h"
142  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPipelineModel.h"
143  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPipelineModelSelectionAdaptor.h"
144  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPipelineTimeKeyFrameEditor.h"
145  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPluginDialog.h"
146  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPluginTreeWidgetEventPlayer.h"
147  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPluginTreeWidgetEventTranslator.h"
148  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPopOutWidget.h"
149  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPresetDialog.h"
150  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPresetGroupsManager.h"
151  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPresetToPixmap.h"
152  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPropertiesPanel.h"
153  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPropertyGroupWidget.h"
154  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPropertyWidget.h"
155  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPropertyWidgetDecorator.h"
156  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqPropertyWidgetInterface.h"
157  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqProxiesWidget.h"
158  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqProxyAction.h"
159  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqProxyEditorPropertyWidget.h"
160  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqProxyInformationWidget.h"
161  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqProxyPropertyWidget.h"
162  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqProxySelectionWidget.h"
163  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqProxyWidget.h"
164  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqProxyWidgetDialog.h"
165  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqRecentFilesMenu.h"
166  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqRemoteCommandDialog.h"
167  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqRemoteCommandTemplateDialog.h"
168  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqRescaleScalarRangeToCustomDialog.h"
169  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqRescaleScalarRangeToDataOverTimeDialog.h"
170  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSingleLogViewerWidget.h"
171  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSMSignalAdaptors.h"
172  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqScalarSetModel.h"
173  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqScalarValueListPropertyWidget.h"
174  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSearchBox.h"
175  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSelectReaderDialog.h"
176  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSelectionAdaptor.h"
177  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSelectionInputWidget.h"
178  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSelectionLinkDialog.h"
179  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSelectionManager.h"
180  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqServerConfigurationImporter.h"
181  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqServerConnectDialog.h"
182  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqServerLauncher.h"
183  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSetBreakpointDialog.h"
184  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSettingsDialog.h"
185  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqShaderReplacementsComboBox.h"
186  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqShaderReplacementsSelectorPropertyWidget.h"
187  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqShortcutDecorator.h"
188  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSignalAdaptorKeyFrameType.h"
189  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSignalAdaptorSelectionTreeWidget.h"
190  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqSignalAdaptorTreeWidget.h"
191  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqReaderSelectionPropertyWidget.h"
192  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqStringVectorPropertyWidget.h"
193  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqTabbedMultiViewWidget.h"
194  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqTextureComboBox.h"
195  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqTextureSelectorPropertyWidget.h"
196  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqTimerLogDisplay.h"
197  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqToolBarInterface.h"
198  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqToolTipTrapper.h"
199  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqTransferFunctionWidget.h"
200  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqTransferFunction2DWidget.h"
201  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqTriggerOnIdleHelper.h"
202  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqUndoStackBuilder.h"
203  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqVCRController.h"
204  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqViewFrame.h"
205  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqViewFrameActionsInterface.h"
206  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqViewManager.h"
207  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqWidgetRangeDomain.h"
208  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqXYChartViewBoundsPropertyWidget.h"
209  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/vtkPVColorTransferControlPointsItem.h"
210  "/builds/gitlab-kitware-sciviz-ci/Qt/Components/pqHelpWindow.h"
211  "/builds/gitlab-kitware-sciviz-ci/build/Qt/Components/pqComponentsModule.h"
212  )
213 endif()
214
215 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
216  foreach(file
217  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqComponents-pv5.13.so.5.13"
218  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqComponents-pv5.13.so.1"
219  )
220  if(EXISTS "${file}" AND
221  NOT IS_SYMLINK "${file}")
222  file(RPATH_CHECK
223  FILE "${file}"
224  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
225  endif()
226  endforeach()
227  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
228  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqComponents-pv5.13.so.5.13"
229  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqComponents-pv5.13.so.1"
230  )
231  foreach(file
232  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqComponents-pv5.13.so.5.13"
233  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqComponents-pv5.13.so.1"
234  )
235  if(EXISTS "${file}" AND
236  NOT IS_SYMLINK "${file}")
237  file(RPATH_CHANGE
238  FILE "${file}"
239  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
240  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
241  if(CMAKE_INSTALL_DO_STRIP)
242  execute_process(COMMAND "/usr/bin/strip" "${file}")
243  endif()
244  endif()
245  endforeach()
246 endif()
247
248 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
249  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqComponents-pv5.13.so" AND
250  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqComponents-pv5.13.so")
251  file(RPATH_CHECK
252  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqComponents-pv5.13.so"
253  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
254  endif()
255  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqComponents-pv5.13.so")
256  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqComponents-pv5.13.so" AND
257  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqComponents-pv5.13.so")
258  file(RPATH_CHANGE
259  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqComponents-pv5.13.so"
260  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
261  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
262  if(CMAKE_INSTALL_DO_STRIP)
263  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqComponents-pv5.13.so")
264  endif()
265  endif()
266 endif()
267
