Go to the documentation of this file. 1 #define __DBL_MIN_EXP__ (-1021) 2 #define __cpp_attributes 200809L 3 #define __cpp_nontype_template_parameter_auto 201606L 4 #define __UINT_LEAST16_MAX__ 0xffff 5 #define __ATOMIC_ACQUIRE 2 6 #define __FLT128_MAX_10_EXP__ 4932 7 #define __FLT_MIN__ 1.17549435082228750796873653722224568e-38F 8 #define __GCC_IEC_559_COMPLEX 2 9 #define __cpp_aggregate_nsdmi 201304L 10 #define __UINT_LEAST8_TYPE__ unsigned char 11 #define __SIZEOF_FLOAT80__ 16 12 #define __INTMAX_C(c) c ## L 13 #define __CHAR_BIT__ 8 14 #define __UINT8_MAX__ 0xff 15 #define __SCHAR_WIDTH__ 8 16 #define __WINT_MAX__ 0xffffffffU 17 #define __FLT32_MIN_EXP__ (-125) 18 #define __cpp_static_assert 201411L 20 #define __ORDER_LITTLE_ENDIAN__ 1234 21 #define __SIZE_MAX__ 0xffffffffffffffffUL 22 #define __WCHAR_MAX__ 0x7fffffff 23 #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_1 1 24 #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_2 1 25 #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_4 1 26 #define __DBL_DENORM_MIN__ double(4.94065645841246544176568792868221372e-324L) 27 #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_8 1 28 #define __GCC_ATOMIC_CHAR_LOCK_FREE 2 29 #define __GCC_IEC_559 2 30 #define __FLT32X_DECIMAL_DIG__ 17 31 #define __FLT_EVAL_METHOD__ 0 32 #define __cpp_binary_literals 201304L 33 #define __FLT64_DECIMAL_DIG__ 17 34 #define __cpp_noexcept_function_type 201510L 35 #define __GCC_ATOMIC_CHAR32_T_LOCK_FREE 2 36 #define __cpp_variadic_templates 200704L 37 #define VTK_MODULE_ENABLE_VTK_AcceleratorsVTKmFilters 1 38 #define __UINT_FAST64_MAX__ 0xffffffffffffffffUL 39 #define __SIG_ATOMIC_TYPE__ int 40 #define __DBL_MIN_10_EXP__ (-307) 41 #define __FINITE_MATH_ONLY__ 0 42 #define __cpp_variable_templates 201304L 43 #define __FLT32X_MAX_EXP__ 1024 44 #define __FLT32_HAS_DENORM__ 1 45 #define __UINT_FAST8_MAX__ 0xff 46 #define __cpp_rvalue_reference 200610L 47 #define __cpp_nested_namespace_definitions 201411L 48 #define __DEC64_MAX_EXP__ 385 50 #define __INT_LEAST8_WIDTH__ 8 51 #define __cpp_variadic_using 201611L 52 #define __UINT_LEAST64_MAX__ 0xffffffffffffffffUL 53 #define QT_OPENGL_LIB 1 54 #define __INT_LEAST8_MAX__ 0x7f 55 #define __cpp_capture_star_this 201603L 56 #define __SHRT_MAX__ 0x7fff 57 #define __LDBL_MAX__ 1.18973149535723176502126385303097021e+4932L 58 #define __FLT64X_MAX_10_EXP__ 4932 59 #define __cpp_if_constexpr 201606L 60 #define __LDBL_IS_IEC_60559__ 2 61 #define __FLT64X_HAS_QUIET_NAN__ 1 62 #define __UINT_LEAST8_MAX__ 0xff 63 #define __GCC_ATOMIC_BOOL_LOCK_FREE 2 64 #define __FLT128_DENORM_MIN__ 6.47517511943802511092443895822764655e-4966F128 65 #define __UINTMAX_TYPE__ long unsigned int 66 #define VTKMDIY_DEBUG 1 68 #define __DEC32_EPSILON__ 1E-6DF 69 #define __FLT_EVAL_METHOD_TS_18661_3__ 0 71 #define __UINT32_MAX__ 0xffffffffU 72 #define __GXX_EXPERIMENTAL_CXX0X__ 1 73 #define __FLT128_MIN_EXP__ (-16381) 74 #define __WINT_MIN__ 0U 75 #define __FLT128_MIN_10_EXP__ (-4931) 76 #define __FLT32X_IS_IEC_60559__ 2 77 #define __INT_LEAST16_WIDTH__ 16 78 #define __SCHAR_MAX__ 0x7f 79 #define __FLT128_MANT_DIG__ 113 80 #define __WCHAR_MIN__ (-__WCHAR_MAX__ - 1) 81 #define __INT64_C(c) c ## L 82 #define __GCC_ATOMIC_POINTER_LOCK_FREE 2 83 #define __FLT32X_MANT_DIG__ 53 84 #define __GCC_ATOMIC_CHAR16_T_LOCK_FREE 2 85 #define __cpp_aligned_new 201606L 86 #define __USER_LABEL_PREFIX__ 87 #define __FLT32_MAX_10_EXP__ 38 88 #define __FLT64X_EPSILON__ 1.08420217248550443400745280086994171e-19F64x 89 #define __STDC_HOSTED__ 1 90 #define __DEC64_MIN_EXP__ (-382) 91 #define __cpp_decltype_auto 201304L 92 #define __DBL_DIG__ 15 93 #define __FLT32_DIG__ 6 94 #define __FLT_EPSILON__ 1.19209289550781250000000000000000000e-7F 95 #define __GXX_WEAK__ 1 96 #define __SHRT_WIDTH__ 16 97 #define __FLT32_IS_IEC_60559__ 2 98 #define __LDBL_MIN__ 3.36210314311209350626267781732175260e-4932L 99 #define __DBL_IS_IEC_60559__ 2 100 #define __DEC32_MAX__ 9.999999E96DF 101 #define __cpp_threadsafe_static_init 200806L 102 #define __cpp_enumerator_attributes 201411L 103 #define __FLT64X_DENORM_MIN__ 3.64519953188247460252840593361941982e-4951F64x 104 #define VTK_MODULE_ENABLE_ParaView_pqPython 1 105 #define __FLT32X_HAS_INFINITY__ 1 106 #define __INT32_MAX__ 0x7fffffff 108 #define __INT_WIDTH__ 32 109 #define __SIZEOF_LONG__ 8 110 #define __STDC_IEC_559__ 1 111 #define __STDC_ISO_10646__ 201706L 112 #define __UINT16_C(c) c 113 #define __DECIMAL_DIG__ 21 114 #define __STDC_IEC_559_COMPLEX__ 1 115 #define __FLT64_EPSILON__ 2.22044604925031308084726333618164062e-16F64 116 #define __gnu_linux__ 1 117 #define __INT16_MAX__ 0x7fff 118 #define __FLT64_MIN_EXP__ (-1021) 119 #define __FLT64X_MIN_10_EXP__ (-4931) 120 #define __LDBL_HAS_QUIET_NAN__ 1 122 #define __FLT64_MANT_DIG__ 53 123 #define __FLT64X_MANT_DIG__ 64 127 #define VTK_ENABLE_VTKM_OVERRIDES 0 128 #define __FLT_HAS_DENORM__ 1 129 #define __SIZEOF_LONG_DOUBLE__ 16 130 #define __BIGGEST_ALIGNMENT__ 16 131 #define __STDC_UTF_16__ 1 132 #define vtkRemotingServerManager_AUTOINIT_INCLUDE "/builds/gitlab-kitware-sciviz-ci/build/CMakeFiles/vtkModuleAutoInit_0d82148c8043c6ef4b938342dea5013a.h" 133 #define OMPI_SKIP_MPICXX 1 134 #define __FLT64_MAX_10_EXP__ 308 135 #define __cpp_delegating_constructors 200604L 136 #define __FLT32_HAS_INFINITY__ 1 137 #define __DBL_MAX__ double(1.79769313486231570814527423731704357e+308L) 138 #define __cpp_raw_strings 200710L 139 #define __INT_FAST32_MAX__ 0x7fffffffffffffffL 140 #define __DBL_HAS_INFINITY__ 1 141 #define __SIZEOF_FLOAT__ 4 142 #define __HAVE_SPECULATION_SAFE_VALUE 1 143 #define __cpp_fold_expressions 201603L 144 #define __DEC32_MIN_EXP__ (-94) 145 #define __INTPTR_WIDTH__ 64 146 #define __FLT64X_HAS_INFINITY__ 1 147 #define __UINT_LEAST32_MAX__ 0xffffffffU 148 #define __FLT32X_HAS_DENORM__ 1 149 #define __INT_FAST16_TYPE__ long int 150 #define __MMX_WITH_SSE__ 1 151 #define __LDBL_HAS_DENORM__ 1 152 #define QT_WIDGETS_LIB 1 153 #define __cplusplus 201703L 154 #define __cpp_ref_qualifiers 200710L 155 #define __DEC32_MIN__ 1E-95DF 156 #define __DEPRECATED 1 157 #define __cpp_rvalue_references 200610L 158 #define __DBL_MAX_EXP__ 1024 159 #define __WCHAR_WIDTH__ 32 160 #define __FLT32_MAX__ 3.40282346638528859811704183484516925e+38F32 161 #define __DEC128_EPSILON__ 1E-33DL 162 #define __SSE2_MATH__ 1 163 #define __ATOMIC_HLE_RELEASE 131072 164 #define __PTRDIFF_MAX__ 0x7fffffffffffffffL 166 #define __ATOMIC_HLE_ACQUIRE 65536 168 #define __LONG_LONG_MAX__ 0x7fffffffffffffffLL 169 #define __SIZEOF_SIZE_T__ 8 170 #define __cpp_nsdmi 200809L 171 #define __FLT64X_MIN_EXP__ (-16381) 172 #define __SIZEOF_WINT_T__ 4 173 #define __LONG_LONG_WIDTH__ 64 174 #define __cpp_initializer_lists 200806L 175 #define __FLT32_MAX_EXP__ 128 177 #define __cpp_hex_float 201603L 178 #define __GXX_ABI_VERSION 1016 179 #define __FLT128_HAS_INFINITY__ 1 180 #define kiss_fft_scalar double 181 #define __FLT_MIN_EXP__ (-125) 182 #define __GCC_HAVE_DWARF2_CFI_ASM 1 184 #define __cpp_lambdas 200907L 185 #define __INT_FAST64_TYPE__ long int 186 #define __FLT64_DENORM_MIN__ 4.94065645841246544176568792868221372e-324F64 187 #define PROTOBUF_USE_DLLS 1 188 #define __cpp_template_auto 201606L 189 #define __DBL_MIN__ double(2.22507385850720138309023271733240406e-308L) 190 #define __FLT128_EPSILON__ 1.92592994438723585305597794258492732e-34F128 191 #define __FLT64X_NORM_MAX__ 1.18973149535723176502126385303097021e+4932F64x 192 #define __SIZEOF_POINTER__ 8 194 #define __DBL_HAS_QUIET_NAN__ 1 195 #define __FLT32X_EPSILON__ 2.22044604925031308084726333618164062e-16F32x 196 #define __DECIMAL_BID_FORMAT__ 1 197 #define __FLT64_MIN_10_EXP__ (-307) 198 #define __FLT64X_DECIMAL_DIG__ 21 199 #define __DEC128_MIN__ 1E-6143DL 200 #define __REGISTER_PREFIX__ 201 #define __UINT16_MAX__ 0xffff 202 #define __LDBL_HAS_INFINITY__ 1 203 #define __FLT32_MIN__ 1.17549435082228750796873653722224568e-38F32 204 #define __UINT8_TYPE__ unsigned char 205 #define __FLT_DIG__ 6 206 #define __NO_INLINE__ 1 207 #define __DEC_EVAL_METHOD__ 2 208 #define __DEC128_MAX__ 9.999999999999999999999999999999999E6144DL 209 #define QT_NO_KEYWORDS 1 210 #define __FLT_MANT_DIG__ 24 211 #define __LDBL_DECIMAL_DIG__ 21 212 #define __VERSION__ "11.3.1 20220421 (Red Hat 11.3.1-3)" 213 #define __UINT64_C(c) c ## UL 214 #define __cpp_unicode_characters 201411L 215 #define _STDC_PREDEF_H 1 216 #define GLAD_API_CALL_EXPORT 1 217 #define __INT_LEAST32_MAX__ 0x7fffffff 218 #define __GCC_ATOMIC_INT_LOCK_FREE 2 219 #define __FLT128_MAX_EXP__ 16384 220 #define __FLT32_MANT_DIG__ 24 221 #define __FLOAT_WORD_ORDER__ __ORDER_LITTLE_ENDIAN__ 222 #define SIZEOF_DPTR (sizeof(void*)) 223 #define __cpp_aggregate_bases 201603L 224 #define __FLT128_HAS_DENORM__ 1 225 #define __FLT32_DECIMAL_DIG__ 9 226 #define __FLT128_DIG__ 33 227 #define __INT32_C(c) c 228 #define __DEC64_EPSILON__ 1E-15DD 229 #define __ORDER_PDP_ENDIAN__ 3412 230 #define __DEC128_MIN_EXP__ (-6142) 231 #define __INT_FAST32_TYPE__ long int 232 #define __UINT_LEAST16_TYPE__ short unsigned int 234 #define __DBL_HAS_DENORM__ 1 235 #define VTKMDIY_MPI_AS_LIB 1 236 #define __cpp_rtti 199711L 237 #define __SIZE_TYPE__ long unsigned int 238 #define __UINT64_MAX__ 0xffffffffffffffffUL 239 #define __FLT_IS_IEC_60559__ 2 240 #define __GNUC_WIDE_EXECUTION_CHARSET_NAME "UTF-32LE" 241 #define __FLT64X_DIG__ 18 242 #define __INT8_TYPE__ signed char 243 #define __cpp_digit_separators 201309L 245 #define QT_HELP_LIB 1 246 #define __GCC_ASM_FLAG_OUTPUTS__ 1 247 #define __UINT32_TYPE__ unsigned int 248 #define __FLT_RADIX__ 2 249 #define __INT_LEAST16_TYPE__ short int 250 #define __LDBL_EPSILON__ 1.08420217248550443400745280086994171e-19L 251 #define __UINTMAX_C(c) c ## UL 252 #define __GNUC_RH_RELEASE__ 3 253 #define __GLIBCXX_BITSIZE_INT_N_0 128 255 #define __FLT32X_MIN__ 2.22507385850720138309023271733240406e-308F32x 256 #define __SIG_ATOMIC_MAX__ 0x7fffffff 257 #define __GCC_ATOMIC_WCHAR_T_LOCK_FREE 2 258 #define __SIZEOF_PTRDIFF_T__ 8 259 #define __LDBL_DIG__ 18 260 #define __FLT64_IS_IEC_60559__ 2 262 #define __FLT32X_MIN_EXP__ (-1021) 263 #define __DEC32_SUBNORMAL_MIN__ 0.000001E-95DF 264 #define __INT_FAST16_MAX__ 0x7fffffffffffffffL 265 #define __FLT64_DIG__ 15 266 #define __UINT_FAST32_MAX__ 0xffffffffffffffffUL 267 #define __UINT_LEAST64_TYPE__ long unsigned int 268 #define __FLT_HAS_QUIET_NAN__ 1 269 #define __FLT_MAX_10_EXP__ 38 270 #define __LONG_MAX__ 0x7fffffffffffffffL 271 #define __FLT64X_HAS_DENORM__ 1 272 #define __DEC128_SUBNORMAL_MIN__ 0.000000000000000000000000000000001E-6143DL 273 #define __FLT_HAS_INFINITY__ 1 274 #define __GNUC_EXECUTION_CHARSET_NAME "UTF-8" 275 #define __cpp_unicode_literals 200710L 276 #define __UINT_FAST16_TYPE__ long unsigned int 277 #define __DEC64_MAX__ 9.999999999999999E384DD 278 #define __INT_FAST32_WIDTH__ 64 279 #define __CHAR16_TYPE__ short unsigned int 280 #define __PRAGMA_REDEFINE_EXTNAME 1 281 #define __SIZE_WIDTH__ 64 283 #define __INT_LEAST16_MAX__ 0x7fff 284 #define __DEC64_MANT_DIG__ 16 285 #define __INT64_MAX__ 0x7fffffffffffffffL 286 #define QT_NETWORK_LIB 1 288 #define __FLT32_DENORM_MIN__ 1.40129846432481707092372958328991613e-45F32 289 #define __SIG_ATOMIC_WIDTH__ 32 290 #define __INT_LEAST64_TYPE__ long int 291 #define __INT16_TYPE__ short int 292 #define __INT_LEAST8_TYPE__ signed char 293 #define __cpp_structured_bindings 201606L 294 #define __SIZEOF_INT__ 4 295 #define __DEC32_MAX_EXP__ 97 296 #define __INT_FAST8_MAX__ 0x7f 297 #define __FLT128_MAX__ 1.18973149535723176508575932662800702e+4932F128 298 #define __INTPTR_MAX__ 0x7fffffffffffffffL 299 #define __cpp_sized_deallocation 201309L 300 #define __cpp_guaranteed_copy_elision 201606L 302 #define __FLT64_HAS_QUIET_NAN__ 1 303 #define __FLT32_MIN_10_EXP__ (-37) 304 #define __EXCEPTIONS 1 305 #define __PTRDIFF_WIDTH__ 64 306 #define __LDBL_MANT_DIG__ 64 307 #define __cpp_range_based_for 201603L 309 #define __FLT64_HAS_INFINITY__ 1 310 #define __FLT64X_MAX__ 1.18973149535723176502126385303097021e+4932F64x 311 #define __STDCPP_DEFAULT_NEW_ALIGNMENT__ 16 312 #define __SIG_ATOMIC_MIN__ (-__SIG_ATOMIC_MAX__ - 1) 313 #define __code_model_small__ 1 314 #define __GCC_ATOMIC_LONG_LOCK_FREE 2 315 #define __cpp_nontype_template_args 201411L 316 #define __DEC32_MANT_DIG__ 7 317 #define __cpp_return_type_deduction 201304L 319 #define __INTPTR_TYPE__ long int 320 #define __UINT16_TYPE__ short unsigned int 321 #define __WCHAR_TYPE__ int 322 #define __UINTPTR_MAX__ 0xffffffffffffffffUL 323 #define __INT_FAST64_WIDTH__ 64 324 #define __cpp_decltype 200707L 325 #define __INT_FAST64_MAX__ 0x7fffffffffffffffL 326 #define __GCC_ATOMIC_TEST_AND_SET_TRUEVAL 1 327 #define __FLT_NORM_MAX__ 3.40282346638528859811704183484516925e+38F 328 #define __FLT64X_MAX_EXP__ 16384 329 #define __UINT_FAST64_TYPE__ long unsigned int 330 #define __cpp_inline_variables 201606L 331 #define __INT_MAX__ 0x7fffffff 333 #define __INT64_TYPE__ long int 334 #define __FLT_MAX_EXP__ 128 335 #define __ORDER_BIG_ENDIAN__ 4321 336 #define __DBL_MANT_DIG__ 53 337 #define __cpp_inheriting_constructors 201511L 338 #define QT_CORE_LIB 1 339 #define __SIZEOF_FLOAT128__ 16 340 #define __INT_LEAST64_MAX__ 0x7fffffffffffffffL 341 #define __DEC64_MIN__ 1E-383DD 342 #define __WINT_TYPE__ unsigned int 343 #define __UINT_LEAST32_TYPE__ unsigned int 344 #define __SIZEOF_SHORT__ 2 345 #define __FLT32_NORM_MAX__ 3.40282346638528859811704183484516925e+38F32 347 #define MPI_NO_CPPBIND 1 348 #define __LDBL_MIN_EXP__ (-16381) 349 #define pqComponents_EXPORTS 1 350 #define MPICH_SKIP_MPICXX 1 351 #define __FLT64_MAX__ 1.79769313486231570814527423731704357e+308F64 353 #define __WINT_WIDTH__ 32 354 #define __INT_LEAST64_WIDTH__ 64 355 #define __LDBL_MAX_EXP__ 16384 356 #define __FLT32X_MAX_10_EXP__ 308 357 #define __SIZEOF_INT128__ 16 358 #define __FLT64X_IS_IEC_60559__ 2 359 #define __LDBL_MAX_10_EXP__ 4932 360 #define __ATOMIC_RELAXED 0 361 #define __DBL_EPSILON__ double(2.22044604925031308084726333618164062e-16L) 362 #define __FLT128_MIN__ 3.36210314311209350626267781732175260e-4932F128 364 #define __UINT8_C(c) c 365 #define __FLT64_MAX_EXP__ 1024 366 #define __INT_LEAST32_TYPE__ int 367 #define __SIZEOF_WCHAR_T__ 4 368 #define __GNUC_PATCHLEVEL__ 1 369 #define __FLT128_NORM_MAX__ 1.18973149535723176508575932662800702e+4932F128 370 #define __FLT64_NORM_MAX__ 1.79769313486231570814527423731704357e+308F64 371 #define __FLT128_HAS_QUIET_NAN__ 1 372 #define __INTMAX_MAX__ 0x7fffffffffffffffL 373 #define __INT_FAST8_TYPE__ signed char 374 #define __cpp_namespace_attributes 201411L 375 #define __FLT64X_MIN__ 3.36210314311209350626267781732175260e-4932F64x 377 #define __STDCPP_THREADS__ 1 378 #define __GNUC_STDC_INLINE__ 1 379 #define __FLT64_HAS_DENORM__ 1 380 #define __FLT32_EPSILON__ 1.19209289550781250000000000000000000e-7F32 381 #define __DBL_DECIMAL_DIG__ 17 382 #define __STDC_UTF_32__ 1 383 #define __INT_FAST8_WIDTH__ 8 385 #define __FLT32X_MAX__ 1.79769313486231570814527423731704357e+308F32x 386 #define __DBL_NORM_MAX__ double(1.79769313486231570814527423731704357e+308L) 387 #define __BYTE_ORDER__ __ORDER_LITTLE_ENDIAN__ 388 #define __INTMAX_WIDTH__ 64 389 #define __cpp_runtime_arrays 198712L 390 #define __UINT64_TYPE__ long unsigned int 391 #define __UINT32_C(c) c ## U 392 #define __cpp_alias_templates 200704L 393 #define __FLT_DENORM_MIN__ 1.40129846432481707092372958328991613e-45F 394 #define __FLT128_IS_IEC_60559__ 2 395 #define VTK_MODULE_ENABLE_VTK_ParallelMPI 1 396 #define __INT8_MAX__ 0x7f 397 #define __LONG_WIDTH__ 64 398 #define __UINT_FAST32_TYPE__ long unsigned int 399 #define __FLT32X_NORM_MAX__ 1.79769313486231570814527423731704357e+308F32x 400 #define __CHAR32_TYPE__ unsigned int 401 #define VTKMDIY_NO_THREADS 1 402 #define __FLT_MAX__ 3.40282346638528859811704183484516925e+38F 403 #define __cpp_constexpr 201603L 405 #define __cpp_deduction_guides 201703L 406 #define __INT32_TYPE__ int 407 #define __SIZEOF_DOUBLE__ 8 408 #define __cpp_exceptions 199711L 409 #define __FLT_MIN_10_EXP__ (-37) 410 #define __FLT64_MIN__ 2.22507385850720138309023271733240406e-308F64 411 #define __INT_LEAST32_WIDTH__ 32 412 #define __INTMAX_TYPE__ long int 413 #define __DEC128_MAX_EXP__ 6145 414 #define __FLT32X_HAS_QUIET_NAN__ 1 415 #define __ATOMIC_CONSUME 1 416 #define __GNUC_MINOR__ 3 417 #define __GLIBCXX_TYPE_INT_N_0 __int128 418 #define __INT_FAST16_WIDTH__ 64 419 #define __UINTMAX_MAX__ 0xffffffffffffffffUL 420 #define __FLT32X_DENORM_MIN__ 4.94065645841246544176568792868221372e-324F32x 421 #define __cpp_template_template_args 201611L 422 #define __DBL_MAX_10_EXP__ 308 423 #define __LDBL_DENORM_MIN__ 3.64519953188247460252840593361941982e-4951L 424 #define __INT16_C(c) c 426 #define __FLT32X_DIG__ 15 427 #define __PTRDIFF_TYPE__ long int 428 #define __ATOMIC_SEQ_CST 5 429 #define __FLT32X_MIN_10_EXP__ (-307) 430 #define __UINTPTR_TYPE__ long unsigned int 431 #define __DEC64_SUBNORMAL_MIN__ 0.000000000000001E-383DD 432 #define __DEC128_MANT_DIG__ 34 433 #define __LDBL_MIN_10_EXP__ (-4931) 434 #define __cpp_generic_lambdas 201304L 435 #define __SSE_MATH__ 1 436 #define __SIZEOF_LONG_LONG__ 8 437 #define __cpp_user_defined_literals 200809L 438 #define __FLT128_DECIMAL_DIG__ 36 439 #define __GCC_ATOMIC_LLONG_LOCK_FREE 2 440 #define __FLT32_HAS_QUIET_NAN__ 1 441 #define __FLT_DECIMAL_DIG__ 9 442 #define __UINT_FAST16_MAX__ 0xffffffffffffffffUL 443 #define __LDBL_NORM_MAX__ 1.18973149535723176502126385303097021e+4932L 444 #define __GCC_ATOMIC_SHORT_LOCK_FREE 2 445 #define __UINT_FAST8_TYPE__ unsigned char 446 #define _GNU_SOURCE 1 447 #define __cpp_init_captures 201304L 448 #define __ATOMIC_ACQ_REL 4 449 #define __ATOMIC_RELEASE 3
