1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Qt/Python 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonUtils.h" 48 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqTextLinkerPython.h" 49 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqLinkedObjectPythonTextArea.h" 50 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonCalculatorCompleter.h" 51 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonCompleter.h" 52 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonDebugLeaksView.h" 53 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonEditorActions.h" 54 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonFileIO.h" 55 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonLineNumberArea.h" 56 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonMacroSettings.h" 57 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonMacroSupervisor.h" 58 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonManager.h" 59 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonScriptEditor.h" 60 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonShell.h" 61 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonShellCompleter.h" 62 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonSyntaxHighlighter.h" 63 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonTabWidget.h" 64 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonTextArea.h" 65 "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonUndoCommand.h" 66 "/builds/gitlab-kitware-sciviz-ci/build/Qt/Python/pqPythonModule.h" 70 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 72 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so.5.13
" 73 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so.1
" 75 if(EXISTS "${file}
" AND 76 NOT IS_SYMLINK "${file}
") 79 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 82 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 83 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqPython-pv5.13.so.5.13
" 84 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqPython-pv5.13.so.1
" 87 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so.5.13
" 88 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so.1
" 90 if(EXISTS "${file}
" AND 91 NOT IS_SYMLINK "${file}
") 94 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 95 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 96 if(CMAKE_INSTALL_DO_STRIP) 97 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 103 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 104 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so
" AND 105 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so
") 107 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so
" 108 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 110 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqPython-pv5.13.so
") 111 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so
" AND 112 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so
") 114 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so
" 115 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 116 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 117 if(CMAKE_INSTALL_DO_STRIP) 118 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so
