1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/ThirdParty/IceT/vtkicet/src
47  include("/builds/gitlab-kitware-sciviz-ci/build/ThirdParty/IceT/vtkicet/src/ice-t/cmake_install.cmake")
48 endif()
49
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51  # Include the install script for the subdirectory.
52  include("/builds/gitlab-kitware-sciviz-ci/build/ThirdParty/IceT/vtkicet/src/communication/cmake_install.cmake")
53 endif()
54
55 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
56  # Include the install script for the subdirectory.
57  include("/builds/gitlab-kitware-sciviz-ci/build/ThirdParty/IceT/vtkicet/src/gl/cmake_install.cmake")
58 endif()
59
