1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/adaptors" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/adaptors/explorers.py")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/adaptors" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/adaptors/__init__.py")
51 endif()
52
53 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/adaptors/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/adaptors/paraview/cinemareader.py")
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/adaptors/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/adaptors/paraview/__init__.py")
59 endif()
60
61 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/adaptors/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/adaptors/paraview/progress.py")
63 endif()
64
65 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/adaptors/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/adaptors/paraview/pv_explorers.py")
67 endif()
68
69 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/adaptors/paraview" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/adaptors/paraview/pv_introspect.py")
71 endif()
72
73 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/database" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/database/file_store.py")
75 endif()
76
77 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/database" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/database/__init__.py")
79 endif()
80
81 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/database" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/database/oexr_helper.py")
83 endif()
84
85 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/database" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/database/raster_wrangler.py")
87 endif()
88
89 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/database" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/database/store.py")
91 endif()
92
93 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/database" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/database/vti_store.py")
95 endif()
96
97 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
98  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/images" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/images/camera_utils.py")
99 endif()
100
101 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
102  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/images" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/images/compositor.py")
103 endif()
104
105 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
106  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/images" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/images/__init__.py")
107 endif()
108
109 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
110  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/images" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/images/layer_rasters.py")
111 endif()
112
113 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
114  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/images" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/images/lookup_tables.py")
115 endif()
116
117 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
118  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/images" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/images/querymaker.py")
119 endif()
120
121 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
122  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python/images" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/images/querymaker_specb.py")
123 endif()
124
125 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
126  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinema_python" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/cinema_python/__init__.py")
127 endif()
128
129 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensesx" OR NOT CMAKE_INSTALL_COMPONENT)
130  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/CinemaPython" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinema/paraview/tpl/LICENSE")
131 endif()
132
progress
