1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
"xpythonx" OR NOT CMAKE_INSTALL_COMPONENT)
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci" TYPE FILE FILES
"/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/__init__.py")
49 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xpythonx
" OR NOT CMAKE_INSTALL_COMPONENT) 50 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/cdb
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/cdb/__init__.py
") 53 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 54 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/cis/
convert" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/
convert/__init__.py
" OR NOT CMAKE_INSTALL_COMPONENT) 58 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/cis/
convert/ascent.py
") 61 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 62 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/cis
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/__init__.py
") 65 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 66 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/cis
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/channel.py
") 69 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 70 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/cis
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/cisview.py
") 73 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 74 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/cis
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/colormap.py
") 77 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 78 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/cis
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/imageview.py
") 81 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 82 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/cis
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/layer.py
") 85 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 86 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/cis
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/cis/renderer.py
") 89 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/pynb/cis
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/pynb/cis/__init__.py
") 93 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 94 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/server
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/server/__init__.py
") 97 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 98 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/server
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/server/__main__.py
") 101 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 102 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/server
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/server/cinema_test.html
") 105 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 106 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/server
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/server/error_no-database.html
") 109 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 110 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/explorer/2.2/css
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/explorer/2.2/css/viewer.css
") 113 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 114 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/explorer/2.2/js
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/explorer/2.2/js/main.js
") 117 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 118 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/explorer/2.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/explorer/2.2/databases.json
") 121 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 122 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/lib/2.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/lib/2.2/common.css
") 125 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 126 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/lib/2.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/lib/2.2/databases.js
") 129 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 130 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/lib
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/lib/cinemacomponents.license.md
") 133 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 134 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/lib
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/lib/CinemaComponents.v2.7.1.min.css
") 137 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 138 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/lib
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/lib/CinemaComponents.v2.7.1.min.js
") 141 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 142 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/lib
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/lib/d3.license.md
") 145 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 146 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/lib
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/lib/d3.v4.min.js
") 149 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 150 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/lib
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/lib/d3.v5.min.js
") 153 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 154 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/lib/2.2/img
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/lib/2.2/img/empty.png
") 157 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 158 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/lib/2.2/img
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/lib/2.2/img/cinema_logo_filmreel_named_100px_white.png
") 161 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 162 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/simple/2.2/css
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/simple/2.2/css/compare.css
") 165 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 166 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.2/css
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.2/css/
range-css.css
") 169 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 170 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.2/css
range-css.textClipping
") 173 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 174 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.2/css
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.2/css/select-css.css
") 177 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 178 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.2/cinema_attributes_example.json
") 181 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 182 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.2
copyright.md
") 185 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 186 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.2/databases.json
") 189 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 190 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.2/license.md
") 193 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 194 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers/cinema/view/2.2
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema/view/2.2/main.js
") 197 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 198 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/__init__.py
") 201 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 202 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema_explorer.html
") 205 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 206 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema_simple.html
") 209 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 210 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/cinema_view.html
") 213 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 214 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/license.md
") 217 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 218 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/readme.md
") 221 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 222 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/testplan_explorer.html
") 225 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 226 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/cinemasci/viewers/testplan_view.html
") 229 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 230 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/python3.10/site-packages/paraview/tpl/cinemasci/viewers
version.md
") 233 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensesx
" OR NOT CMAKE_INSTALL_COMPONENT) 234 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/CinemaSci
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/ThirdParty/cinemasci/paraview/tpl/license.md
bool convert(const std::string &num, T &t)
