1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Utilities/Versioning
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVVersioning-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVersioning-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
50 endif()
51
52 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
53  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES
54  "/builds/gitlab-kitware-sciviz-ci/Utilities/Versioning/vtkParaViewDeprecation.h"
55  "/builds/gitlab-kitware-sciviz-ci/build/Utilities/Versioning/vtkPVVersion.h"
56  "/builds/gitlab-kitware-sciviz-ci/build/Utilities/Versioning/vtkPVVersionQuick.h"
57  )
58 endif()
59
60 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
61 endif()
62
63 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses" OR NOT CMAKE_INSTALL_COMPONENT)
64  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkPVVersioning" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Utilities/Versioning/LICENSE")
65 endif()
66
67 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
68  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Utilities/Versioning/vtkPVVersioning.spdx")
69 endif()
70
