1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/ExtractionPython
47  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/ExtractionPython/vtkPythonSelector.h"
48  "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/ExtractionPython/vtkPVVTKExtensionsExtractionPythonModule.h"
49  )
50 endif()
51
52 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
53  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVVTKExtensionsExtractionPython-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsExtractionPython-hierarchy.txt")
54 endif()
55
56 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
57  foreach(file
58  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so.5.13"
59  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so.1"
60  )
61  if(EXISTS "${file}" AND
62  NOT IS_SYMLINK "${file}")
63  file(RPATH_CHECK
64  FILE "${file}"
65  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
66  endif()
67  endforeach()
68  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
69  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so.5.13"
70  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so.1"
71  )
72  foreach(file
73  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so.5.13"
74  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so.1"
75  )
76  if(EXISTS "${file}" AND
77  NOT IS_SYMLINK "${file}")
78  file(RPATH_CHANGE
79  FILE "${file}"
80  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
81  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
82  if(CMAKE_INSTALL_DO_STRIP)
83  execute_process(COMMAND "/usr/bin/strip" "${file}")
84  endif()
85  endif()
86  endforeach()
87 endif()
88
89 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
90  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so" AND
91  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so")
92  file(RPATH_CHECK
93  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so"
94  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
95  endif()
96  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so")
97  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so" AND
98  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so")
99  file(RPATH_CHANGE
100  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so"
101  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
102  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
103  if(CMAKE_INSTALL_DO_STRIP)
104  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsExtractionPython-pv5.13.so")
105  endif()
106  endif()
107 endif()
108
