1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"vtkCommonExecutionModel-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkCommonExecutionModel-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonExecutionModel-pv6.0.so.6.0
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonExecutionModel-pv6.0.so.1
" 54 if(EXISTS "${file}
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonExecutionModel-pv6.0.so.6.0
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonExecutionModel-pv6.0.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonExecutionModel-pv6.0.so.6.0
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonExecutionModel-pv6.0.so.1
" 69 if(EXISTS "${file}
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonExecutionModel-pv6.0.so
" OR NOT CMAKE_INSTALL_COMPONENT) 87 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkTemporalAlgorithm.txx
") 90 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 91 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES 92 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkAggregateToPartitionedDataSetCollection.h
" 93 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/
vtkAlgorithm.h
" 99 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkCellGridAlgorithm.h
" 106 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkEndFor.h
" 108 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkExecutionAggregator.h
" 109 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkExecutionRange.h
" 110 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/
vtkExecutive.h
" 111 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkExplicitStructuredGridAlgorithm.h
" 116 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkForEach.h
" 132 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkParallelReader.h
" 133 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkPartitionedDataSetAlgorithm.h
" 134 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkPartitionedDataSetCollectionAlgorithm.h
" 141 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkReaderAlgorithm.h
" 144 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/
vtkScalarTree.h
" 147 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkSimpleReader.h
" 149 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/
vtkSpanSpace.h
" 150 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkSphereTree.h
" 156 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkTimeRange.h
" 157 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/
vtkTreeAlgorithm.h
" 167 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/vtkTemporalAlgorithm.h
" 171 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 172 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES 173 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Common/ExecutionModel/vtkCommonExecutionModelModule.h
" 174 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Common/ExecutionModel/vtkCommonExecutionModelSerDes.h
" 178 if(CMAKE_INSTALL_COMPONENT STREQUAL "licenses
" OR NOT CMAKE_INSTALL_COMPONENT) 179 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkCommonExecutionModel
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Common/ExecutionModel/LICENSE
") 182 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 183 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Common/ExecutionModel/vtkCommonExecutionModel.spdx
