1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Common/Math
47  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkTuple.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkAmoebaMinimizer.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkFFT.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkFunctionSet.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkInitialValueProblemSolver.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkMatrix3x3.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkMatrix4x4.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkPolynomialSolversUnivariate.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkQuaternionInterpolator.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkRungeKutta2.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkRungeKutta4.h"
58  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkRungeKutta45.h"
59  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkQuaternion.h"
60  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkReservoirSampler.h"
61  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Common/Math/vtkCommonMathModule.h"
62  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkFFT.txx"
63  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/vtkQuaternion.txx"
64  )
65 endif()
66
67 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
68  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkCommonMath-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkCommonMath-hierarchy.txt")
69 endif()
70
71 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
72  foreach(file
73  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMath-pv5.13.so.5.13"
74  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMath-pv5.13.so.1"
75  )
76  if(EXISTS "${file}" AND
77  NOT IS_SYMLINK "${file}")
78  file(RPATH_CHECK
79  FILE "${file}"
80  RPATH "\$ORIGIN")
81  endif()
82  endforeach()
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
84  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonMath-pv5.13.so.5.13"
85  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonMath-pv5.13.so.1"
86  )
87  foreach(file
88  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMath-pv5.13.so.5.13"
89  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMath-pv5.13.so.1"
90  )
91  if(EXISTS "${file}" AND
92  NOT IS_SYMLINK "${file}")
93  file(RPATH_CHANGE
94  FILE "${file}"
95  OLD_RPATH "\$ORIGIN:"
96  NEW_RPATH "\$ORIGIN")
97  if(CMAKE_INSTALL_DO_STRIP)
98  execute_process(COMMAND "/usr/bin/strip" "${file}")
99  endif()
100  endif()
101  endforeach()
102 endif()
103
104 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
105  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMath-pv5.13.so" AND
106  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMath-pv5.13.so")
107  file(RPATH_CHECK
108  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMath-pv5.13.so"
109  RPATH "\$ORIGIN")
110  endif()
111  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonMath-pv5.13.so")
112  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMath-pv5.13.so" AND
113  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMath-pv5.13.so")
114  file(RPATH_CHANGE
115  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMath-pv5.13.so"
116  OLD_RPATH "\$ORIGIN:"
117  NEW_RPATH "\$ORIGIN")
118  if(CMAKE_INSTALL_DO_STRIP)
119  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMath-pv5.13.so")
120  endif()
121  endif()
122 endif()
123
124 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensesx" OR NOT CMAKE_INSTALL_COMPONENT)
125  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkCommonMath" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Math/LICENSE")
126 endif()
127
128 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xspdxx" OR NOT CMAKE_INSTALL_COMPONENT)
129  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Common/Math/vtkCommonMath.spdx")
130 endif()
131
