1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Common/System 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/System/vtkClientSocket.h" 48 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/System/vtkDirectory.h" 49 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/System/vtkExecutableRunner.h" 50 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/System/vtkServerSocket.h" 51 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/System/vtkSocket.h" 52 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/System/vtkSocketCollection.h" 53 "/builds/gitlab-kitware-sciviz-ci/VTK/Common/System/vtkTimerLog.h" 54 "/builds/gitlab-kitware-sciviz-ci/build/VTK/Common/System/vtkCommonSystemModule.h" 58 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 59 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkCommonSystem-hierarchy.txt
vtk/hierarchy/ParaView/vtkCommonSystem-hierarchy.txt
") 62 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 64 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonSystem-pv5.13.so.5.13
" 65 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonSystem-pv5.13.so.1
" 67 if(EXISTS "${file}
" AND 68 NOT IS_SYMLINK "${file}
") 74 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 75 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonSystem-pv5.13.so.5.13
" 76 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonSystem-pv5.13.so.1
" 79 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonSystem-pv5.13.so.5.13
" 80 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonSystem-pv5.13.so.1
" 82 if(EXISTS "${file}
" AND 83 NOT IS_SYMLINK "${file}
") 88 if(CMAKE_INSTALL_DO_STRIP) 89 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 95 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 96 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonSystem-pv5.13.so
" AND 97 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonSystem-pv5.13.so
") 99 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonSystem-pv5.13.so
" 102 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonSystem-pv5.13.so
") 103 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonSystem-pv5.13.so
" AND 104 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonSystem-pv5.13.so
") 106 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonSystem-pv5.13.so
" 107 OLD_RPATH "\$ORIGIN:
" 108 NEW_RPATH "\$ORIGIN
") 109 if(CMAKE_INSTALL_DO_STRIP) 110 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonSystem-pv5.13.so
") 115 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xspdxx
" OR NOT CMAKE_INSTALL_COMPONENT) 116 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Common/System/vtkCommonSystem.spdx
