1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkCommonTransforms-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkCommonTransforms-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv6.0.so.6.0"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv6.0.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonTransforms-pv6.0.so.6.0"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonTransforms-pv6.0.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv6.0.so.6.0"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonTransforms-pv6.0.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:"
74  NEW_RPATH "\$ORIGIN")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/bin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonTransforms-pv6.0.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkAbstractTransform.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkCylindricalTransform.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkGeneralTransform.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkHomogeneousTransform.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkIdentityTransform.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkLandmarkTransform.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkLinearTransform.h"
98  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkMatrixToHomogeneousTransform.h"
99  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkMatrixToLinearTransform.h"
100  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkPerspectiveTransform.h"
101  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkSphericalTransform.h"
102  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkThinPlateSplineTransform.h"
103  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkTransform.h"
104  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkTransform2D.h"
105  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkTransformCollection.h"
106  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Transforms/vtkWarpTransform.h"
107  )
108 endif()
109
110 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
111  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES
112  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Common/Transforms/vtkCommonTransformsModule.h"
113  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Common/Transforms/vtkCommonTransformsSerDes.h"
114  )
115 endif()
116
117 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
118  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Common/Transforms/vtkCommonTransforms.spdx")
119 endif()
120
