moc_predefs.h
1 #define __DBL_MIN_EXP__ (-1021)
2 #define __cpp_attributes 200809L
3 #define __cpp_nontype_template_parameter_auto 201606L
4 #define __UINT_LEAST16_MAX__ 0xffff
5 #define __ATOMIC_ACQUIRE 2
6 #define __FLT128_MAX_10_EXP__ 4932
7 #define __FLT_MIN__ 1.17549435082228750796873653722224568e-38F
8 #define __GCC_IEC_559_COMPLEX 2
9 #define __cpp_aggregate_nsdmi 201304L
10 #define __UINT_LEAST8_TYPE__ unsigned char
11 #define __SIZEOF_FLOAT80__ 16
12 #define __INTMAX_C(c) c ## L
13 #define __CHAR_BIT__ 8
14 #define __UINT8_MAX__ 0xff
15 #define __SCHAR_WIDTH__ 8
16 #define __WINT_MAX__ 0xffffffffU
17 #define __FLT32_MIN_EXP__ (-125)
18 #define __cpp_static_assert 201411L
19 #define QT_GUI_LIB 1
20 #define __ORDER_LITTLE_ENDIAN__ 1234
21 #define __SIZE_MAX__ 0xffffffffffffffffUL
22 #define __WCHAR_MAX__ 0x7fffffff
23 #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_1 1
24 #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_2 1
25 #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_4 1
26 #define __DBL_DENORM_MIN__ double(4.94065645841246544176568792868221372e-324L)
27 #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_8 1
28 #define __GCC_ATOMIC_CHAR_LOCK_FREE 2
29 #define __GCC_IEC_559 2
30 #define __FLT32X_DECIMAL_DIG__ 17
31 #define __FLT_EVAL_METHOD__ 0
32 #define __cpp_binary_literals 201304L
33 #define __FLT64_DECIMAL_DIG__ 17
34 #define __cpp_noexcept_function_type 201510L
35 #define __GCC_ATOMIC_CHAR32_T_LOCK_FREE 2
36 #define __cpp_variadic_templates 200704L
37 #define __UINT_FAST64_MAX__ 0xffffffffffffffffUL
38 #define __SIG_ATOMIC_TYPE__ int
39 #define __DBL_MIN_10_EXP__ (-307)
40 #define __FINITE_MATH_ONLY__ 0
41 #define __cpp_variable_templates 201304L
42 #define __FLT32X_MAX_EXP__ 1024
43 #define __FLT32_HAS_DENORM__ 1
44 #define __UINT_FAST8_MAX__ 0xff
45 #define __cpp_rvalue_reference 200610L
46 #define __cpp_nested_namespace_definitions 201411L
47 #define __DEC64_MAX_EXP__ 385
48 #define __INT8_C(c) c
49 #define __INT_LEAST8_WIDTH__ 8
50 #define __cpp_variadic_using 201611L
51 #define __UINT_LEAST64_MAX__ 0xffffffffffffffffUL
52 #define QT_OPENGL_LIB 1
53 #define __INT_LEAST8_MAX__ 0x7f
54 #define __cpp_capture_star_this 201603L
55 #define __SHRT_MAX__ 0x7fff
56 #define __LDBL_MAX__ 1.18973149535723176502126385303097021e+4932L
57 #define __FLT64X_MAX_10_EXP__ 4932
58 #define __cpp_if_constexpr 201606L
59 #define __LDBL_IS_IEC_60559__ 2
60 #define __FLT64X_HAS_QUIET_NAN__ 1
61 #define __UINT_LEAST8_MAX__ 0xff
62 #define __GCC_ATOMIC_BOOL_LOCK_FREE 2
63 #define __FLT128_DENORM_MIN__ 6.47517511943802511092443895822764655e-4966F128
64 #define __UINTMAX_TYPE__ long unsigned int
65 #define __linux 1
66 #define __DEC32_EPSILON__ 1E-6DF
67 #define __FLT_EVAL_METHOD_TS_18661_3__ 0
68 #define __unix 1
69 #define __UINT32_MAX__ 0xffffffffU
70 #define __GXX_EXPERIMENTAL_CXX0X__ 1
71 #define __FLT128_MIN_EXP__ (-16381)
72 #define __WINT_MIN__ 0U
73 #define __FLT128_MIN_10_EXP__ (-4931)
74 #define __FLT32X_IS_IEC_60559__ 2
75 #define __INT_LEAST16_WIDTH__ 16
76 #define __SCHAR_MAX__ 0x7f
77 #define __FLT128_MANT_DIG__ 113
78 #define __WCHAR_MIN__ (-__WCHAR_MAX__ - 1)
79 #define __INT64_C(c) c ## L
80 #define __GCC_ATOMIC_POINTER_LOCK_FREE 2
81 #define __FLT32X_MANT_DIG__ 53
82 #define __GCC_ATOMIC_CHAR16_T_LOCK_FREE 2
83 #define __cpp_aligned_new 201606L
84 #define __USER_LABEL_PREFIX__
85 #define __FLT32_MAX_10_EXP__ 38
86 #define __FLT64X_EPSILON__ 1.08420217248550443400745280086994171e-19F64x
87 #define __STDC_HOSTED__ 1
88 #define __DEC64_MIN_EXP__ (-382)
89 #define __cpp_decltype_auto 201304L
90 #define __DBL_DIG__ 15
91 #define __FLT32_DIG__ 6
92 #define __FLT_EPSILON__ 1.19209289550781250000000000000000000e-7F
93 #define __GXX_WEAK__ 1
94 #define __SHRT_WIDTH__ 16
95 #define __FLT32_IS_IEC_60559__ 2
96 #define __LDBL_MIN__ 3.36210314311209350626267781732175260e-4932L
97 #define __DBL_IS_IEC_60559__ 2
98 #define __DEC32_MAX__ 9.999999E96DF
99 #define __cpp_threadsafe_static_init 200806L
100 #define __cpp_enumerator_attributes 201411L
101 #define __FLT64X_DENORM_MIN__ 3.64519953188247460252840593361941982e-4951F64x
102 #define __FLT32X_HAS_INFINITY__ 1
103 #define __INT32_MAX__ 0x7fffffff
104 #define __unix__ 1
105 #define __INT_WIDTH__ 32
106 #define __SIZEOF_LONG__ 8
107 #define __STDC_IEC_559__ 1
108 #define __STDC_ISO_10646__ 201706L
109 #define __UINT16_C(c) c
110 #define __DECIMAL_DIG__ 21
111 #define __STDC_IEC_559_COMPLEX__ 1
112 #define __FLT64_EPSILON__ 2.22044604925031308084726333618164062e-16F64
113 #define __gnu_linux__ 1
114 #define __INT16_MAX__ 0x7fff
115 #define __FLT64_MIN_EXP__ (-1021)
116 #define vtkRenderingCore_AUTOINIT_INCLUDE "/builds/gitlab-kitware-sciviz-ci/build/CMakeFiles/vtkModuleAutoInit_be7301261a49b13d6a9b1d9e110eacd8.h"
117 #define __FLT64X_MIN_10_EXP__ (-4931)
118 #define __LDBL_HAS_QUIET_NAN__ 1
119 #define __FLT64_MANT_DIG__ 53
120 #define __FLT64X_MANT_DIG__ 64
121 #define __GNUC__ 11
122 #define __GXX_RTTI 1
123 #define __MMX__ 1
124 #define __FLT_HAS_DENORM__ 1
125 #define __SIZEOF_LONG_DOUBLE__ 16
126 #define __BIGGEST_ALIGNMENT__ 16
127 #define __STDC_UTF_16__ 1
128 #define __FLT64_MAX_10_EXP__ 308
129 #define __cpp_delegating_constructors 200604L
130 #define __FLT32_HAS_INFINITY__ 1
131 #define __DBL_MAX__ double(1.79769313486231570814527423731704357e+308L)
132 #define __cpp_raw_strings 200710L
133 #define __INT_FAST32_MAX__ 0x7fffffffffffffffL
134 #define __DBL_HAS_INFINITY__ 1
135 #define __SIZEOF_FLOAT__ 4
136 #define __HAVE_SPECULATION_SAFE_VALUE 1
137 #define __cpp_fold_expressions 201603L
138 #define __DEC32_MIN_EXP__ (-94)
139 #define __INTPTR_WIDTH__ 64
140 #define __FLT64X_HAS_INFINITY__ 1
141 #define __UINT_LEAST32_MAX__ 0xffffffffU
142 #define __FLT32X_HAS_DENORM__ 1
143 #define __INT_FAST16_TYPE__ long int
144 #define __MMX_WITH_SSE__ 1
145 #define __LDBL_HAS_DENORM__ 1
146 #define QT_WIDGETS_LIB 1
147 #define __cplusplus 201703L
148 #define __cpp_ref_qualifiers 200710L
149 #define __DEC32_MIN__ 1E-95DF
150 #define __DEPRECATED 1
151 #define __cpp_rvalue_references 200610L
152 #define __DBL_MAX_EXP__ 1024
153 #define __WCHAR_WIDTH__ 32
154 #define __FLT32_MAX__ 3.40282346638528859811704183484516925e+38F32
155 #define __DEC128_EPSILON__ 1E-33DL
156 #define __SSE2_MATH__ 1
157 #define __ATOMIC_HLE_RELEASE 131072
158 #define __PTRDIFF_MAX__ 0x7fffffffffffffffL
159 #define __amd64 1
160 #define __ATOMIC_HLE_ACQUIRE 65536
161 #define __GNUG__ 11
162 #define __LONG_LONG_MAX__ 0x7fffffffffffffffLL
163 #define __SIZEOF_SIZE_T__ 8
164 #define __cpp_nsdmi 200809L
165 #define __FLT64X_MIN_EXP__ (-16381)
166 #define __SIZEOF_WINT_T__ 4
167 #define __LONG_LONG_WIDTH__ 64
168 #define __cpp_initializer_lists 200806L
169 #define __FLT32_MAX_EXP__ 128
170 #define ABI_ID "ELF"
171 #define __cpp_hex_float 201603L
172 #define __GXX_ABI_VERSION 1016
173 #define __FLT128_HAS_INFINITY__ 1
174 #define kiss_fft_scalar double
175 #define __FLT_MIN_EXP__ (-125)
176 #define __GCC_HAVE_DWARF2_CFI_ASM 1
177 #define __x86_64 1
178 #define __cpp_lambdas 200907L
179 #define __INT_FAST64_TYPE__ long int
180 #define __FLT64_DENORM_MIN__ 4.94065645841246544176568792868221372e-324F64
181 #define __cpp_template_auto 201606L
182 #define __DBL_MIN__ double(2.22507385850720138309023271733240406e-308L)
183 #define __FLT128_EPSILON__ 1.92592994438723585305597794258492732e-34F128
184 #define __FLT64X_NORM_MAX__ 1.18973149535723176502126385303097021e+4932F64x
185 #define __SIZEOF_POINTER__ 8
186 #define __LP64__ 1
187 #define __DBL_HAS_QUIET_NAN__ 1
188 #define __FLT32X_EPSILON__ 2.22044604925031308084726333618164062e-16F32x
189 #define __DECIMAL_BID_FORMAT__ 1
190 #define __FLT64_MIN_10_EXP__ (-307)
191 #define __FLT64X_DECIMAL_DIG__ 21
192 #define __DEC128_MIN__ 1E-6143DL
193 #define __REGISTER_PREFIX__
194 #define __UINT16_MAX__ 0xffff
195 #define __LDBL_HAS_INFINITY__ 1
196 #define __FLT32_MIN__ 1.17549435082228750796873653722224568e-38F32
197 #define __UINT8_TYPE__ unsigned char
198 #define __FLT_DIG__ 6
199 #define __NO_INLINE__ 1
200 #define __DEC_EVAL_METHOD__ 2
201 #define __DEC128_MAX__ 9.999999999999999999999999999999999E6144DL
202 #define QT_NO_KEYWORDS 1
203 #define __FLT_MANT_DIG__ 24
204 #define __LDBL_DECIMAL_DIG__ 21
205 #define __VERSION__ "11.3.1 20220421 (Red Hat 11.3.1-3)"
206 #define __UINT64_C(c) c ## UL
207 #define __cpp_unicode_characters 201411L
208 #define _STDC_PREDEF_H 1
209 #define GLAD_API_CALL_EXPORT 1
210 #define __INT_LEAST32_MAX__ 0x7fffffff
211 #define __GCC_ATOMIC_INT_LOCK_FREE 2
212 #define __FLT128_MAX_EXP__ 16384
213 #define __FLT32_MANT_DIG__ 24
214 #define __FLOAT_WORD_ORDER__ __ORDER_LITTLE_ENDIAN__
215 #define SIZEOF_DPTR (sizeof(void*))
216 #define __cpp_aggregate_bases 201603L
217 #define __FLT128_HAS_DENORM__ 1
218 #define __FLT32_DECIMAL_DIG__ 9
219 #define __FLT128_DIG__ 33
220 #define __INT32_C(c) c
221 #define __DEC64_EPSILON__ 1E-15DD
222 #define __ORDER_PDP_ENDIAN__ 3412
223 #define __DEC128_MIN_EXP__ (-6142)
224 #define __INT_FAST32_TYPE__ long int
225 #define __UINT_LEAST16_TYPE__ short unsigned int
226 #define unix 1
227 #define __DBL_HAS_DENORM__ 1
228 #define __cpp_rtti 199711L
229 #define __SIZE_TYPE__ long unsigned int
230 #define __UINT64_MAX__ 0xffffffffffffffffUL
231 #define __FLT_IS_IEC_60559__ 2
232 #define __GNUC_WIDE_EXECUTION_CHARSET_NAME "UTF-32LE"
233 #define __FLT64X_DIG__ 18
234 #define __INT8_TYPE__ signed char
235 #define __cpp_digit_separators 201309L
236 #define __ELF__ 1
237 #define __GCC_ASM_FLAG_OUTPUTS__ 1
238 #define __UINT32_TYPE__ unsigned int
239 #define __FLT_RADIX__ 2
240 #define __INT_LEAST16_TYPE__ short int
241 #define __LDBL_EPSILON__ 1.08420217248550443400745280086994171e-19L
242 #define __UINTMAX_C(c) c ## UL
243 #define __GNUC_RH_RELEASE__ 3
244 #define __GLIBCXX_BITSIZE_INT_N_0 128
245 #define __k8 1
246 #define __FLT32X_MIN__ 2.22507385850720138309023271733240406e-308F32x
247 #define __SIG_ATOMIC_MAX__ 0x7fffffff
248 #define __GCC_ATOMIC_WCHAR_T_LOCK_FREE 2
249 #define __SIZEOF_PTRDIFF_T__ 8
250 #define GUISupportQt_EXPORTS 1
251 #define __LDBL_DIG__ 18
252 #define __FLT64_IS_IEC_60559__ 2
253 #define __x86_64__ 1
254 #define __FLT32X_MIN_EXP__ (-1021)
255 #define __DEC32_SUBNORMAL_MIN__ 0.000001E-95DF
256 #define __INT_FAST16_MAX__ 0x7fffffffffffffffL
257 #define __FLT64_DIG__ 15
258 #define __UINT_FAST32_MAX__ 0xffffffffffffffffUL
259 #define __UINT_LEAST64_TYPE__ long unsigned int
260 #define __FLT_HAS_QUIET_NAN__ 1
261 #define __FLT_MAX_10_EXP__ 38
262 #define __LONG_MAX__ 0x7fffffffffffffffL
263 #define __FLT64X_HAS_DENORM__ 1
264 #define __DEC128_SUBNORMAL_MIN__ 0.000000000000000000000000000000001E-6143DL
265 #define __FLT_HAS_INFINITY__ 1
266 #define __GNUC_EXECUTION_CHARSET_NAME "UTF-8"
267 #define __cpp_unicode_literals 200710L
268 #define __UINT_FAST16_TYPE__ long unsigned int
269 #define __DEC64_MAX__ 9.999999999999999E384DD
270 #define __INT_FAST32_WIDTH__ 64
271 #define __CHAR16_TYPE__ short unsigned int
272 #define __PRAGMA_REDEFINE_EXTNAME 1
273 #define __SIZE_WIDTH__ 64
274 #define __SEG_FS 1
275 #define __INT_LEAST16_MAX__ 0x7fff
276 #define __DEC64_MANT_DIG__ 16
277 #define __INT64_MAX__ 0x7fffffffffffffffL
278 #define __SEG_GS 1
279 #define __FLT32_DENORM_MIN__ 1.40129846432481707092372958328991613e-45F32
280 #define __SIG_ATOMIC_WIDTH__ 32
281 #define __INT_LEAST64_TYPE__ long int
282 #define __INT16_TYPE__ short int
283 #define __INT_LEAST8_TYPE__ signed char
284 #define __cpp_structured_bindings 201606L
285 #define __SIZEOF_INT__ 4
286 #define __DEC32_MAX_EXP__ 97
287 #define __INT_FAST8_MAX__ 0x7f
288 #define __FLT128_MAX__ 1.18973149535723176508575932662800702e+4932F128
289 #define __INTPTR_MAX__ 0x7fffffffffffffffL
290 #define __cpp_sized_deallocation 201309L
291 #define __cpp_guaranteed_copy_elision 201606L
292 #define linux 1
293 #define __FLT64_HAS_QUIET_NAN__ 1
294 #define __FLT32_MIN_10_EXP__ (-37)
295 #define __EXCEPTIONS 1
296 #define __PTRDIFF_WIDTH__ 64
297 #define __LDBL_MANT_DIG__ 64
298 #define __cpp_range_based_for 201603L
299 #define __FLT64_HAS_INFINITY__ 1
300 #define __FLT64X_MAX__ 1.18973149535723176502126385303097021e+4932F64x
301 #define __STDCPP_DEFAULT_NEW_ALIGNMENT__ 16
302 #define __SIG_ATOMIC_MIN__ (-__SIG_ATOMIC_MAX__ - 1)
303 #define __code_model_small__ 1
304 #define __GCC_ATOMIC_LONG_LOCK_FREE 2
305 #define __cpp_nontype_template_args 201411L
306 #define __DEC32_MANT_DIG__ 7
307 #define __cpp_return_type_deduction 201304L
308 #define __k8__ 1
309 #define __INTPTR_TYPE__ long int
310 #define __UINT16_TYPE__ short unsigned int
311 #define __WCHAR_TYPE__ int
312 #define __UINTPTR_MAX__ 0xffffffffffffffffUL
313 #define __INT_FAST64_WIDTH__ 64
314 #define __cpp_decltype 200707L
315 #define __INT_FAST64_MAX__ 0x7fffffffffffffffL
316 #define __GCC_ATOMIC_TEST_AND_SET_TRUEVAL 1
317 #define __FLT_NORM_MAX__ 3.40282346638528859811704183484516925e+38F
318 #define __FLT64X_MAX_EXP__ 16384
319 #define __UINT_FAST64_TYPE__ long unsigned int
320 #define __cpp_inline_variables 201606L
321 #define __INT_MAX__ 0x7fffffff
322 #define __linux__ 1
323 #define __INT64_TYPE__ long int
324 #define __FLT_MAX_EXP__ 128
325 #define __ORDER_BIG_ENDIAN__ 4321
326 #define __DBL_MANT_DIG__ 53
327 #define __cpp_inheriting_constructors 201511L
328 #define QT_CORE_LIB 1
329 #define __SIZEOF_FLOAT128__ 16
330 #define __INT_LEAST64_MAX__ 0x7fffffffffffffffL
331 #define __DEC64_MIN__ 1E-383DD
332 #define __WINT_TYPE__ unsigned int
333 #define __UINT_LEAST32_TYPE__ unsigned int
334 #define __SIZEOF_SHORT__ 2
335 #define __FLT32_NORM_MAX__ 3.40282346638528859811704183484516925e+38F32
336 #define __SSE__ 1
337 #define __LDBL_MIN_EXP__ (-16381)
338 #define __FLT64_MAX__ 1.79769313486231570814527423731704357e+308F64
339 #define __amd64__ 1
340 #define __WINT_WIDTH__ 32
341 #define __INT_LEAST64_WIDTH__ 64
342 #define __LDBL_MAX_EXP__ 16384
343 #define __FLT32X_MAX_10_EXP__ 308
344 #define __SIZEOF_INT128__ 16
345 #define __FLT64X_IS_IEC_60559__ 2
346 #define __LDBL_MAX_10_EXP__ 4932
347 #define __ATOMIC_RELAXED 0
348 #define __DBL_EPSILON__ double(2.22044604925031308084726333618164062e-16L)
349 #define __FLT128_MIN__ 3.36210314311209350626267781732175260e-4932F128
350 #define _LP64 1
351 #define __UINT8_C(c) c
352 #define __FLT64_MAX_EXP__ 1024
353 #define __INT_LEAST32_TYPE__ int
354 #define __SIZEOF_WCHAR_T__ 4
355 #define __GNUC_PATCHLEVEL__ 1
356 #define __FLT128_NORM_MAX__ 1.18973149535723176508575932662800702e+4932F128
357 #define __FLT64_NORM_MAX__ 1.79769313486231570814527423731704357e+308F64
358 #define __FLT128_HAS_QUIET_NAN__ 1
359 #define __INTMAX_MAX__ 0x7fffffffffffffffL
360 #define __INT_FAST8_TYPE__ signed char
361 #define __cpp_namespace_attributes 201411L
362 #define __FLT64X_MIN__ 3.36210314311209350626267781732175260e-4932F64x
363 #define __STDCPP_THREADS__ 1
364 #define __GNUC_STDC_INLINE__ 1
365 #define __FLT64_HAS_DENORM__ 1
366 #define __FLT32_EPSILON__ 1.19209289550781250000000000000000000e-7F32
367 #define __DBL_DECIMAL_DIG__ 17
368 #define __STDC_UTF_32__ 1
369 #define __INT_FAST8_WIDTH__ 8
370 #define __FXSR__ 1
371 #define __FLT32X_MAX__ 1.79769313486231570814527423731704357e+308F32x
372 #define __DBL_NORM_MAX__ double(1.79769313486231570814527423731704357e+308L)
373 #define __BYTE_ORDER__ __ORDER_LITTLE_ENDIAN__
374 #define __INTMAX_WIDTH__ 64
375 #define __cpp_runtime_arrays 198712L
376 #define __UINT64_TYPE__ long unsigned int
377 #define __UINT32_C(c) c ## U
378 #define __cpp_alias_templates 200704L
379 #define __FLT_DENORM_MIN__ 1.40129846432481707092372958328991613e-45F
380 #define __FLT128_IS_IEC_60559__ 2
381 #define __INT8_MAX__ 0x7f
382 #define __LONG_WIDTH__ 64
383 #define __UINT_FAST32_TYPE__ long unsigned int
384 #define __FLT32X_NORM_MAX__ 1.79769313486231570814527423731704357e+308F32x
385 #define __CHAR32_TYPE__ unsigned int
386 #define __FLT_MAX__ 3.40282346638528859811704183484516925e+38F
387 #define __cpp_constexpr 201603L
388 #define __SSE2__ 1
389 #define __cpp_deduction_guides 201703L
390 #define __INT32_TYPE__ int
391 #define __SIZEOF_DOUBLE__ 8
392 #define __cpp_exceptions 199711L
393 #define __FLT_MIN_10_EXP__ (-37)
394 #define __FLT64_MIN__ 2.22507385850720138309023271733240406e-308F64
395 #define __INT_LEAST32_WIDTH__ 32
396 #define __INTMAX_TYPE__ long int
397 #define __DEC128_MAX_EXP__ 6145
398 #define __FLT32X_HAS_QUIET_NAN__ 1
399 #define __ATOMIC_CONSUME 1
400 #define __GNUC_MINOR__ 3
401 #define __GLIBCXX_TYPE_INT_N_0 __int128
402 #define __INT_FAST16_WIDTH__ 64
403 #define __UINTMAX_MAX__ 0xffffffffffffffffUL
404 #define __FLT32X_DENORM_MIN__ 4.94065645841246544176568792868221372e-324F32x
405 #define __cpp_template_template_args 201611L
406 #define __DBL_MAX_10_EXP__ 308
407 #define __LDBL_DENORM_MIN__ 3.64519953188247460252840593361941982e-4951L
408 #define __INT16_C(c) c
409 #define __STDC__ 1
410 #define __FLT32X_DIG__ 15
411 #define __PTRDIFF_TYPE__ long int
412 #define __ATOMIC_SEQ_CST 5
413 #define __FLT32X_MIN_10_EXP__ (-307)
414 #define __UINTPTR_TYPE__ long unsigned int
415 #define __DEC64_SUBNORMAL_MIN__ 0.000000000000001E-383DD
416 #define __DEC128_MANT_DIG__ 34
417 #define __LDBL_MIN_10_EXP__ (-4931)
418 #define __cpp_generic_lambdas 201304L
419 #define __SSE_MATH__ 1
420 #define __SIZEOF_LONG_LONG__ 8
421 #define __cpp_user_defined_literals 200809L
422 #define __FLT128_DECIMAL_DIG__ 36
423 #define __GCC_ATOMIC_LLONG_LOCK_FREE 2
424 #define __FLT32_HAS_QUIET_NAN__ 1
425 #define __FLT_DECIMAL_DIG__ 9
426 #define __UINT_FAST16_MAX__ 0xffffffffffffffffUL
427 #define __LDBL_NORM_MAX__ 1.18973149535723176502126385303097021e+4932L
428 #define __GCC_ATOMIC_SHORT_LOCK_FREE 2
429 #define __UINT_FAST8_TYPE__ unsigned char
430 #define _GNU_SOURCE 1
431 #define __cpp_init_captures 201304L
432 #define __ATOMIC_ACQ_REL 4
433 #define __ATOMIC_RELEASE 3
