1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/AMR
47  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/AMR/vtkAMRBaseParticlesReader.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/AMR/vtkAMRBaseReader.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/AMR/vtkAMRDataSetCache.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/AMR/vtkAMREnzoParticlesReader.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/AMR/vtkAMREnzoReader.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/AMR/vtkAMReXGridReader.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/AMR/vtkAMReXParticlesReader.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/AMR/vtkAMRFlashParticlesReader.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/AMR/vtkAMRFlashReader.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/AMR/vtkAMRVelodyneReader.h"
57  "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/AMR/vtkIOAMRModule.h"
58  )
59 endif()
60
61 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOAMR-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOAMR-hierarchy.txt")
63 endif()
64
65 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
66  foreach(file
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOAMR-pv5.13.so.5.13"
68  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOAMR-pv5.13.so.1"
69  )
70  if(EXISTS "${file}" AND
71  NOT IS_SYMLINK "${file}")
72  file(RPATH_CHECK
73  FILE "${file}"
74  RPATH "\$ORIGIN")
75  endif()
76  endforeach()
77  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
78  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOAMR-pv5.13.so.5.13"
79  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOAMR-pv5.13.so.1"
80  )
81  foreach(file
82  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOAMR-pv5.13.so.5.13"
83  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOAMR-pv5.13.so.1"
84  )
85  if(EXISTS "${file}" AND
86  NOT IS_SYMLINK "${file}")
87  file(RPATH_CHANGE
88  FILE "${file}"
89  OLD_RPATH "\$ORIGIN:"
90  NEW_RPATH "\$ORIGIN")
91  if(CMAKE_INSTALL_DO_STRIP)
92  execute_process(COMMAND "/usr/bin/strip" "${file}")
93  endif()
94  endif()
95  endforeach()
96 endif()
97
98 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
99  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOAMR-pv5.13.so" AND
100  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOAMR-pv5.13.so")
101  file(RPATH_CHECK
102  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOAMR-pv5.13.so"
103  RPATH "\$ORIGIN")
104  endif()
105  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOAMR-pv5.13.so")
106  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOAMR-pv5.13.so" AND
107  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOAMR-pv5.13.so")
108  file(RPATH_CHANGE
109  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOAMR-pv5.13.so"
110  OLD_RPATH "\$ORIGIN:"
111  NEW_RPATH "\$ORIGIN")
112  if(CMAKE_INSTALL_DO_STRIP)
113  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOAMR-pv5.13.so")
114  endif()
115  endif()
116 endif()
117
118 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xspdxx" OR NOT CMAKE_INSTALL_COMPONENT)
119  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/AMR/vtkIOAMR.spdx")
120 endif()
121
