1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/IO/Chemistry
47  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Chemistry/vtkCMLMoleculeReader.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Chemistry/vtkGaussianCubeReader.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Chemistry/vtkGaussianCubeReader2.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Chemistry/vtkMoleculeReaderBase.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Chemistry/vtkPDBReader.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Chemistry/vtkVASPAnimationReader.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Chemistry/vtkVASPTessellationReader.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Chemistry/vtkXYZMolReader.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/IO/Chemistry/vtkXYZMolReader2.h"
56  "/builds/gitlab-kitware-sciviz-ci/build/VTK/IO/Chemistry/vtkIOChemistryModule.h"
57  )
58 endif()
59
60 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkIOChemistry-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkIOChemistry-hierarchy.txt")
62 endif()
63
64 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOChemistry-pv5.13.so.5.13"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOChemistry-pv5.13.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHECK
72  FILE "${file}"
73  RPATH "\$ORIGIN")
74  endif()
75  endforeach()
76  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
77  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOChemistry-pv5.13.so.5.13"
78  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOChemistry-pv5.13.so.1"
79  )
80  foreach(file
81  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOChemistry-pv5.13.so.5.13"
82  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOChemistry-pv5.13.so.1"
83  )
84  if(EXISTS "${file}" AND
85  NOT IS_SYMLINK "${file}")
86  file(RPATH_CHANGE
87  FILE "${file}"
88  OLD_RPATH "\$ORIGIN:"
89  NEW_RPATH "\$ORIGIN")
90  if(CMAKE_INSTALL_DO_STRIP)
91  execute_process(COMMAND "/usr/bin/strip" "${file}")
92  endif()
93  endif()
94  endforeach()
95 endif()
96
97 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
98  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOChemistry-pv5.13.so" AND
99  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOChemistry-pv5.13.so")
100  file(RPATH_CHECK
101  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOChemistry-pv5.13.so"
102  RPATH "\$ORIGIN")
103  endif()
104  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkIOChemistry-pv5.13.so")
105  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOChemistry-pv5.13.so" AND
106  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOChemistry-pv5.13.so")
107  file(RPATH_CHANGE
108  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOChemistry-pv5.13.so"
109  OLD_RPATH "\$ORIGIN:"
110  NEW_RPATH "\$ORIGIN")
111  if(CMAKE_INSTALL_DO_STRIP)
112  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkIOChemistry-pv5.13.so")
113  endif()
114  endif()
115 endif()
116
